Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: drive shaft help please
Old 07-04-2009, 09:44 AM   #1
Default drive shaft help please
does anyone know of a good alternative shaft for a hi lift axle and a peed trany .. i cant have anything special orderd because i wont be in town long .. so preferably something i can get at the local hobby shop.. i dont know the dementions of the shaft but i can tell you that is slightly shorter than a 2.5 t maxx shaft .. and a bit longer than a rustler shaft ... much help would be apriciated since i cant drive myself to the hobby shop to see what would work
thanks
miles
miles is offline   Reply With Quote
Old 07-04-2009, 09:49 AM   #2
crawlinghulls's Avatar
Something like this might work.
http://www.tcscrawlers.com/MIP-C-Dri...1-p-16872.html
Not much more expensive than the traxxas shafts with metal yokes (and you'll never "pop" a shaft). Although, with the traxxas it is easy to cut and modify the length of the shaft.
crawlinghulls is offline   Reply With Quote
Old 07-04-2009, 09:54 AM   #3
ahh thanks ... im not havin trouble with the shafts poping and i have the maxx ones cut and fitted i just cant seem to get the set scew tight enoph and it slips off after a few min. of driving ... is there a good chance these will be at the local shop?
Old 07-04-2009, 10:14 AM   #4
I'm in CT - but I would imagine most shops carry them. They are a direct replacement for an Scorpion (i think). Nothing a phone call can't answer
Old 07-04-2009, 10:25 AM   #5
cool thanks .. im out in oklahoma visiting some familly when i live back in california .. so i cant really special order anything because i need it for here ... thanks for your help
Old 07-04-2009, 10:36 AM   #6
With max shafts, I drill a through hole in the pinion shaft and use the standard long shank set screws that go through the hole.
Can make the joint a little wobbly if the hole is too large.
Start small and you can always enlarge if it necessary.
sweli is offline   Reply With Quote
Old 07-04-2009, 03:32 PM   #7
no dont do that, get some traxxas pede shafts. alum yokes with them. yhey are a direct fit for your tranny, snince thats what truck its from. but you may have to grind the nipple off the axel sides, i dont remember from my highlift if i had to or not.
Kranberry is offline   Reply With Quote
Old 07-05-2009, 05:11 AM   #8
Pretty sure the pinion is long enough on a high lift so you don't have to gring the "nipple" off the traxxas metal yoke.
Old 07-05-2009, 06:04 AM   #9
thead lock works fine
flmudder is online now   Reply With Quote
