Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: How "Scale" would this setup be
Old 07-25-2009, 01:21 AM   #1
Default How "Scale" would this setup be
IM waiting till payday to order up these shocks
its a metal body that came off a GraveDigger RC cheapo truck i got for free. if i set it up with a winch bumber, headlights, and all that would it work as 1.9 scaler, or should i stick with the plan to do a yota.
BBCorvette18 is offline   Reply With Quote
Old 07-25-2009, 01:36 AM   #2
I like to #*&^
not scale at all, i think you will like the yota in the long run any ways and end up switching to it even if you did do the grave digger body
2500hdon37s is offline   Reply With Quote
Old 07-25-2009, 09:17 AM   #3
jeepcj578's Avatar
looks good
i like to see people think outside the box with bodys
jeepcj578 is offline   Reply With Quote
Old 07-25-2009, 10:49 AM   #4
Practicing my launchs >:)
Robbob's Avatar
Id say run with it ..... you got a solid body and a frame why not.
No offense against the Yota guys but why do the norm? Take your time, try to avoid the shortcuts and youll end up with a killer rig you can enjoy.
Robbob is offline   Reply With Quote
Old 07-25-2009, 10:57 AM   #5
Befriending Champ 09'
crunky's Avatar
throw a set of seats in it, some internal cage work, maybe a little bit of trail damage, and a few beer cans later and that thing will look sick.
crunky is online now   Reply With Quote
Old 07-25-2009, 01:11 PM   #6
~The Scale Shop~
STANG KILLA SS's Avatar
i would save your money on those shocks, you wont be happy with perfomance or leaking.
Old 07-25-2009, 01:24 PM   #7
I <3 LS3
exesivefire's Avatar
who cares what other people think?
will you like it if you build it?
that's all that should matter
exesivefire is offline   Reply With Quote
Old 07-25-2009, 01:42 PM   #8
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
x2. Get the aluminum Axial version for the SCX or get the new Pro-Line scale shocks
Harley is offline   Reply With Quote
Old 07-25-2009, 03:28 PM   #9
Pro-line scale shocks all the way.
Dxxcrawler is offline   Reply With Quote
Old 07-25-2009, 09:05 PM   #10
im going to build it, the way it sits the body weighs just under 2 pounds, i can cut a little out of it but not much. when i had an X-Trail chassis and it set up with this body it didnt work at all it was just way to heavy, but with this chassis and getting a good suspension setup i think it will work
Old 07-25-2009, 10:37 PM   #11
lift it up a bunch and with some bigger tires and a good paint job it should look badass. But it's your build, do whatever ya want! Also the savage/wk shocks sprung would look good if u went with the lifted stance (it would save you money for some other goodies) or are those ax10 shocks?
super mud is offline   Reply With Quote
Old 07-25-2009, 10:43 PM   #12
def. save your money on the shocks they dont have very smooth action to them!!!!!!
rockmahala is offline   Reply With Quote
Old 07-27-2009, 10:56 AM   #13
yes its just got ax10 shocks. and i dont really want to do a "gravedigger" more of a gravedigger setup for rock crawling super low stance, droop suspension.
