10-01-2013, 09:56 PM | #1 |
Pebble Pounder Join Date: Sep 2010 Location: Santee
| myth619's spare parts TJ build
I recently got bit by the TJ bug so with the help from my friend Shinjari I got an unmolested New Bright TJ body. He also set me up with a slightly modified SCX10 chassis to get going with. I started with: Axial axels Axial Trans Axial Wheels and Bead Locks A few sets of Flatirons Axial and Proline shocks & springs Some 98mm Axial aluminum links Some misc traxxas rod ends and a few drive shafts that I hoped would work. With the plan being to build a stretched and comp cut TJ, I used the sewing thread method to cut the fender flairs off. Started imagining the wheels base while waiting for a frame Got a frame and mocked up how high/low the body will sit. I wanted to keep the body a low to the frame as possible and found that it wasn't going to happen with the trans in the stock location so a GCM transfer case was procured from Shinjari ( youll begin to see a reoccurring theme with where a lot of my parts come from) and mounted it to the stock SCX10 center skid. There ended up being about a 1/4" clearance between the case and the body. NO FLOOR CUTTING Assembled the links to see how much needed to be cut . Rear links done With how the way the frame was modified by two previous owners ago I had to move the center skid forward one set of holes and drill a new hole for the front upper link mount otherwise the links would have been an inch long or the rear axel would have been at the rear bumper. Last edited by myth619; 10-02-2013 at 06:15 PM. |
10-01-2013, 10:06 PM | #2 |
| Re: myth619's spare parts TJ build |
10-01-2013, 10:15 PM | #3 |
10-01-2013, 10:23 PM | #4 |
While cycling the front suspension during the mock up phase I wasn't happy with the amount of up travel it had. I did a few well placed pie cut to frame in front of the shock mounts and was able to raise the rails about 3/8" which allowed the drag link and track bar to clear the frame at full compression and articulation. You can see the before and after in these pics before: after: |
10-01-2013, 10:30 PM | #5 |
10-01-2013, 11:12 PM | #6 |
10-01-2013, 11:14 PM | #7 |
That's it for now, more tomorrow
10-02-2013, 02:02 AM | #8 |
Quarry Creeper Join Date: Apr 2009 Location: Lynnwood
Nice work! I have the same body hanging in my garage, been there for quite a while now! But hopefully tomorrow I get some parts in the mail to put it to use.
10-02-2013, 01:39 PM | #9 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Front tranny mount is sick! Can I copy that? |
10-02-2013, 02:58 PM | #10 |
Quarry Creeper Join Date: Feb 2008 Location: Quincy
10-02-2013, 06:06 PM | #11 |
| Re: myth619's spare parts TJ build Thanks, copy away. Thanks. If I push straight down on the front of the frame the front shocks have a little more than an 1/8" left to compress when the steering components hit the frame. When it articulates the shocks will get full compression. The tire will hit the fender before that happens though. I may do a HiLine fender on it before its done. Last edited by myth619; 10-02-2013 at 06:19 PM. |
10-02-2013, 06:28 PM | #12 |
Boat side time.... I just bent some sheet metal and welded it to the frame. They also serve as the body mounts. Along with the boatsides, the rock sliders will mount them and pinch the body between them. The two middle hole will mount the slider to the body and the two end holes will mount the body to the boatsides. |
10-02-2013, 06:39 PM | #13 |
10-02-2013, 06:47 PM | #14 |
More Cage I did the small front window bars and the grab handles from a variety pack of music strings that can be bought at Lowes. They come in 6in pieces of various diameters. They can be found in the nut and bolt section under Hobby Parts( I think that's what its called) If I decide to run a spare tire Ill incorporate the mount off the back of the cage and tie it into a rear bumper of some kind. Last edited by myth619; 10-02-2013 at 06:54 PM. |
10-02-2013, 06:50 PM | #15 |
That's all the pics for now and Im caught up on the build. If there are any questions about what I did that I didn't go over let me know. Hopefully tonight I can get the front bumper/ winch mount done and some more pics posted. Thanks for looking! |
10-02-2013, 06:55 PM | #16 |
10-02-2013, 09:30 PM | #17 |
Rock Crawler Join Date: Apr 2011 Location: SD
What's up myth, have you been crawling with the guys up in temecula? Rig looks good. I'm working on a similar build, a YJ, but I have to wait until I can get my tube work done, as I have no welding skills |
10-02-2013, 11:24 PM | #18 | |
| Re: myth619's spare parts TJ build Quote:
Im really happy with how this TJ is coming along. Im taking my time on it, mainly because I don't have an instant budget to buy what I need so I can take my time on building the extras. Are you doing a build thread on your YJ? | |
10-02-2013, 11:42 PM | #19 |
Got a good start on the front bumper..... Mocked this one up with some card board Bending the bumper up! All bent up Aaaaaand, test fit Welding and shaping the corners Grill Hoop Stinger Seeing how it looks. I still have to do some reinforcing tubes from the top of the stinger to the grill hoop to keep the stinger from bending when the rig goes over. Im also going to do a Haas style fairlead so I need to do that mount too. |
10-03-2013, 09:18 AM | #20 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Great job on the TJ. I love these little Jeeps! Super fun to drive and the scale aspect is just awesome. I dig the front bumper for sure. What's the plan for the rear bumper?
myth619's spare parts TJ build - Similar Threads | ||||
Myth619's Chero Build | myth619 | 1.9 Scale Rigs | 3 | 04-12-2012 08:35 PM |
Spare Parts Build | thzero | Illinois | 9 | 12-16-2011 09:27 PM |
...spare parts build... | Leprasol | Axial SCX-10 | 14 | 05-25-2011 08:45 PM |
Spare parts build | max power | Non Crawler RC's | 5 | 10-28-2008 01:38 PM |
Spare parts build.... | ddiaz10240 | 1.9 Scale Rigs | 1 | 08-26-2008 11:30 PM |
