04-23-2010, 06:48 PM | #1 |
Rock Crawler Join Date: Oct 2009 Location: San Diego
| Tumbler
Another mog build... Started with a set of T-Rex's & an R2 w/disconnect. Using a CR01 shell to set the scale. It'll eventually be swapped out for a more minimal hard body - details on that later. My roller so far-> Front will run drooped. Travel is bias to the rear. Next to my previous build |
04-23-2010, 09:24 PM | #2 |
Quarry Creeper Join Date: Nov 2006 Location: omaha
Nice start, I cant wait to see the end. I love mogs |
04-24-2010, 02:13 AM | #3 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
Hows it ,looking good already there mate,i like those MOG bodies. Ill be watching this build for sure. So does mean i have to start my RF tuber soon now you;ve started another build. |
04-24-2010, 10:51 AM | #4 |
| Yes it does! But aren't you working on something else right now? As long as its next! Just my luck - as soon as I started this mog I was given a GI Joe Willys! So I guess thats next for me... I'll have to keep an eye out for some RF or Comp Crawler axles.
04-24-2010, 11:03 AM | #5 |
This is what inspired my build Not needing to use the entire cab, I decided to pull a mold off the CR01 shell to build a hard front clip. I haven't decided on the final material yet but my first 2 test pulls are made from a mix of bondo & resin reinforced with fiberglass. I managed to trap some air bubbles due to my vigorous stirring but these are good enough for a mock up. Final one should be better. Live and learn! |
04-24-2010, 10:03 PM | #6 |
Quarry Creeper Join Date: Dec 2007 Location: H.B.
Too bad they don't make 2.2 mud pluggers. They would be perfect! Looks good, dude! |
04-25-2010, 12:55 PM | #7 |
I like where this build is going,its going to be cool. The mudslingers would suit it i think too. My SCX honcho is done,just get my mini up and going,and its on to the tuber. |
05-02-2010, 06:16 PM | #8 |
Made some progress on the cab. Its removable from the frame via bolts. |
05-17-2010, 07:01 PM | #9 |
Havent had much time to put into this build lately. Just got the stinger finalized along with battery placement. |
05-23-2010, 10:04 AM | #10 |
Got more tube and tried narrower 1.9's just to see how they look. Definitely want to stick with 2.2's but nice to have the option to run 1.9's. Probably will scoot the rear axle forward .5 inch. |
05-23-2010, 10:55 AM | #11 |
Rock Crawler Join Date: Jul 2008 Location: gilbert
Those 1.9's give it a better scale look as compared to the 1.1 rig. Keep up the great work. Subscribed!
05-24-2010, 12:46 AM | #12 |
Quarry Creeper Join Date: Feb 2010 Location: melbourne
Wow you wouldnt think you would have good articulation with the front shocks layed so far forward like that
05-24-2010, 11:13 PM | #13 |
05-24-2010, 11:25 PM | #14 |
| You're absolutely right. I'm still playing around with that - as you can see from the original placement I have removed and rotated that front upper mount. The articulation still sucks but I don't really want to lay the shock down rear ward as it wouldn't be as scale looking for a mog... but that may be my only resolve.
06-02-2010, 10:57 AM | #15 |
Some days you just wake up with a need to chop it all up and try something different!... |
06-02-2010, 11:58 AM | #16 |
I wanna be Dave Join Date: Apr 2007 Location: clarksburg
Looks even better!! It takes alot of balls to cut up something you have so much time in...It was well woth your efforts..
06-02-2010, 01:46 PM | #17 |
Pebble Pounder Join Date: Dec 2009 Location: salina,ks
that is pretty bad ass man, great job
06-02-2010, 03:24 PM | #18 |
RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| That's Cool Impressive frame work. I can see you masterpiece coming together. |
06-09-2010, 08:31 AM | #19 |
Some progress... |
06-10-2010, 09:34 PM | #20 |
Pebble Pounder Join Date: May 2008 Location: El Monte
nice man.... still have the unimog body?? |
