04-29-2013, 02:27 AM | #41 |
Pebble Pounder Join Date: Aug 2011 Location: Holland
| Re: Old comp truck turned scale truck (the rebuild, AGAIN!)
Speachless m8! What a skill.
04-30-2013, 10:24 PM | #42 | |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
| Re: Old comp truck turned scale truck (the rebuild, AGAIN!) Quote:
I was actually thinking the same thing about the springs. I hoping they hold up for at least the season. I'll keep the thread updated as the season goes on. Thanks! I forgot to show this in the last post but here is the fit if the inside of the fenders with the new wheel wells. With the bed done i made up some new panels for the rest of the body. the nice thing about the new chassis set-up with the separate bed, is that it now allows me to assemble the cab corners, back and roof as one piece before i install it. much easier than the old method where i had to glue everything together on the chassis. then i added fitted the panels to the chassis then threw on the spare mount and tool box. then it was time to add the lites. to do that i simply glued the LED's to the inside of the lite bucket And fed the wires through the access in the floor that keeps the inside of the bed nice and clean The last thing i wanted to address was the skid. I never put kick-ups on it and it would catch stuff all the time. to i made up some plates and tacked them in place then TIG'd them solid. My welds are getting better. Here is a comparison to show just how small they are With the chassis done it was blasting then paint. I went with something different, a light gray. next it was running gear and interior Then it was time for paint on the body. I wanted to try a new Rustoleum paint. it's a metallic gunmetal gray with primer in it. the paint came out nice but for those that might want to use it, The "primer" effect does not work. you need to primer the surface first. also it comes out real heavy and fast but i had no runs. Also, the finish ends up dull, even though it says glossy, so i put a clear over it. Finally it was time to assemble it. It looks neat with the bed off Here is a shot of the back of the cab since once the bed is on it won't be seen Now to hook up the rear lites I used a small Losi micro connector. And here is it minus the lite lenses I didn't show this before but here is the profile of the leaf springs. they tuck up nicely for a smooth belly I also added rear shackle mounts That pretty much gets the build up to date. I ran it at a comp this past weekend and did pretty good finishing 2nd. I'll post up some comp pics later. | |
04-30-2013, 11:13 PM | #43 |
Pebble Pounder Join Date: Apr 2011 Location: wenatchee
WOW!!! That is awesome! How well does it hold up?
05-01-2013, 12:16 AM | #44 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
well as if the build couldnt get any better....... holy crap nice work man those new molds look 100 times better than the bondo ones too nice and clean and looks a little smoother too.. everytime i come and check out one of your threads it makes me wish how i could have a longer attention span and patience.:mrgreen i would ask how many hours you have into this rebuild but i probably dont wanna know |
05-01-2013, 01:45 AM | #45 |
Rock Stacker Join Date: Nov 2004 Location: Omaha
WOW. I just have to say im totally blow away by your fab work. Looks great! Question for you however, where do you get the .006 sheet metal from and what do you use to glue the panels together?
05-01-2013, 07:01 AM | #46 |
Pebble Pounder Join Date: Oct 2007 Location: Ohio
Masher just amazing . I watched your first one on scale. All I can say is your the man! |
05-01-2013, 11:41 AM | #47 |
Always some of my favorite builds. Great update to the truck.
05-01-2013, 11:54 AM | #48 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
Looks great man. always liked your other builds. Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
05-01-2013, 09:37 PM | #49 |
Pebble Pounder Join Date: Feb 2011 Location: .
Man that was a quick rebuild. Such great work on everything, a level of skill that is amazing |
05-01-2013, 10:40 PM | #50 | |
Pure Metal Tooling Foil - BLICK art materials | |
05-02-2013, 05:12 AM | #51 | |||||
| Re: Old comp truck turned scale truck (the rebuild, AGAIN!) Pretty good, you'll see in the pics below. Quote:
I don't know exactly how many hours but it's probably around 80. Quote:
Well i got the lenses on and got some nice outdoor shots at the comp this past weekend then the carnage began during the second course. Then as i began the third course, the tranny went out. After i fixed it i managed to finish the course with a bit more carnage After the comp i did some playing around then i took a bit of a tumble! I easily fixed the damage and proceeded to add some more! In all i was extremely happy with the truck. it performed better than i hoped and the damage was exactly as i expected. I have another comp this weekend so we'll see how it does there. | |||||
05-02-2013, 08:00 AM | #52 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Great rebuild! I can't wait to get some video of it in PA! |
05-06-2013, 08:46 PM | #53 |
| Re: Old comp truck turned scale truck (the rebuild, AGAIN!) Don't worry, you will. it'll be nice and strait in August though as this body will be thoroughly beat by then! Well, last week i was playing around and added some more character to the body by getting a little friendly with a rock then i flopped it on the passenger side But it was quickly fixed and i was on my way |
05-06-2013, 11:26 PM | #54 |
body is looking good with all the damage!!! i watched your videos on youtube of the comp and i noticed that it has quiet a bit of torque twist and that you could have made some of those sidehills, is it just because of the leaf springs??
05-08-2013, 09:06 PM | #55 | |
I got some more pics from the comp at Rausch Creek. these were taken by a professional photographer and came out amazing! You can see his stuff here: jkolvaphotography's Photos On to the pics! and some playing around shots | |
05-08-2013, 10:35 PM | #56 |
Rock Crawler Join Date: Feb 2007 Location: Peoria, Arizona
Awesome as always!
05-11-2013, 06:23 AM | #57 |
Truck looks great! How do you like those clocked c`s did you get any more steering angle ?
05-11-2013, 04:02 PM | #58 |
| Re: Old comp truck turned scale truck (the rebuild, AGAIN!) |
05-11-2013, 04:23 PM | #59 |
Rock Crawler Join Date: Feb 2013 Location: Casper
Just great work man. I love the realistic damage. I'll looking to do something similar with my wraith. Use a metal type material for the panels. A++ for realistic damage. J. |
05-14-2013, 08:01 PM | #60 | |||
| Re: Old comp truck turned scale truck (the rebuild, AGAIN!) Thanks! Quote:
Well as BigSki mentioned i did some more bashing the other weekend trail riding with the club. I'll just let the pics do the talking The nice thing about the metal is after a full day of bashing it only takes a few minutes to put it back into shape! | |||
Old comp truck turned scale truck (the rebuild, AGAIN!) - Similar Threads | ||||
Class 3 Yota scaler (another comp truck rebuild) | Metal Masher | 2.2 Scale Rigs | 22 | 05-11-2014 09:24 PM |
old comp truck turned scale truck (the rebuild!) | Metal Masher | 1.9 Scale Rigs | 32 | 01-02-2013 01:23 AM |
old comp truck turned scale truck | Metal Masher | 1.9 Scale Rigs | 50 | 04-22-2011 01:16 PM |
WCC Comp Truck Rebuild | Chris_The_Battery_Man | General Crawlers | 21 | 06-07-2009 12:43 AM |
