03-03-2013, 11:38 AM | #21 |
Quarry Creeper Join Date: Nov 2012 Location: Paxton
| Re: project Night Fury-a rock bouncer build.
ok guys i need some help here. i finally put some electronics on this thing. and i am getting a huge of amount of intereference from something. when i hit the steering and let it go, it will go all the way back and forth and maybe come back to center or maybe not. the ESC does the samething. it acts like i keep pulling the trigger then letting go and repeat. i tried 2 different radios and RX, samething happens. anyone have any help? |
03-03-2013, 07:43 PM | #22 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
Your servo needs a BEC.
03-03-2013, 09:56 PM | #23 |
| Re: project Night Fury-a rock bouncer build. |
03-03-2013, 11:19 PM | #24 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Does it do the same thing outside of the chassis? Is something (exposed wire) touching the chassis? Did you pull the red wire from the ESC with the BEC plugged into the receiver? Bad ass chassis BTW! Nice job on the welds. |
03-04-2013, 12:30 AM | #25 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
03-04-2013, 03:11 AM | #26 | |
| Re: project Night Fury-a rock bouncer build. Quote:
thank you. | |
03-04-2013, 11:29 PM | #27 |
My best advice is go through the electronics section and read read read and search search search. You're bound to find a similar issue with answers and/or advice. Also, google the crap out of the issue and add rccrawler and see what you find. You can also use the google custom search in the upper right corner of this screen to search the forum easier. I wish I had an answer for you. Maybe try a new bec or redo your connections and solders? I've found this advice valuable. Sometimes when you stare at something too hard for too long, you get blinders. Walk away...clear your head and then take a fresh look at it. More times than not, you'll find something you skipped over because you were concentrating too hard on one thing or the other. Case in point, I spent an hour looking for a cake pan (yes a cake pan) for my wife that was in the garage. I tore it upside down and couldn't find it. I thought it was in a certain place. After looking everywhere, I found it. It was literally right where I thought it was supposed to be, almost in plain sight...right behind the one box I didn't move. It doesn't help with your issue, but again I spent an hour looking for something that I could have found in less than a minute if I didn't loose my head getting distracted and frustrated. Last edited by Bulldog; 03-04-2013 at 11:39 PM. |
03-05-2013, 03:22 AM | #28 |
well i don't know if it anything to do with it. but i put a full charge in my battery and for some reason the servo quit glitching. but my ESC is still acting up. a buddy of mine ask if i switched it from "brushless" to "brushed" motor or not. so hopefully i'll get his castle link today to get that checked out. anybody think this could have anything to do with it? what exactly would this do?
03-05-2013, 05:29 AM | #29 | |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
03-05-2013, 07:43 PM | #30 |
it must be the fact that the battery was low on voltage causing the servo to act up. and apparently since i didn't check my speed control before trying it out, it was still on brushless motor setting. after switching it to brushed motor everything seems to work just fine. i put my honcho tires and wheels on it and got some pics, don't mind the wires obviously they will get tied back better at final assembly. not much flex, who needs flex when you got bounce. right? ground clearance |
03-06-2013, 02:04 AM | #31 |
Sounds like you figured it out. Again....Most problems are solved in the easiest way possible....yet we kill ourselves trying to figure them out. Glad you're up and running and some good info for anyone reading. |
03-06-2013, 04:44 PM | #32 |
i drove it around alittle today at work, seems to work just fine. it's time to tear it back down to chassis and finish welding supension tabs. then start on body panels.
03-12-2013, 06:41 PM | #33 |
little update, sorry no pics. i have started on the body panels. have to admit probably the hardest part of the build so far. the side panels are a huge PITA trying to get them in one piece, but i have one side done already. once i get the other side done i will get mounting tabs welded on then it's time for powder coat and final assembly. |
03-14-2013, 08:06 PM | #34 |
i have my body panels all finished up. they're not all mounted yet but here's what they look like. |
03-15-2013, 12:49 AM | #35 |
Body panels look good! I still can't believe how small that chassis is! |
03-15-2013, 03:03 AM | #36 |
03-19-2013, 08:05 PM | #37 |
i got all my body panels done and mounted. now it's time for powder coat. |
03-20-2013, 11:04 PM | #38 |
Eating popcorn...! |
03-21-2013, 12:23 PM | #39 |
I wanna be Dave Join Date: Jun 2007 Location: Arlington wa
wow.... this thing looks killer! the panels look great on there! color choice??
03-21-2013, 08:32 PM | #40 |
project Night Fury-a rock bouncer build. - Similar Threads | ||||
Fat Girl 2.2 scale rock bouncer | ecoli | 2.2 Scale Rigs | 350 | 08-24-2013 08:21 AM |
Caged Fury Rock Run | Xtremekrawler8 | Tamiya Clod Buster | 0 | 03-07-2005 09:29 AM |
