08-24-2012, 12:36 PM | #21 |
RCC Addict Join Date: Jan 2010 Location: Barboursville, WV
| Re: Cole's Big Block Blazer you just convinced me that my truck needs power more than it needs an interior No mud or water for the pro4? Last edited by brianw; 08-24-2012 at 07:32 PM. |
08-25-2012, 12:00 AM | #22 |
Going Fast Join Date: May 2011 Location: Hazzard County
The pro4 went in this summer, so no mud or water around here. (I havnt looked too hard) But it will be slinging plenty of it at NWSC!
08-25-2012, 01:10 AM | #23 |
| Re: Cole's Big Block Blazer what have you done (or will do) to waterproof the motor? |
08-25-2012, 12:10 PM | #24 |
| Re: Cole's Big Block Blazer |
08-25-2012, 02:37 PM | #25 |
I've finally had it with the rc4wd 110mm shocks, so threw some 95mm powerstrokes I had on and it's much better. But I may dual shock the front because it's so front heavy. What has been anyones experience with dual shocks?
08-26-2012, 07:26 PM | #26 |
Tiny update, installed a long MIP male bone drive shaft for a traxxas summit, it's just barely is short enough with the length I have the rear extended now. |
08-26-2012, 07:37 PM | #27 |
Rock Stacker Join Date: Jun 2012 Location: Jensen Beach, South Florida
Love the truck, the cut boggers are sick! I bet they work great especially in the rear for when things get nasty. very nice.
08-27-2012, 12:04 PM | #28 |
08-28-2012, 05:12 AM | #29 |
Rock Stacker Join Date: Feb 2012 Location: usa
I had those wideers before I hated them rc4wd has some now that fit tight but way better
08-28-2012, 10:53 AM | #30 | |
| Re: Cole's Big Block Blazer Quote:
My g mades work pretty well for me. | |
08-28-2012, 11:16 AM | #31 |
Put a brand new MMP in last night, testing it out today. This should solve my overheating issue.
08-28-2012, 09:47 PM | #32 |
Finally got a full pack through it today. With just some carnage Found a hole in one of my boggers, which is surprising because they only have 5 hours of run time on em. I also found 2 little holes in the sidewall of one of the iroks! So I dont know if it was a fluke or I need different tires? Also noticed a couple times when this irok was wedged in a hole, the wheel would spin inside the tire. Hopefully a remount will fix it but it was mounted well the first time. Here's the spun bead. And on a nasty roll over the cage landed right on a pointed rock and promptly snapped it, plastic welder to the rescue |
08-29-2012, 11:43 PM | #33 |
I mounted my 1.9 stamped steel wheels 4 different times today because they kept losing the bead I guess they cant hold what the pro4 dishes out on 3s/65c. So I need some reliable beadlock wheels in time for NWSC at the end of september. I was thinking the gearhead slot mags but havnt read any reviews. So my question is whats a wheel that can stand up to the abuse I put this rig through??? And a pic from todays testing |
08-30-2012, 06:19 PM | #34 |
Rock Crawler Join Date: Jun 2010 Location: UTAH COUNTY
Can you take and or post any vids of this rig? I wanna see how that pro4 setup does. Please.
08-30-2012, 10:41 PM | #35 | |
I don't have any vids as of yet, but I'm going to the dunes tomorrow and threw some panther paddle tires on it. I'll get some vids in the sand but they will be more like FOFF vids | |
08-30-2012, 10:52 PM | #36 |
UGC rc4wd steelie spacers and a lil scuffing of the wheel/spacer helped with spinning the beads for me. Seems like the steelie is a lil too slick. Underground Crawlers RC4WD spacers The iroks look awesome on the steelies, always preferred the normal looking wheel style Last edited by Meatwad; 08-30-2012 at 10:54 PM. |
08-31-2012, 04:15 PM | #37 |
Newbie Join Date: Feb 2011 Location: Portugal
08-31-2012, 07:55 PM | #38 |
Did you need special pinions or could you use the ones you already had?
09-03-2012, 09:50 PM | #39 |
| Re: Cole's Big Block Blazer Rc FOFF Axial SCX10 Crawler - YouTube Sadly, I only got this tiny vid with my iphone, too much fun playing with it! After 20 min. of bashing the bolt that holds the knuckle to the chub fell out, and I noticed the Vanquish chub threads were stripped out Witch cut me short. |
09-03-2012, 09:59 PM | #40 |
My gearhead slot mags came today, looks like they will actually hold the bead, love the look too! And a roost pic |
Cole's Big Block Blazer - Similar Threads | ||||
big block question... | brandonwalsh420 | Losi Micro-Rock Crawler | 15 | 03-07-2012 04:26 PM |
big block questions | brandonwalsh420 | Losi Micro-Rock Crawler | 4 | 12-31-2011 06:11 PM |
C/K packin big block heat | livewires | HPI Wheely King | 10 | 05-09-2011 06:37 PM |
Big block swap | hitman46mod | HPI Wheely King | 12 | 12-15-2007 06:29 AM |
