09-30-2006, 12:53 PM | #41 |
Quarry Creeper Join Date: May 2005 Location: Newton
lookin good. Can't wait till I have enough money to get me one.
09-30-2006, 06:33 PM | #42 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Wow, you had your's since Jan.'99. lucky bastard. |
09-30-2006, 06:46 PM | #43 |
You're busted, Diaz! Now we know your secret! You've got a fargin' time machine! |
09-30-2006, 07:56 PM | #44 |
If the shackles were on the rear (of the front axle), would there be enough driveshaft travel to allow it to shorten? If the wheelbase was a bit longer it would work, but I know my shafts are bottomed out when the rig is at full droop. Excellent idea for a smoother ride though. |
10-01-2006, 12:07 AM | #45 |
I joined the Band! Join Date: Mar 2006 Location: Gardena,Ca.
on the next chassis that i make , it will have the option to run the front shackle mounted towards the middle of the chassis.i think that i will make it so that i can run dual shocks up front also. and i will soften the chassis lines also. give it some curves |
10-01-2006, 12:48 AM | #46 |
Rock Crawler Join Date: Nov 2005 Location: dallas
Shackles on the rear of the front axle would be more scale
10-02-2006, 09:01 AM | #47 |
some more shots. thought i'd try some tranny options too. i'm getting ready to make another chassis with the changes i want. get rid of some holes and male it alittle curvy Last edited by ddiaz10240; 10-02-2006 at 09:06 AM. |
10-02-2006, 09:01 PM | #48 |
Quarry Creeper Join Date: Aug 2005 Location: Lake Mary
I honestly dont know why they didnt make the shackels on the front of the axle on the back of the leafs, Less chance of bending the leafs if you hit a bump probably more flex under a climbing load. The only reason they put the shackels up front on the front axle on 1:1 rigs is because if they are on the back of the leafs when the breaks are applyed the front end dives because the axle pulls backwards causing the shackle to buckle, the down side is a stiffer ride though. Wheel base can also make a difference too. |
10-03-2006, 06:58 PM | #49 |
i made some crossmembers out of 1/4" alum. need to drill and tap for screws. i also made another frame with the holes for the shackles reversed
10-03-2006, 07:13 PM | #50 | |
Newbie Join Date: Oct 2006 Location: Elkhart
10-03-2006, 07:33 PM | #51 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Good...send me one. | |
10-03-2006, 07:57 PM | #52 |
I'm holding out for the all-alloy curvy version. That's gonna be just what this truck needs.
10-03-2006, 08:01 PM | #53 |
T-case is low enough. |
10-04-2006, 10:13 AM | #54 |
RCC Addict Join Date: May 2006 Location: Roseville
Man, that is sexy...
10-04-2006, 10:31 AM | #55 | |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
10-04-2006, 05:43 PM | #56 |
well i tried to changed it up a bit. i think my bearings came in today so i will put everything together tonight. i also made another frame with some curves added. i also added dual shock mounts up front. let me know what you guys think? i know i'm going to change the design again
10-04-2006, 05:45 PM | #57 |
I like where this is going. What about fourlink mounts on the lower portion?
10-04-2006, 06:14 PM | #58 |
RCC Addict Join Date: Sep 2005 Location: Beaver County, PA
looking good. More curves to come Im sure. How about dual shock mounts front and rear?
10-04-2006, 06:24 PM | #59 |
Hey Diaz, Looks good. You can send me one of those straight ones now that you don't need them anymore.
10-05-2006, 11:57 AM | #60 |
Quarry Creeper Join Date: Aug 2005 Location: newport
Oh man, now that curved version is looking HOT |
