02-23-2013, 11:08 AM | #1 |
Newbie Join Date: Jan 2013 Location: PA
| 6x6 drive shafts
Am in the process of building a 6x6 with scx10 axles and scx10 tranmission on a custom c channel chassis. What are some cheap driveshafts that can be modified to fit the axles and straight through axles to the third axl
02-23-2013, 03:46 PM | #2 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
| Re: 6x6 drive shafts
you could just use stock ones. there are a few ways to do it. i shortened a male shaft and glued a female shaft onto that. i have also drilled the center of a male shaft out and tapped it. inserted threaded rod into it, and then threaded another male shaft that i had cut off, drilled, and tapped. there are other ways to do it. maybe someone else will chime in. did ya try searching? edit, one other way is to use two female shafts and glue a male shaft into one of the female ends. Last edited by rik; 02-23-2013 at 03:48 PM. |
02-23-2013, 04:08 PM | #3 |
Driveshafts and a pass-thru axle are two different things. As was said, stockers chopped down for the small distance between the 2nd and 3rd axle work well.
6x6 drive shafts - Similar Threads | ||||
Creeper Drive Shafts/Stub Shafts | boog1313 | Venom Creeper | 3 | 04-23-2011 09:32 AM |
AX10 MIP C Drive dig drive shafts in stock! | RPP Hobby | RPP Hobby | 1 | 12-03-2009 10:50 PM |
