03-11-2012, 04:34 PM | #281 |
| Re: eric113's honcho flatbed now with portals
I finally got my locker fixed thanks to MThead. While he had my stuff I did another mod. Its not for the faint hearted. I will let you guys figure out I did. |
03-11-2012, 04:42 PM | #282 |
Pebble Pounder Join Date: May 2011 Location: Antwerp Belgium
You maked/buyed a behind the axle steering. You shaved a bit of the axle hous in the middle of on the bottom side. And... euhm, that's it |
03-11-2012, 04:44 PM | #283 |
Looks like you shaved the bottom of the axles cases.
03-11-2012, 05:30 PM | #284 |
| Re: eric113's honcho flatbed now with portals |
03-11-2012, 09:18 PM | #285 |
Quarry Creeper Join Date: Feb 2012 Location: Texas - just outside of Austin
Your truck is crazy..I had no idea they made portal axles for RC! Is there a website for ya'lls trail runs/comps? I'm in Cedar Park.. thanks |
03-11-2012, 09:58 PM | #286 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
Sweet build Eric, took me an hour to catch up on it, but well worth it.
03-12-2012, 10:46 PM | #287 |
Rock Stacker Join Date: May 2008 Location: oregon city
How did you shave the axles so much. Did you have to mod the r&p also
03-13-2012, 04:25 PM | #288 | ||
| Re: eric113's honcho flatbed now with portals Quote:
I drew line around and cut with my dremel. Yes you have shave the ring gear ALOT. | ||
04-11-2012, 07:09 PM | #289 |
I know been slacking on the updates, I moved and clean up the garage and get my work bench setup. I need to get this ready for ECC and maybe a local comp. I been needing to get bunch of misc. little mods done. I painted up a new cab. I wanted to do color out the norm for me. I need to reforce the back of the cab, install side mirrors and get it stickered up. While back I ordered up Holmes hobbies team torquemaster 25t with 6* timing. Hoping the foam filter will help keep the crap out. Also updated the to latest firmeware on BR-XL. I wanted more steering, I drilled and tapped the arms for zero ackerman. I also went back to normal steering links. I also remade my own panhard link. Need to clean them up and get them painted. Last edited by eric113; 04-11-2012 at 07:20 PM. |
04-11-2012, 07:44 PM | #290 |
Quarry Creeper Join Date: Feb 2011 Location: Princeton Illinois
R u not running the pitbulls anymore?
04-13-2012, 09:02 PM | #291 |
04-13-2012, 09:18 PM | #292 |
RCC Addict Join Date: Oct 2007 Location: gervais
For shaving the axles, did you cut the bottom off completely and glue a thing of styrene on or what?
04-13-2012, 09:34 PM | #293 | |
To give idea how much ring gear needs to be shaved. Last edited by eric113; 04-13-2012 at 09:41 PM. | |
04-13-2012, 10:06 PM | #294 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
Damn Eric Do the tires turn magically or do you just have amazing gear mesh for how little is left of the ring gear?
04-13-2012, 10:14 PM | #295 |
04-13-2012, 10:27 PM | #296 |
How does it look on the inside with the pinion on it? I don't know if it's the pic or not but the milled one doesnt have that doohickey on it in the axle does it? Because then ya that very little but if the thing is off, seems like you still have a good amount still, should be fine then Edit: actually have you thought of lengthening the pinion shaft to put the pinion closer? Like shave the top of the pinion so that the stronger base of the pinion is meshed with the smaller ring gear? Last edited by demonoid369; 04-13-2012 at 10:31 PM. |
04-13-2012, 10:30 PM | #297 | |
I'm not following on the doohickey part. I did run it around the yard today full blast and never skipped a beat and sounded great the whole time. | |
04-13-2012, 10:33 PM | #298 |
| That thing that's on the diff on the left one Edit: I also added another question/thought to the post I did |
04-13-2012, 10:38 PM | #299 | |
To your edited question, I'm going to run as is and see how it holds up. | |
04-13-2012, 10:48 PM | #300 |
Aaaaaaahhhhhh alright that's what it is lol wasn't sure. Thought maybe that was the chuck you put on it to allow yourself to turn the ring gear down lol
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/276351-eric113s-honcho-flatbed-now-portals.html | ||||
NEW project ----------- der es wird alles besser HILUX - Seite 4 - 4x4 Scaler auf Axial SCX10 Basis - rockcrawler.de | This thread | Refback | 12-12-2011 12:47 PM |
