03-23-2013, 07:06 PM | #21 |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
| Re: D90 class 1. by mjderstine
YELLOW????? JK..........Looks good bro But, Wheres the Driver? Video Please........... Regards, Rick |
03-23-2013, 07:09 PM | #22 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
I think you have a problem. Just like the rest of us |
03-23-2013, 08:26 PM | #23 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
its gonna look like this when the scale stuff is done. and yes it needs a driver. but its ready for a test drive tomorrow. should be good enough. but man these hard bodies are NOT light. yes, bart, i have a problem. a big one. i have the deuce, F-Toy, M-715, D90, and a Mog. 3 run. two are being built... all need more scale goodies. |
03-24-2013, 11:12 AM | #24 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
Nice work MJ. You've got alot more progress to show at the moment. Nice work with the battery tray.
03-24-2013, 05:11 PM | #25 |
thanks man. i had the first failure today. the drive line from the tranny to the t-case stripped, i only got to drive it for about 10 minutes. but it was fun. need ot dial back the drag brake too. and get shorter shocks. maybe only 80mm front and back.
03-31-2013, 04:15 PM | #26 |
got the new drive shafts in. mega truck axle for the power line from tranny to t-case. and some MIP no name thingys that i had to trim down. messed up on that though, and had to braze them back together, just hoping that is strong enough to hold up. thanks axialjeepster. they are def a good deal. |
05-04-2013, 01:02 PM | #27 |
well since everyone is so interested in this thread-o-mine, i figured i'd post up my headlight progress. got some cheap Cree led flash lights from ebay. about $6 each, and like 300 lumens. super bright little thing. so i just took the led assembly off, filled down the tactical bumps on the end, and using some E6000 to attach to the body. they should be about as bright as you can get on an rc truck. i was gonna just use the led assembly, but they creat some heat and i wanted the clunkier part of the flashlight in there to act as a heat sink and also protect the thing from the elements. this thing will have to be going through some completely submerged obstacles at our upcoming even over at VAscaler.com VA-Scaler hosting 1st Camel Trophy Team Challenge June 1st, 2013 here are a couple pics of the things getting glued in. exciting stuff isnt it! |
05-04-2013, 11:40 PM | #28 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
Please do a how to on the wiring on the headlights, what's removed, sanded, ect. I have some premium LEDs flashlights that I want to use but don't understand how to wire, where to solder ect so they work right. Thanks.... |
05-05-2013, 10:14 AM | #29 | |
| Re: D90 class 1. by mjderstine Quote:
will have something posted up a little later. | |
05-05-2013, 11:12 AM | #30 |
Pebble Pounder Join Date: Jun 2012 Location: Lucerne Valley
| Re: D90 class 1. by mjderstine |
05-05-2013, 01:28 PM | #31 |
ok, so here is the how to. its pretty simple man. so dont get scared of it. if you can do some simple soldering you should be fine. on my led the inner circle is the postive, and the outer brass circle is the negative. should be the same on just about all CREE leds. take the solder iron and tin a small part of the brass on the positive and negative. also tin the wire you are using. then just solder them together. the other side is a little bit trickier only because you soldering 4 wires onto one led. tin 4 spots on the led, and solder the wires from the first led to the correct spots. then solder the power supply wires on. they just get plugged into a battery. the battery is the cool part, at least i think so. these cree leds are designed for a single cell lipo. so just use an old cell phone battery. solder on a plug and switch and away you go. you can now charge the cell phone battery with your charger too. cell phone batteries can be had on ebay for about $7 shipped. |
05-05-2013, 01:42 PM | #32 |
Thanks I going to break mine out and see what them look like. Isn't there a way to add a resister so that you can just link into the reciever?
05-05-2013, 02:09 PM | #33 |
Very cool ... Have you tried it out yet?
05-05-2013, 02:24 PM | #34 |
you def could man. i dont usually get into the resistor stuff though. this is just as easy for me.
05-05-2013, 02:24 PM | #35 |
05-05-2013, 02:43 PM | #36 |
05-05-2013, 02:45 PM | #37 |
DAMMMMMM I had to break out my sun glasses Regards Rick |
05-05-2013, 08:25 PM | #38 |
| Re: D90 class 1. by mjderstine WOW thats bright. Great idea, looking at picking a couple up... Thanks for the pics... |
05-05-2013, 09:05 PM | #39 |
05-05-2013, 09:40 PM | #40 |
| Re: D90 class 1. by mjderstine I like it.... |
D90 class 1. by mjderstine - Similar Threads | ||||
USRCCA Class 1 - Super Class - Cut N Shut Tire Catalog | Nova's Ark | Crawler Innovations | 32 | 01-29-2023 05:10 AM |
BYB by MJDerstine (with good video) | mjderstine | Kyosho Crawlers | 76 | 07-30-2013 07:23 PM |
How To: Aluminum Body Panels by mjderstine | mjderstine | Paint and Body | 6 | 05-01-2012 07:50 AM |
