12-11-2011, 10:20 PM | #101 |
Rock Crawler Join Date: Oct 2009 Location: San Diego
Tranny plate roughed cut and fitted - its made of white delrin, for now Havent decided on which tranny to go with yet: SCX10 or Wraith. If turning radius become a problem definitely will try the Wraith dig... though I have a spare VP dig around here somewhere as well. SCX10 tranny Wraith tranny Chassis overall shot. The frame rails will be milled out in various areas to reduce weight but that cant happen until placement of everything else is figured out. Last edited by prifral; 12-11-2011 at 10:22 PM. |
12-11-2011, 10:49 PM | #102 |
Quarry Creeper Join Date: Sep 2010 Location: Deus est mortuus, logica obtinet.
looks like it is coming along nicely! i can't wait to see the end result!
12-13-2011, 11:19 PM | #103 |
Newbie Join Date: Apr 2011 Location: St. Catharines
Wow. Just Wow. What an awesome job you have done so far. Just one thing, have you thought about rounding the corners on the chassis mounts. It wont shave much weight but it may prevent anything from hanging up on the rig in tight spaces and I think it will look better too. Keep up the amazing job.
12-22-2011, 01:48 PM | #104 | |
| Re: MONGO - built specifically to steal exotic cars off a speeding train Quote:
I machined an aluminum tranny cradle that bridges the two side plates and more importantly dropped the tranny an additional 1 inch. The hardware will eventually be countersunk and a delrin skid plate added. Tranny is not bolted down yet but as you can see the spur will be well bellow the bed | |
12-22-2011, 02:14 PM | #105 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
When it's fisished you need to send it my way so it can be tested Really looking good man what do you think that the final tire will be?
12-22-2011, 02:36 PM | #106 |
Looking for new Trails Join Date: Dec 2008 Location: GPS locating signal.....
Looking good, coming along very nice...
12-23-2011, 11:04 AM | #107 |
thanks guys inched along a bit more. tranny mounted, screws countersunk the beginning of the belly. these are two Delrin rails. it was important that these not be an integral part of the structure so they can be sacrificial material and easily replaceable should they wear out over time. eventually their shapes will be improved ie corners beveled so they can easily slide off obstacles the space between the Delrin rails will be bridged by a carbon fiber plate. if electrical interference becomes a problem I may default back to a Delrin plate. I just like carbon fiber as it slides better than Delrin, especially on rocks. |
12-23-2011, 12:51 PM | #108 |
Really like the carbon fiber idea you'll have to let us know how it works out.
12-23-2011, 02:26 PM | #109 |
Pebble Pounder Join Date: Apr 2011 Location: Liverpool Y.N.W.A.
This looks well cool.... great attention to detail, the angles, all look perfect..... nice one |
12-23-2011, 10:54 PM | #110 |
Rock Crawler Join Date: Jun 2010 Location: Colorado Springs
Awesome replaceable delrin slider idea! Keep it coming Merry Christmas! |
12-26-2011, 02:43 PM | #111 |
Got a skid plate idea Im content w/for now ... 2 delrin sides that capture a carbon fiber plate in the middle the carbon fiber plate will have to be notched for the drive shaft clearance later on - but first I have to extend the outputs of the gearbox so that the drive shaft isn't sticking out in the open/unprotected by the lower links. |
12-26-2011, 04:36 PM | #112 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
Wow, you do AMAZING work. I love building stuff like that, I just don't have the patience for the perfection you obviously strive for. Is all your mill work on a manual mill or CNC? Keep it up! Tim.
12-26-2011, 08:57 PM | #113 |
RCC Addict Join Date: May 2010 Location: Midwest
Looks like this thing is going to be fun! Nice machine work |
12-27-2011, 12:38 AM | #114 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
I've been watching and not commenting...but I owe you one! The precision of this build is astounding. It's a great build to watch. I love it! Keep wowing us! |
12-27-2011, 02:20 AM | #115 |
Rock Stacker Join Date: Mar 2009 Location: AU
very interesting, awesome precision.
12-28-2011, 04:04 AM | #116 |
Rock Crawler Join Date: Apr 2005 Location: Upland
This is coming along nicely. I'd like to see your tube bender if you don't mind. Are you going to develope it to sell? I'd definitely be a buyer for one. Great job on the build. Can't wait to see it rolling and stealing cars.
12-28-2011, 11:33 AM | #117 |
Rock Stacker Join Date: Mar 2010 Location: Fargo
This is sweet. You should find out who made the 1:1 and show them it.
12-28-2011, 12:48 PM | #118 | |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
12-28-2011, 07:59 PM | #119 | ||
Roughed out the end caps of the frame. I ended up machining a drill jig in order to drill the four holes through the end caps into the ladder frame longitudinally. Basically the problem was that I simply could not stand the ladder frame up on its end to drill those holes on my bench top drill press - not tall enough, even if I could it would not be very precise. Problem solved, I tapped the side rails for 2.5mm bolts. This should keep the ends close to perfectly square. I may add bolts through the side later on to pinch the rails but for now the pieces fit snug enough. An overall progress shot to date: Next up is to locate the cab onto the frame and create the mounts for that. Then locate the gearbox/upper link mount assembly onto the frame. Once that is done I can cut the frame to length at the rear then its onto links/suspension. Yipes! Long way to go! | ||
12-28-2011, 08:39 PM | #120 |
that looks amazing. your work is impressive! i hope once i have finished school for machining that i can do some projects like this!
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/332988-mongo-built-specifically-steal-exotic-cars-off-speeding-train.html | ||||
TIMBERJACK 480B DEBUSQUEUR | This thread | Refback | 03-01-2013 05:51 AM | |
"Mongo" - page 3 | This thread | Refback | 03-01-2013 03:38 AM | |
RCFansÒ£¿ØÃÔ|RCFansÂÛ̳ - Powered by Discuz! | This thread | Refback | 02-17-2013 08:33 AM |
