08-13-2010, 02:17 PM | #1 |
Quarry Creeper Join Date: Mar 2008 Location: Pittsburgh
| Camel Tophy Defender 110 build. **Teaser vid added 9/9/10**
One of the things I've always liked about the Defender 110 models, is that you had to hand build your own, and that meant you would be joining a semi-exclusive group of builders. Rumor has it that RC4WD will be producing a fairly inexpensive 110. I have to admit, I hope it doesn't happen, I like that there aren't many 110 out there. This is my first ever styrene project, I know, I should have started with something easier, but as they say, go big or don't go at all. Anyway, on to the build. I'm not trying to make a perfect reproduction but I do want it to be true to the 110's used in Camel Trophy. Here's what I'm trying to get close to. Last edited by Stburr91; 09-09-2010 at 03:12 PM. |
08-13-2010, 02:24 PM | #2 |
RCC Addict Join Date: Dec 2007 Location: Calgary
Wow, you've done an awesome job on stretching it Looking forward to seeing more pics.
08-13-2010, 03:29 PM | #3 |
Rock Crawler Join Date: Jun 2010 Location: Forsyth County, Georgia
Hell yes man. There are not many 110s like you said, and if you pull one off you pretty much are at the top of the builders list |
08-13-2010, 04:32 PM | #4 |
Official Scale Nazi Join Date: Sep 2004 Location: Monticello, IL
Awesome section job!
08-14-2010, 01:02 AM | #5 |
Quarry Creeper Join Date: Jan 2009 Location: Lowell Massachusetts
Wow, you make it look easy. Good job
08-14-2010, 03:25 AM | #6 |
RCC Addict Join Date: Feb 2007 Location: sweden
That was an perfect executed job! Well done!
08-14-2010, 06:33 AM | #7 |
RCC Addict Join Date: Feb 2008 Location: your back yard
I you sure this is your first? Looks to me that you have been doing this for years. Great work. |
08-14-2010, 06:51 AM | #8 |
08-14-2010, 07:01 AM | #9 |
RCC Addict Join Date: Nov 2007 Location: Massachusetts
Wow, That chop job came out great- Really looking forward to seeing how this one comes out..! Subscribed..! |
08-14-2010, 07:11 AM | #10 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
Stunning job, the cut itself and the extension pieces. How did you get that nice of a bend on the roof section. When I first looked at it I thought you had cut that piece out of another body. Nice
08-14-2010, 08:15 AM | #11 |
RCC Addict Join Date: Mar 2007 Location: MS Gulf Coast
Nice work! I'll be watching this, I love the Camel Trophy rigs and Defender 110's of course. |
08-14-2010, 01:22 PM | #12 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
as said above,subscribed,nice sectioning of the body.
08-14-2010, 01:29 PM | #13 |
Pebble Pounder Join Date: May 2008 Location: in the shop
great body mod skills. I like that you did this stretch with only one body. I would have tried it with 2 bodies.
08-14-2010, 01:46 PM | #14 |
RCC Addict Join Date: Sep 2009 Location: Bradenton
very nice cant wait to see the out come |
08-14-2010, 01:57 PM | #15 | |
Thanks guys, I'll have an update later tonight. Quote:
I would have liked to use two bodies, but at about $80 each, I decided to use only one. | |
08-16-2010, 11:13 AM | #16 |
Got some more work done. I started on the the bull bar and roll bar. I've read that it is very hard to get the 180 degree bends right for the bull bar, so I wanted to find an easy was of doing it. I found two jars of paint the were the perfect size, and clamped them down the correct distance apart. From there is was just simply bending the brake line around them. It was very easy, and it came out perfectly on the first try. Now just braze it up. The finished bull bar with mounting plate. |
08-17-2010, 08:10 PM | #17 |
Sweet bending & brazing job on the brush guard. This is really going to turn out awsome
08-18-2010, 10:03 AM | #18 |
I did a little work on the chassis. Because I have some much Axial stuff, I decided to use it for this build. I'm using a SCX chassis, which is a little sort, and can't accommodate the 13.25" wheel base, so I simply moved the rear shock hoop back. The next problem was the driveshaft is too short. I like to use the Traxxas half shafts in my Axial rigs, so I cut and glued a couple of the shafts together. Here's a few pics. You can see that the shock hoop have been moved back, and the rear driveshaft has been lengthened. Last edited by Stburr91; 08-18-2010 at 10:09 AM. |
08-18-2010, 03:43 PM | #19 |
Quarry Creeper Join Date: Aug 2009 Location: Syracuse
| Great job so far, cant wait to see the finished product |
08-18-2010, 06:43 PM | #20 |
Newbie Join Date: Aug 2004 Location: blairsville
nice rig so far keep up the great job
