12-10-2014, 05:56 AM | #81 |
Quarry Creeper Join Date: Sep 2012 Location: Connecticut, USA
| Re: china 2dr jeep body awesomeness !!! ?
Awesome Build! I just picked up one of these bodies the other day, and I'm totally in love with it. I really want to paint it, but it looks really sharp the way it is too...(if you don't mind Yellow) Its so much better than the New Bright!!! (I'm working on one of those right now too) I love how you did the tube doors, that's sick! I don't know how to weld or have the equipment, so I'll be using the Axial Rubicon roll cage. I got it fitted last night and it needs modification, but fits really well with the top on or off! Plenty durable enough too! I'll have a Build thread soon too.
05-19-2016, 01:05 PM | #82 |
Newbie Join Date: Nov 2015 Location: Houston
Awesome work man. 2 questions... How did you end up cutting the fender flares, they look nice. And how did you mount the body? |
05-23-2016, 10:26 AM | #83 |
Rock Crawler Join Date: Nov 2011 Location: Kamloops
Well id say i would show you some pictures but pboto bucket sh!t the bed and cant access them any more . I took some sheet metal and built a couple angle sections that screw through the back and to the frame . That was in the back an the front i did the same i welded some 3mm nuts to the front of the servo bracket and screwed them in that way . Sadly this is probably in the same state as the last picture . I have built several rigs since i started this one . It will get finished but not until i build my k5 rc4wd blazer I just got . Thanks for digging up an old thread and bringing back some memories. Cheers Ehh
05-02-2017, 09:06 AM | #84 |
Newbie Join Date: Jul 2012 Location: Madisonville
I am currently looking for options for a similar build. I was wondering what transfer case you used and how you mounted it? I've thought about going with the GCM J2 Skeleton Chassis but would like to use an old SCX10 chassis if I could. Also, I will be using SCX10-2 axles. |
05-02-2017, 02:06 PM | #85 | |
Newbie Join Date: Mar 2017 Location: Central Jersey
| Re: china 2dr jeep body awesomeness !!! ? Quote:
From what I've seen, front motor mount and low profile transfer case is the way to go. But i'm debating the route I want to go. I don't have the skills alot of these guys do, so I'm probably going to go the easiest route. | |
05-03-2017, 12:45 AM | #86 |
Front motor mount is the only way if you don't want to hack up the interior. GCM Also makes a SCX10 front motor mount and tcase setup which I used on a old 2dr build I had. Look at my created threads for the build. |
china 2dr jeep body awesomeness !!! ? - Similar Threads | ||||
Proline Jeep JK 2dr | wxgs333 | Axial SCX-10 | 21 | 04-18-2011 09:38 PM |
