03-05-2008, 07:13 AM | #101 | |
Rock Stacker Join Date: Aug 2007 Location: Kingston
They make dremels everyday! Grind off the end of the hex. | |
03-05-2008, 03:24 PM | #102 |
Newbie Join Date: Feb 2008 Location: south africa
hi there, i am from south africa and i have recently bought my self a toyota high lift and find the leaf springs a little hard, not giving enouth articulation. trying to do a 4 link set up but dont know how to secure every thing. any idears would be gr8. thanks Andrew
03-06-2008, 12:32 AM | #103 |
Rock Crawler Join Date: Jan 2008 Location: Jonesboro, Arkansas
I GOT MY HIGHLIFT BUILT, EVRY THING TO MY SPECS, THE ONLY THING IS, I CANT DRIVE IT:-( I NEED A RADIO-WHAT IS THE BEST RADIO-WHAT IS A SHIFT GATE-PLEASE HELP ME GET THE PERFECT RADIO SET UP FOR MY HIGHLIFT- AND NO IT WILL NOT HAVE REAR STEER. SITES WHERE I CAN GET A RADIO WILL HELP A LOT |
03-06-2008, 10:28 AM | #104 | |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
you can find it right here this is a shift gate from RC4WD.COM, I tried to obtain one but unfortunately they are sold out, I emailed customer support and they said they dont know when there will be more available, I made my own out of the plastic from a DVD case, it works good, but not as pretty as the aluminum you can find the shift gate right here | |
03-06-2008, 10:33 AM | #105 | |
03-06-2008, 12:48 PM | #106 |
03-06-2008, 01:10 PM | #107 |
| I AM RUNNING THE ROOSTER CRAWLER SPEEDCONTROL. HAD IT ALL READY. CH 4 IS SHFTING AND THAT IS DONE HOW EXACTLY. SORRY, THIS IS MY FIRST HIGHLIFT AND FIRST RC WITH SOMETHING MORE COMPLICATED THAN THE TQ3, I JUST DONT WANT MESS UP THE HIGHLIFT.:-(
03-06-2008, 11:45 PM | #108 |
| Ive heard those roosters are pretty bada$$. The only reason i know this stuff is because i just built a highlift hilux and I figured it all out by asking people on this forum, so dont worry about it. shifting is done with the left stick. Left is highway, middle is 2nd gear, and right is low. you just move the stick to the side or keep it in the middle and move it forward to accelerate once you are in gear. the shift-gate helps you to not switch gears once you are accelerating because its bad for the tranny
03-07-2008, 12:05 AM | #109 | |
03-08-2008, 04:41 PM | #110 |
I RECENTLY PURCHASED THIS HIGH LIFT USED AND GOT IT ALL BACK TOGETHER WITH THE PARTS SUPPLIED BY THE SELLER, BUT I HAVE A FEW QUESTIONS I HOPE SOMEONE CAN HELP ME WITH. DAN ANYONE TELL ME WHY MY HIGH LIFT SITS SO HIGH, WHAT DO I NEED TO GET IT BACK DOWN SO THE 1.9 TIRES LOOK SCALE AGAIN AND IF I NEED TO BUY SOMETHING FOR THIS, WHERE CAN I BUY IT. ANY HELP WOULD BE GREATLY APPRECIATED. |
03-17-2008, 03:30 AM | #111 |
Newbie Join Date: Mar 2008 Location: clifton heights
what is the most flex you guys are getting with the leafs?
04-06-2008, 05:34 AM | #112 |
Newbie Join Date: May 2006 Location: vancuver island B/C
| ground clearence
is there any way to get better ground clearence from the high lift?
05-05-2008, 10:31 AM | #113 |
Pebble Pounder Join Date: Oct 2006 Location: Mt. Enterprise
hmm this is wierd....for some reason i cant see the pictures on the very front page...anyone else having this problem? i can see all the others though....
05-19-2008, 08:33 AM | #114 |
Rock Crawler Join Date: Jan 2005 Location: Windsor, VA
Broke a leaf spring this weekend, so I guess I will be 4-linking one end of my highlift based blazer. gonna link the rear and leave the leafs up front. Any pictures of where you guys mounted your links? |
06-19-2008, 05:05 PM | #115 |
Newbie Join Date: Jul 2007 Location: Finland
Hello! Im working on a 4linked Highlift and a was wondering, do anyone have .pdf for servomount? |
09-07-2008, 08:37 AM | #116 |
Newbie Join Date: Jul 2008 Location: Sioux Falls, SD
i just got a f350 and was wondering whats the best lengths to use for the 4 link setup, and i only have one leaf up front and have no flex at all
10-14-2008, 10:39 AM | #117 |
Quarry Creeper Join Date: Sep 2008 Location: Petaluma
| f350 4 link
I looked for a 4 link system for my high lift also - cuz the stock leafs don't do much in the way of flex. I saw someone taper the top of the leaf spring (where it attaches to the bolt on the frame) and that gave it a bit more play. I'm currently converting the rear to a 4 link system but its taking time to create the right look thats functional too. I had to grind down the fins on the inner axel to fit the 4 link plate I'm designing. I haven't made the supporting rods yet but after checking around - I found I'll have to make them on my own. I'll try and keep you posted on the progress after here. |
10-14-2008, 11:06 AM | #118 | |
http://www.rccrawler.com/forum/showp...99&postcount=1 | |
10-14-2008, 10:28 PM | #119 |
Wow - that's beautiful - but I don't think those will bolt up to the f350 high lift. The drive train looks different. Here's the update to the metal project. BTW - it was made from a decking bracket - galvanized steel - very sturdy. I used the bed brackets for the right and left swing arm and i will probably fabricate a center bracket. All will bolt on to the existing skid plate. Not sure what I'll do about remounting the truck bed but will worry bout that much later. I'll have to file down the screws but at least it doesn't require a nut ont he end. The screws mount directly into the threaded bracket. Now that its essentially mounted. I'll work on the rods and then after they are measured and cut - will reduce the size of the bracket and then drill a few "cool" holes - add paint and should be done in about a month! |
10-15-2008, 07:43 AM | #120 |
| , did you search in the thread i gave you? and my comment also said i owned a set of those for my hi lift, don't get me wrong i applaud your effort and building abilty, but i just want to make sure people also know there are already made pieces for their hi lift. http://www.rccrawler.com/forum/showp...&postcount=145 |
