Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: military recovery truck
Old 01-26-2014, 05:20 AM   #21
Default Re: military recovery truck
Originally Posted by arcanecrawler89 View Post
Do some type of screw shaft with a servo on it so the servo can lift and lower the boom. Basically some sort of worm gear type set up :thumbup:
sent from my 5th scale
thanks man, I hadn't even thought of that lol I'll see what I can come up with, should be able to make it work I have made worm drives before, I used one for an automatic tilt tray truck which is what I was originally thinking for this build but I decided against it.
dcrou7 is offline   Reply With Quote
Old 01-26-2014, 12:12 PM   #22
Love this truck! Looks great. I'm looking forward to more updates.
rj_dio is offline   Reply With Quote
Old 01-26-2014, 04:40 PM   #23
I thinkbit would do good with a worm gear then when or if you do a scale video with it you can run better footage at least thats how I see it
arcanecrawler89 is offline   Reply With Quote
Old 01-27-2014, 07:02 PM   #24
I was wondering who got this cab, glad to see it going on a chassis. looking really good
SEMIJOE is offline   Reply With Quote
Old 01-29-2014, 06:25 AM   #25
Thanks, I'm glad you like it.
I mocked up all the electronics and took it for a test drive today goes pretty good but still a few creases I need to iron out. Very fun can't wait to really get the tires dirty lol
Old 01-29-2014, 07:16 PM   #26
what chassis is that?
minicooperzoom is offline   Reply With Quote
Old 01-29-2014, 10:01 PM   #27
The chassis rails are from a tamiya king hauler I had to make custom cross members to make it slightly wider to allow the scx skid plate to fit, and the leaf springs are from an OG bruiser so they are very stiff that's why I needed to make the drop shackles and the axles are the wide cast alloy RC channel ones. I ended up needing to chop about an inch of the end of the chassis rails so that the bed would fit on. If you like I can post some more detailed pics of how it's all set up.
Old 11-04-2014, 07:52 PM   #28
What ever beacme of this project?
military recovery truck - Similar Threads
Recovery Trail Truck ngward79 1.9 Scale Rigs 49 11-13-2014 01:18 PM
SCX10 Recovery Truck Tonysmini Axial SCX-10 17 03-19-2013 06:42 AM
F-350 Recovery Truck (now a dually!!!) maxxa87 Axial SCX-10 32 06-26-2012 08:18 PM
military ShKH vz.77 Dana recovery 8x8x8 #187 SEMIJOE Non Crawler RC's 14 02-06-2011 01:15 PM
recovery truck lobi1kanobi Scale Videos! 8 05-05-2009 11:00 PM
