Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: MFF Campbell Rock Racer
Old 07-07-2009, 01:06 AM   #1
MadDogRC LLC
Mad4Rnr's Avatar
Default MFF Campbell Rock Racer
This rock racer inspired buggy will be the rig that gets towed behind the MBA Tundra Tow Rig. Chris (a.k.a. ecoli) from Metal Fume Fabrication builts a awesome little 1.9 Campbell rock buggy chassis and his craftsmanship is top-notch, I'm stoked to built it up into a rock basher!
First I took the TLT axles from the Loco FJ which had CVD's, axle-C's and MSD lockouts.
For the front suspenesion I started by replacing the RCP upper link mount with a hand built Delrin unit, the mount lets me have longer upper links which will make sure the axle doesn't roll backon it self.
With 90mm RC4WD shocks, here is the full stuff position:
I wanted the front shocks vertical at full stuff but settled for vertical at full droop:
Click the image to open in full size.:
The wheel base will be around 10.25" inches so to get the rear shock angle I needed new shock mounts, besides the TLT plate on the rear just dosn't look clean so some tube will be out soon. Also a skid plate in the back ground:
Before I make the rear link mount a quick front and rear mock up
I also threw in the axial trans and drive shafts to check the fit.
I ended up having to make a trans spacer out of 1/4" Delrin to get the 19t Orion motor to clear the chassis.
more soon...
Mad4Rnr is online now   Reply With Quote
Old 07-07-2009, 01:10 AM   #2
Gold Star Baby!
Colby's Avatar
Nice!! A buddy of mine got one of these chassi's from ecoli, and he beat the snot out of it. Very strong, and yours is looking good
Colby is offline   Reply With Quote
Old 07-07-2009, 01:24 AM   #3
Hateraide
Code454's Avatar
that looks great and yes Chris does do amazing work you will be really happy with it, cant wait to see more
Code454 is offline   Reply With Quote
Old 07-07-2009, 06:47 AM   #4
Pizza Overlord
salmonfacesalad's Avatar
Yep it sure took a beating.
salmonfacesalad is offline   Reply With Quote
Old 07-07-2009, 06:51 AM   #5
looks like that will be a fun rig to wheel!!
chino438 is online now   Reply With Quote
Old 07-07-2009, 10:12 AM   #6
very nice.
eagar to see it with 1.9s.
I didnt think of using TLT axles or 1.9s.
any particular reason for TLTs?
Rocksolo is online now   Reply With Quote
Old 07-07-2009, 10:36 AM   #7
Southern buggy whore
ecoli's Avatar
Looks good. I realized I forgot to tell you for this one you'd need to put in the spacer to raise the tranny a bit, but it looks like you figured it out on your own ! Tranny/motor was a tight fit, wasn't it?
What wheels/tires are you planning on running?
Rocksolo: reason for TLTs is likely the fact that they're a bit narrower than Axial axles (plus he had them available!) so generally more suitable for 1.9 frames. If you're running Axial axles with this frame, you'd likely want to go with wheels with a lot of backspacing to them to bring them in closer. There's enough options out there now that it's really a matter of personal preference.
ecoli is offline   Reply With Quote
Old 07-07-2009, 10:51 AM   #8
Axial Team Driver
Brandon's Avatar
Looks great Mad4Rnr
Brandon is offline   Reply With Quote
Old 07-07-2009, 11:13 AM   #9
Looks sweet so far Erik that 19 turn motor should be fun on the rocks
BigB_117 is offline   Reply With Quote
Old 07-07-2009, 04:41 PM   #10
sweet! the rigs I've built so far has all had axial (except the moa) axles.
I am not opposed to TLTs plus someone local has a few of them I maybe able to get my hands on
MFF is da shiz
sorry for jacking
Old 07-08-2009, 12:52 AM   #11
MadDogRC LLC
Mad4Rnr's Avatar
Thanks guys, this one will be fun to complete, shoud be done this weekend.
Originally Posted by Rocksolo View Post
very nice.
Thanks man, IMO 1.9's with TLT's look the most scale due to the width, ecoli hit it right on the head...
Word on the tight fit, nice engineering! Looks like 100 thou clearance on each side!
For wheels and tires right now just some 1.9 Flat Irons on black Axial beadlocks but would love to get some Walker Evan's wheels...
Old 07-08-2009, 08:29 PM   #12
looks great
GH Racing is offline   Reply With Quote
Old 07-10-2009, 01:34 AM   #13
MadDogRC LLC
Mad4Rnr's Avatar
Did some work on the rear link mount, used some 3/4" x 1/4" bar stock, 3/16" tubing along with 1/8 rod.
Here it is mid assembly:
Finished and mounted:
Rear suspension full stuff:
full droop:
side view with wheels and tires, i think the stance looks pretty good:
front:
rear:
this weekend I'll paint the chassis, link mount and panels. also try to get the electronics in it
Old 07-10-2009, 09:38 AM   #14
......../-__-\........
helhedded's Avatar
Wow... very nice!
Where do you plan on mounting the electronics?
helhedded is online now   Reply With Quote
Old 07-11-2009, 08:12 PM   #15
It's about time someone did a scale cambell as in with the "right tire size"
Everybody else does 2.2 which is scale to like 48's, 54's. Good job
super mud is offline   Reply With Quote
Old 07-12-2009, 12:48 PM   #16
MadDogRC LLC
Mad4Rnr's Avatar
Originally Posted by helhedded View Post
Wow... very nice!
Thanks, I have a trick up my sleeve for the electronics, just picked up this "trick" yesterday. I want to paint the chassis and cut out the side panels today so might be able to mount stuff tonight
Yeah I noticed that same thing thats why I'm super glad ecoli is making both a 2.2 and 1.9 version of this chassis. I think he did his homeowrk with the proprotioning of this chassis to std 1.9 tires!
Old 07-14-2009, 09:50 PM   #17
ecoli's Avatar
Tick tock, weekends over ;)! Seriously, it looks great so far, can't wait to see the finished product.
Old 07-15-2009, 04:21 AM   #18
I know that the TLT's axles is much more narrow than the Axial's one.
Can i know that the stock width of the TLT's axles ???
Thanks man.
IS520 is offline   Reply With Quote
Old 07-15-2009, 03:42 PM   #19
MadDogRC LLC
Mad4Rnr's Avatar
Thanks man.
Looking around will do you some good:
Axial AX10 Axle Comparison to HPI TLT & PTI
Old 07-15-2009, 03:45 PM   #20
helhedded's Avatar
How are those shocks working out for you? My buddy has a set that sticks until you cycle the shocks and for the record every set that I have got my hands on have stuck. I was just curious to know what you have done/if anything to combat this issue?
