Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: ***land rover defender 110 camel trophy***
Old 08-27-2011, 02:22 PM   #1
Default ***land rover defender 110 camel trophy***
Hello, my name is Ivan and I am from Spain.
I will present my project of a Land Rover 110 Camel Trophy
I do not speak English well, but try to explain.
I started the bodywork:
I cut the bodywork to make a 110
I made ​​the door for 110
I used plastic plates to attach the body parts
I applied putty for the joints
I have applied to give rigide vidro fiber inside
I have painted with primer, painted with tamiya, place stickers and finished with a layer of lacquer
some details of the bodywork
Well, tomorrow more.
Saludos
Iván
igonzalezlago is offline   Reply With Quote
Old 08-27-2011, 02:56 PM   #2
WOW!..great job ivan!...lookin forward to see this build.good luck
GREEDY GENIUS is offline   Reply With Quote
Old 08-28-2011, 12:39 AM   #3
Great bodywork
CJ318 is offline   Reply With Quote
Old 08-31-2011, 12:48 PM   #4
Hello, today the construction of the roll bar and roof rac:
Roof:
Roll bar:
installed in the car:
Saludos
Iván
Old 08-31-2011, 02:23 PM   #5
Damn son, kickin azz and takin names. Killer job, you got skillz..
stelerzman is offline   Reply With Quote
Old 08-31-2011, 05:42 PM   #6
looking great so far!
Highboost73 is offline   Reply With Quote
Old 09-08-2011, 01:41 PM   #7
some more photos
Now the defense
Old 09-25-2011, 03:33 AM   #8
hello
Now begins the chassis and mechanical
Saludos
Iván
Old 09-26-2011, 07:42 AM   #9
Great work so far!!!
papakev01 is offline   Reply With Quote
Old 09-26-2011, 08:45 PM   #10
awesome so far! Did you cut the chassis with a laser cutter?
rcjeepbuilder is offline   Reply With Quote
Old 09-27-2011, 12:35 PM   #11
Hi, thanks for the comments.
The chassis is laser cut into 2 mm, bumpers and brackets gearbox are laser cut from 1 mm all stainless steel
Saludos
Iván
Old 09-27-2011, 02:14 PM   #12
Wow..simply amazing!
I'm building a range rover sport now and just got thru fabing the front bumper,i tried to make it look like the safari guard bumper with a slight twist.
Great job on this build so far!
Old 10-25-2011, 06:34 PM   #13
Wow you D110 is looking amazing. I have seen so much custom fab work on different builds and read a lot of literature on materials used but still don't have the grasp needed to proceed myself. Still a rookie but eager to learn. My friend has a tig welder and a mig welder. What material did you use for your bumper? Did you braze it? And finally what sort of tube bender are you using? A D90 will be my winter build and also my first hard body scaler. Any info or tricks you've learned and willing to share would be appreciated. Thanks for posting so many pics for points of reference.
JimmyJam is offline   Reply With Quote
Old 11-05-2011, 01:31 PM   #14
Hello, defense is stainless steel 1 mm thick. This soldier with a few points and then TIG rod Platex with 30% silver.
Saludos
Iván
Old 11-05-2011, 01:37 PM   #15
Hello, now we continue with the defense.
Since welding is finished and smoothed.
I made a channel inside the defense to put a grid.
Then I painted it all with epoxy paint and this is the result.
Saludos
Iván
Old 11-06-2011, 01:40 AM   #16
Looks awesome, do you have two of these bodies on the go? I notice one for mock ups that is not yellow
Arctic Fire is offline   Reply With Quote
Old 11-06-2011, 04:21 AM   #17
Hello, I have not only a body. First a yellow paint but was not the color camel, then the entire sand and returned to painting with Tamiya camel yellow.
The car, during construction, has had several changes,
First used axes to cut F-350, an aluminum chassis and a transfer cut craft built for me. After I changed things up to the latest photos I post.
Saludos
Iván
Old 11-06-2011, 04:24 AM   #18
nice work
mud-sweat-gears is offline   Reply With Quote
Old 11-06-2011, 06:35 AM   #19
That's great! Well planned so far and the mesh on the "defense" as you call it is a nice touch!
murdock is offline   Reply With Quote
Old 11-06-2011, 01:02 PM   #20
Wow nice job. I have dreamed about building, but have not gottin there yet. I do have some advice that I have learned over the years of scale building.
Every led light needs a fluted lens. They just dont look good without.
Amazing build keep it coming
Evan
SlickRockSpider is offline   Reply With Quote
