04-02-2013, 12:38 AM | #41 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| Re: Ax10wannabe's attempt at an F350 crew cab
took the servo off and mounted the front axle for mockup.... the shock hoops are off front and rear and the frame sticks out past the hood too much for my liking so either i can move the shock hoops forward and make longer links or i can chop off some off the front and leave the axle where it is.. next the rear hoops are too far forward so i can drill new holes and move them back on the frame.. also sold the rock sliders that i made to a friend because they are too short so im gonna make some news ones.. here's some pics of what im talking about.... |
04-02-2013, 01:09 AM | #42 |
Rock Crawler Join Date: Apr 2011 Location: British Columbia
Make the links you need then see how it looks and go from there can't wait for my "pink" sliders mighty fine work your doing
04-02-2013, 01:12 AM | #43 |
*Ax10wannabe's build powered by bud* |
04-02-2013, 10:24 PM | #44 |
dont worry you'll get your pink sliders on sunday.. might even glue some pink tassles on em' too gonna half ass mock it up and get it rolling so i can take it to a crawl day on sunday just for a conversation piece.. haha |
04-06-2013, 04:56 PM | #45 |
got the chassis pretty much done and ready for tomorrow.. couple small things in the morning and i can run it |
04-06-2013, 07:07 PM | #46 |
Pebble Pounder Join Date: Dec 2008 Location: kingsland
looking great so far nice work
04-06-2013, 10:06 PM | #47 |
thanks chief its been a fun project so far.. has tested my patience in a few spots but thats when you set it down and walk away for a while then come back |
04-08-2013, 11:05 PM | #48 |
ran the chassis a tiny bit yesterday but the rear driveshaft kept popping off because the rear axle flops around cuz the lower links arent bolted on but should be able to get some material this week and make up a crapload of links... now that the chassis is basically done except for links and apparently theres no work for me this week im going to start on the sliders tomorrow, once that is done i can figure out how i want to mount the body. |
04-10-2013, 12:42 AM | #49 |
| Re: Ax10wannabe's attempt at an F350 crew cab |
04-10-2013, 04:36 AM | #50 |
Quarry Creeper Join Date: Nov 2012 Location: Michigan
Your doing some great work here. I would say chop some of the front frame. Can't wait to see the end results!
04-10-2013, 10:12 AM | #51 |
thanks man!!! got to thinking last night on how to mount the body.. im thinking i might just mark and drill some holes in the hood and bed and run the body posts.. it would be easier to get the body on and off the chassis... then if i decide to use some heavy duty velcro i can just fill in the holes and make it smooth again i also bolted on the grille last night and set it on the frame looks good... im going to leave the frame for now and see how it runs with the body on. |
04-10-2013, 06:08 PM | #52 |
took the chassis on the rocks this morning just before it rained.. phew.. it did good it needs weight in the wheels, soften up the foams a bit more, wear in the tires and shock adjustment/ rebuild...
04-10-2013, 10:06 PM | #53 |
added a few styrene strips and shoo goo on the inside for strength and i put the grille on last night, starting to look like a truck again!! |
04-11-2013, 08:15 PM | #54 |
yeah me too!! |
04-11-2013, 10:39 PM | #55 |
04-11-2013, 10:54 PM | #56 |
| Re: Ax10wannabe's attempt at an F350 crew cab rubbing won't be a big deal when your flopping it over checker or wrecker |
04-11-2013, 11:08 PM | #57 |
oh dont worry it will get the roll over and durability tests!!!! |
04-13-2013, 10:18 PM | #58 |
You need bed stacks for this fiddy |
04-14-2013, 07:07 PM | #59 |
yup it will get some |
04-20-2013, 09:58 PM | #60 |
not much updating becaue im just doing the boring and tetious job of the bodywork.. no point in taking pics of that.. gonna take it crawling on the rocks tomorrow, it did just fine on mine so im sure there wont be a problem.
Ax10wannabe's attempt at an F350 crew cab - Similar Threads | ||||
f350 crew cab | super pig | 1.9 Scale Rigs | 25 | 09-26-2011 10:55 PM |
f350 crew cab | lil wasted | Paint and Body | 0 | 07-26-2010 09:40 PM |
F350 crew cab | jetdog racing | 1.9 Scale Rigs | 9 | 06-06-2010 08:27 PM |
