06-11-2010, 10:38 AM | #21 |
Rock Crawler Join Date: Oct 2009 Location: San Diego
06-23-2010, 06:51 PM | #22 |
rear shocks mounted and more tube work |
06-23-2010, 06:59 PM | #23 |
Newbie Join Date: Dec 2009 Location: Saint Louis
looks like it might end up top heavy to me.... but never the less great build man
06-24-2010, 07:58 AM | #24 | |
Planning on doing a split battery pack mounted on each side of the gearbox to lower the CG. Last edited by prifral; 06-24-2010 at 08:06 AM. | |
06-28-2010, 11:49 AM | #25 |
battery, servo & winch mounts |
06-29-2010, 01:40 PM | #26 |
Brazing done for now (more to come later for body panel, lights & accessory mounts). Next is to wire it up and test! |
06-30-2010, 01:29 PM | #27 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
Its looking leally good, i recon run it without the body?,the tubework is awsum.
07-01-2010, 10:11 AM | #28 |
| Thanks! Going to run it with a the front clip to keep it looking like a mog. Other than that, a floor and some side panels to hide the gearbox and electronics. Hoping to keep it simple and clean |
07-05-2010, 09:16 PM | #29 |
Finally found some time to take this out for a test run-> http://www.youtube.com/watch?v=uTr1hwR7jg4 Thats a 55t for now but will eventually swap it for more wheel spin. Overall pretty content with the suspension and weight distribution. Things will change when body panels and accessories go on - hopefully for the better. |
07-06-2010, 08:58 AM | #30 |
Quarry Creeper Join Date: Dec 2007 Location: H.B.
Looking good. I bet the panels and accessories will help use the suspension a little more with the added weight. |
07-06-2010, 12:41 PM | #31 |
07-06-2010, 09:22 PM | #32 |
07-07-2010, 03:58 AM | #33 |
Pebble Pounder Join Date: Apr 2009 Location: chino
07-07-2010, 08:17 AM | #34 |
Any front end damage from the head on collision? |
07-07-2010, 10:00 AM | #35 |
07-08-2010, 07:21 PM | #36 |
Built brackets for front clip Clip glued to bracket, bracket and clip is removable for battery access Started wooden deck for cargo area |
07-09-2010, 07:35 PM | #37 |
I wanna be Dave Join Date: Apr 2007 Location: clarksburg
Hey man it looks killer. Your brazeing is perfect and the design looks awesome. As for being top heavy (which I prefer a top heavy rig) you could just weight the wheels and it will help alot.
07-10-2010, 12:25 AM | #38 |
| Thanks! I'll definitely keep wheel weights in mind once I get this thing together and start to tune it. Though I'm watching the weight as I build, its hard to call where it will be once its done. I expect to add on about 1.5lbs max in scale details.
07-12-2010, 05:42 PM | #39 |
Small update(been too busy w/other projects) Got the front aluminum floor cut and braked. Used some 2mm screws to attach it to tubing. Those bolt heads are still to visible for my taste so Ill have to figure something else out. The aluminum will eventually be scuffed up or powdercoat black. The wood flooring will be aged, stained, and faux bolt studs added later on. |
07-19-2010, 05:45 PM | #40 |
Rock Stacker Join Date: Sep 2008 Location: C-ville
looks awesome man keep it up!!!!!!! |
