02-18-2012, 11:59 AM | #221 |
Quarry Creeper Join Date: Sep 2007 Location: strawtown
| Re: MONGO - built specifically to steal exotic cars off a speeding train
good to see it actually up and running. there have been a few hydraulic steering builds on here but this is the first one i've seen get this far. most die off while they are still working out the steering. keep up the good work |
02-18-2012, 10:48 PM | #222 | |||
Rock Crawler Join Date: Oct 2009 Location: San Diego
| Re: MONGO - built specifically to steal exotic cars off a speeding train Quote:
I dont do wheel speed Quote:
With that in mind I manage to get out and put another lipo through the rig today. The hydro system is still performing well w/no leaks. Though I do notice a thin coat of oil on the shaft from time to time - the oil level has not dropped. A short vid from today: Amongst a myriad of other things Im stil waiting on new wheels/tires and ESC but driving around with the current setup is essential in figuring out what works and what doesnt in the geometry and balance department. Discoveries made at this stage will help determine materials/weight that I can afford to throw on this rig to "finish" it | |||
02-18-2012, 11:41 PM | #223 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
Awesome videos, it's nice to see this thing out there in the wild. The Hydro looks great-congrats on the success there. One question, even without the finishing touches, I would have expected to see a lot more body roll with all that tube up high. Is there a trick as far as your shock setups or is it just an optical illusion as to the amount of "weight"? It really looks like the chassis doesn't know the cab is riding way up high. More great work will surely follow...we'll be here! Last edited by Bulldog; 02-18-2012 at 11:44 PM. |
02-19-2012, 11:35 AM | #224 |
Newbie Join Date: Jan 2012 Location: Oceanside
awesome idea, that thing is def not something u see everyday. good job
02-19-2012, 09:00 PM | #225 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
Cool build
02-19-2012, 09:20 PM | #226 |
Jeep whore Join Date: Aug 2008 Location: Florida
very nice! and very squeaky |
02-20-2012, 01:51 AM | #227 |
Pebble Pounder Join Date: Jun 2011 Location: Australia
what are you using to pump the fluid cause it soundsl ike a servo
02-20-2012, 02:36 PM | #228 |
Quarry Creeper Join Date: Jul 2009 Location: Back from vacation!!!
Very nice, well balanced too!!!
02-20-2012, 02:47 PM | #229 |
Looking for new Trails Join Date: Dec 2008 Location: GPS locating signal.....
AWESOME built ... that thing move's so easy and smooth...
02-21-2012, 10:13 PM | #230 | |||
Thx! Thx! Quote:
Thx! Considered welded steel or aluminum for the bed frame but the steel is too heavy and both are too rigid. A rigid bed frame would not take impacts well, the thin cross section would bend too easily. This is very important in my consideration because I anticipate many roll overs with this rig After brainstorming a bit an old 1/4inch thick lexan racing windshield caught my eye. This would be ideal because it retains excellent memory and most importantly it can take high impacts. So I chopped the windshield up and squared it off. The idea is to use the lexan for the frame and cut out the blacked out areas between the rails as well as machine certain areas to reduce weight then inlay an aluminum panel over the entire bed. | |||
02-22-2012, 09:41 PM | #231 |
Lexan bed roughed out. Gotta switch gears and address the mounting system for the bed. The front will be attached to the bed via a truss system. The rear will be permanently bolted to the rear bumper and the rear bumper will pivot on the ladder frame. The idea is so that the bed pivots back to allow easy access to the battery and electronics etc. - hence the 3.6oz bar of 7075 sitting on the frame in this pic. Got lots of machining ahead of me. Hope to remove at least 2/3rd of the bar weight when bumper is done. I am deviating from movie car by adding this bumper as well as shortening the ladder frame - all in hopes for better functionality. Some ideas. |
02-24-2012, 08:01 PM | #232 |
the Setra scale I used to weigh my bar stock was faulty - ofcourse I didnt find it out until machining was underway. So initial weight was way off. At this stage it comes in at 290 grams. Lots more machining to do - should shed a bunch of weight once material is hogged out from the back. |
02-24-2012, 08:04 PM | #233 |
awesome machining skills!
02-25-2012, 10:07 AM | #234 |
Newbie Join Date: Jul 2009 Location: west jordan
this build is awesome!!! NICE WORK! i'm on the edge of my seat! |
02-26-2012, 12:19 AM | #235 |
Pebble Pounder Join Date: Jan 2012 Location: colorado springs
Its a long build but I love it.
02-26-2012, 10:48 PM | #236 |
down to 160 grams |
02-27-2012, 09:02 AM | #237 |
Rock Crawler Join Date: Jun 2010 Location: Colorado Springs
Rear bumper turned out great!
02-27-2012, 09:12 PM | #238 |
| Re: MONGO - built specifically to steal exotic cars off a speeding train |
02-27-2012, 09:23 PM | #239 |
Pretty high up for a trailer hitch haha Are those angle brackets holding the rear bumper going to turn into a pivoting mechanism like you mentioned earlier? Or maybe just remove a pair of those screws to pivot?
02-28-2012, 08:32 AM | #240 | |
wheels/tires: These are GCM Racing Detroit Baja 1.9 Beadlocks w/the disc brake hex. My favorite because of how clean it looks and craftsmanship is superb These are CAC ONE9 12 Hole 1.9 Beadlock. Awesome wheels as well but a bit too busy for this build. I may anodize the rings and use black hardware to make them more subtle. Tire wise: the Baja Claws seem to be the right diameter but the Rock Beast will definitely be the go to for performance. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/332988-mongo-built-specifically-steal-exotic-cars-off-speeding-train.html | ||||
TIMBERJACK 480B DEBUSQUEUR | This thread | Refback | 03-01-2013 05:51 AM | |
"Mongo" - page 3 | This thread | Refback | 03-01-2013 03:38 AM | |
RCFansÒ£¿ØÃÔ|RCFansÂÛ̳ - Powered by Discuz! | This thread | Refback | 02-17-2013 08:33 AM |
