Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: New Jungle Rescue crawler
Old 04-01-2006, 02:43 AM   #1
Default New Jungle Rescue crawler
Hey guys,
Thought i'd drop in a picture of my current scale build.
Body is from a truck from the bay, TLT axels and a lot of fiddling and building,
Still have the wheels to die, ESC and reciever to fit, a few scale bits and pieces to tack on and a few tool boxes to cover the gear box. Fairly happy with the flex so far, will work on it once it is finished.
Feedback kindly appreciated.
Thanks guys.
savageaussie is offline   Reply With Quote
Old 04-01-2006, 06:13 AM   #2
Hmmmmmmmmm, that looks a lot like my last build a few months ago....
http://www.imagestation.com/album/pi...?id=2123689760
jwrape is offline   Reply With Quote
Old 04-01-2006, 10:20 AM   #3
Umm...................... do the drive shafts work on that angle ?
madhatter is offline   Reply With Quote
Old 04-01-2006, 10:23 AM   #4
Not sure who's your talkin' about but mine work good.
Old 04-01-2006, 10:47 AM   #5
I think he's reffering to the orignial poster, as am I. Those DS & axle angles look atrocious.
RANOVRU is offline   Reply With Quote
Old 04-01-2006, 11:08 AM   #6
Does the suspension move at those angles on its own? Hows the steering?
ManiacMagoo is online now   Reply With Quote
Old 04-01-2006, 11:48 AM   #7
Location: a place of settlement, activity, or residence.
Those driveline angles are definitely scary. Maybe you should ditch the tires and go with some Masher 2K's and lower it about a 1/2". I think it would look a little better. You could also drop the transmission and link mounts.
thaclodking is offline   Reply With Quote
Old 04-01-2006, 11:48 AM   #8
1 man, 2 sons
Unimoger's Avatar
wow, those are some violent driveline and link angles, sterring, flex????
Unimoger is offline   Reply With Quote
Old 04-01-2006, 12:18 PM   #9
well put!
chaotic_life is offline   Reply With Quote
Old 04-01-2006, 04:51 PM   #10
I love how everyone says the same thing only in different words..
Collapse_The_Masses is offline   Reply With Quote
Old 04-01-2006, 07:46 PM   #11
Hey Guys,
Thanks for the concern on the drive shaft angles, They all seem to work fine I have angled the diffs a little to help stop the binding, will try to get a flex shot when it's done. It is based on a 1:1 Australian troop carrier and support truck, similar to the merc Unimog, I need the bigger tyres to help it look the same, A little higher than the original but i like to have the center clearance.
cheers
Old 04-01-2006, 10:00 PM   #12
Get off my lawn!
microgoat's Avatar
Your center clearance is gone anyway; the fenders and steps hang down to the tops of the tires. If you lower the tranny you'll have a lot smoother running without losing any clearance and have a lot more functional truck. Not only will your driveshafts not bind up (and you'll be able to fix that caster angle) but you'll lower your center of gravity by a good inch, and you'll have a place to hang the links so they're not vertical.
I know it sucks having to rebuild your whole truck; I've done it myself many times.
This truck as it is now reminds me of a gal I used to date. Nice to look at, but I wouldn't want to spend too much time with her. Drop the tranny about an inch and a half and you'll be in much better shape.
microgoat is offline   Reply With Quote
Old 04-02-2006, 11:04 AM   #13
AKA TOKEN
ColquittCustom405's Avatar
Man........
ColquittCustom405 is offline   Reply With Quote
