10-18-2006, 12:44 AM | #61 |
Newbie Join Date: Sep 2005 Location: Melbourne, Australia
Oh yeah sorry, the color is the Tamiya light gunmetal, its much lighter in RL, photo was taken in low light with a flash. I dont like the color Looks better than blue with red wheels though!
10-20-2006, 04:39 AM | #62 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Tip # 62 - Body lift Here's a simple body lift, unscrew the metal L-brackets that the cab scews into & place them above the spot you just removed it from. Face the L-bracket up. For the bed you just need a spacer about an inch. For added stregnth, drill another hole for the bed mounts & use 2 spacers per side. The side steps will need to be removed & the standoff trimmed or raised. |
10-22-2006, 11:59 PM | #63 |
Official Scale Nazi Join Date: Sep 2004 Location: Monticello, IL
Great write-up in RCD Jason! I'm sure that it will help alot of people decide to buy this thing.
10-23-2006, 11:28 AM | #64 | |
RCC Addict Join Date: Feb 2006 Location: UrAnUs
might add lil metallic | |
11-08-2006, 08:48 PM | #65 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
Has anyone discovered better tire option. I need a little better traction for all around trail riding. I dont want to fit MOABs they are too big and awkward. I tried the stock TLT tires and rims and remembered why I got rid of them in the first place.
11-11-2006, 12:29 AM | #66 | |
11-11-2006, 01:36 AM | #67 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
I narrowed Geos and took out a section of tread to reduce the tire so it'd fit a 1.9 rim. They're just a tad shorter than regular Geos and there's no huge 2.2 wheel crammed in them. | |
11-11-2006, 02:43 PM | #68 | |
11-12-2006, 01:43 PM | #69 |
Rock Stacker Join Date: Apr 2006 Location: Thomaston
what might be a good radio to use on theis beast. i was thinking thetq3 but im not sure how that would do shifting wise. im looking for something in the 110.00 and under price range |
11-12-2006, 03:42 PM | #70 |
RCC Addict Join Date: May 2006 Location: Roseville
It would work, but you would have to change the switch from a two-position to a three-position. Also, you would have to play around with the mechanical linkadge to make everything work properly. The how is up to you. |
11-12-2006, 03:50 PM | #71 | |
Also, I put the coil springs back in the rear shocks. After about a month, the back end started to sag. | |
11-12-2006, 07:55 PM | #72 |
for my final question, what radio, is everyone else using, cuz ui dont have time or expierients to do andthing electrical |
11-12-2006, 08:02 PM | #73 |
Anything with a 3 position 3rd channel should work. Spektrum has been the most popular choice from what I've seen. I had a 8 channel I got from my uncle but it was too hard to program and use that radio.
11-12-2006, 08:26 PM | #74 |
JR R-1 Pro |
11-12-2006, 09:09 PM | #75 | |
11-13-2006, 02:11 PM | #76 |
| hope this pic works, but i was thinking abotn something like this but how do u shift with the little thing on the top
11-13-2006, 02:12 PM | #77 |
pretty sure pics didnt work so heres the link http://www2.gpmd.com/image/t/towj41.jpg |
11-13-2006, 03:22 PM | #78 |
Neither of those work. And your signature needs to be smaller.
11-17-2006, 09:21 PM | #79 |
Rock Crawler Join Date: Nov 2004 Location: Lost in Florida
will this setup work? novak xrs / trinity 4200 zap pack / Futaba S3010 (shifting) / Airtronics 94358Z is there a more eco friendly set up....like do i really need a 200oz servo in this thing? and is there a cheaper servo to use for shifting...and do i need 90oz of torque for that?....thanks btw i am asking this because i am about to order my high lift and all the requirements.... Thanks again |
11-19-2006, 07:46 PM | #80 |
Maxx shocks will fit the factory mounting hardware, and give you more downtravel. Oil leakage isn't any worse than the grease leakage I use a 3003 standard servo for shifting, and a 90 ouncer for steering. No worries with either one. |
