scx10 chassis for hilux body I was wondering if anyone knew what scx10 chassis to use with a tamiya hilux body. I know that there are two different wheelbases but just not sure which one to use Thanks in advance |
If you are looking for an rtr, then the dingo will work. and if you want a kit, go with the normal SCX10. The honcho wheelbase is too long. |
The chassis length is the same, it's just the links that make the wheelbase shorter or longer."thumbsup" |
Kit or Dingo. |
is there a SCX+hilux craze right now? I think this is like the 5th person this week asking the same question... Dingo will be a better start to match the wheelbase but it'll be plastic. If you got the kit all you need to do is buy 2 extra links i believe 98mm for the rear and it'll work. Things might get complicated if you change your upper links thou. |
