01-01-2014, 12:22 AM | #1 |
Quarry Creeper Join Date: Mar 2011 Location: over there...
| bronc's 2014 class2 rig..yota truggy
HAPPY NEW YEAR! so here is the old 1.9 never did a build thread on it wish i did so hears the start of this new one .. old layout she served me well Last edited by bronc4now; 01-01-2014 at 01:10 AM. |
01-01-2014, 12:47 AM | #2 |
Newbie Join Date: Jul 2013 Location: LaSalle
| Re: bronc's 2014 class2 rig..yota truggy
Are those the t Rex 60's?
01-01-2014, 12:48 AM | #3 |
ok so im tearing her down and doing a full rebuild new motor bearings rod ends bahbahbah... but most important a new body and cage work ok so most parts will carry over and ill just go over those as i go 1st the body work. tamiya hilux cab tamiya hilux front grill reign rear panel with window rc4wd clear window bam pinched front Last edited by bronc4now; 01-01-2014 at 12:55 AM. |
01-01-2014, 12:49 AM | #4 |
| Re: bronc's 2014 class2 rig..yota truggy |
01-01-2014, 12:51 AM | #5 |
01-01-2014, 01:01 AM | #6 |
01-01-2014, 01:04 AM | #7 |
01-01-2014, 04:31 AM | #8 |
Newbie Join Date: Nov 2013 Location: froze a×÷ NE OH
The curries are based off dana 60s its just a currie made case with the cover rotated up to keep from bashing the covers on rocks, internally its a dana 60 thou
01-04-2014, 07:38 PM | #9 |
ok so my yota wont have a toyota drive line or power plant so why should the dash be right ? my buddy made this chevy dash for his c10 he had extras so why not looks killer in there ..the original was made from all styrene this is a copy from the of original made in a mold ... Last edited by bronc4now; 01-04-2014 at 07:43 PM. |
01-04-2014, 10:14 PM | #10 |
dang I need one of those! |
01-05-2014, 05:15 PM | #11 |
Rock Crawler Join Date: May 2007 Location: floriduh
Sweet!!! I need one of those dashes!!!!!! |
01-12-2014, 08:15 PM | #12 |
update ... rebuilt axles w/ gripfab lockers overdrive front std rear hd gears ,vp cvd's ,shocks and trans w/ axial hd gear set with a new 27t hh motor .. some more body work and still more to come i hate preping a car for paint its just like a 1:1 it all shows luckly this is a ttc truck not a show truck i need to get a chassis together to fit this body too so this is where the work will be for next few days and a few other welding projects 1st so i bent my 1st 3/16" soild rod im going to have fun with this wish me luck ill think about this more tonight and tomorrrow ..tire carrier and rear stinger im thinking. |
01-12-2014, 09:18 PM | #13 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
Lookin good, first bit of tube is the hardest but once you get a good base that is square/level you'll be suprised how easily it flows from there. Before you know it you'll have an interior cage and an exo |
01-26-2014, 10:31 PM | #14 |
01-26-2014, 11:12 PM | #15 |
RCC Addict Join Date: Mar 2009 Location: hawaii
Looks really good! What springs are you using on those scx10 shocks?
01-27-2014, 06:56 AM | #16 |
| Re: bronc's 2014 class2 rig..yota truggy Good eye ...Top secret springs not axial..o and i love em....ok i give injust had them in my box from some old Durango dex410 buggy there small bore shocks rear..that 1st came out not there new big bores they almost fit the shock cup perfect..i just ordered some new test springs I hope they work kyosho might be discontinued
02-03-2014, 07:35 PM | #17 |
cage done for now testing period..and light bar tabs still planned but i need a roller asap for upcoming comp so hear we are.. bare looks so good i almost wanted to spray only clear coat but i chose to keep it classy black.. winch plate fairlead.. lights front im good back not sure yet.. wiring next..shes a pig so far 9lbs |
08-14-2014, 09:43 AM | #18 |
Long time small update.. Ok I've been really happy so far with this rig small issues but I've been getting around them. 1st the heavy stock seats ive been wanting to make a set but my time is aways taking up. so when the scale shop put out the new seats i picked up a set and they were great i was so busy I didn't take a pick but he's happy .. After that i went to the king of guru's in ohio and had blast running and meeting all the cool guys and i also picked up one of these bad boys 3rd in class 2 |
08-14-2014, 10:09 AM | #19 |
Ok and the guru's kicked both of my rigs butt.. at the end of my run i noticed my front diff slipping close call..so tear down time before ECSC nasty water aways gets in these curries i guess.. looks to be my front gripfab no slop locker came loose or something it had been in there for some time and it might of been user error ..but nothing broke so i cleaned it all up and put her back in with red lock tight made sure my axle ran smoothly and cranked it down good decided to swap out that o/d gear up front also as I've seen my teeth get chewed up like dlux and some has found..so I'm now running std hd gears front u/d in rear. And some new 5mm stub cvds all new bearing of course |
08-14-2014, 10:20 AM | #20 |
O how could I forget added my lights and motoworks rims and scale hubcaps also.. last week local comp yota took 3rd and fj took 1st Last edited by bronc4now; 08-14-2014 at 10:48 AM. |
bronc's 2014 class2 rig..yota truggy - Similar Threads | ||||
2014 Mattzilla Ultra4 Rig | Harley | 1.9 Scale Rigs | 149 | 02-07-2016 02:22 PM |
Bronc's c1 rig | bronc4now | 1.5 Scale Rigs | 28 | 02-16-2015 11:48 PM |
Yet another Yota truggy | Jester666 | 2.2 Scale Rigs | 94 | 08-23-2010 03:48 PM |
My Yota Truggy | atvdude775 | 1.9 Scale Rigs | 10 | 05-21-2009 11:16 PM |
