02-09-2014, 04:40 PM | #1 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
| 55' chevy sedan
this build has been a long time in planning, started and stopped a few times, and now has found a grove that really seems to work. custom.......everything really. TH rear end Creeper front (for now) G-made V1 1.9 1.9 rock crushers TH trans going 15t HPI fireball and the stock TH ESC for now. Brushless in the end though. g-made gtransistion shcoks in the back stock axial shocks up front for now, had them and they work. Here is how the idea started almost 2 years ago now, RS10 axles and creeper wheels and tires, loving the current version. |
02-09-2014, 05:26 PM | #2 |
Rock Stacker Join Date: Nov 2011 Location: clarskville/ but now back in Ohio
| Re: 55' chevy sedan
how is the steering gonna work? and with a good paint job it will look bad ass
02-09-2014, 05:30 PM | #3 |
Trying to do a cantilever with the servo under the boby. Almost wotks, need more throw on the servo side. Sent from my SCH-I545 using Tapatalk |
02-09-2014, 06:42 PM | #4 |
Newbie Join Date: Mar 2009 Location: SLO
| Re: 55' chevy sedan
Your servo is going to hate you unless you get a longer arm on that canti If you have a traxxas steering rack sitting around, I would use the piece on the left in this picture. http://www.amainhobbies.com/images/m...ra/tra3743.jpg Last edited by TLZ; 02-09-2014 at 06:59 PM. |
02-09-2014, 06:52 PM | #5 |
Yeah, trial and error. Anyone seen any other setups similar? Sent from my SCH-I545 using Tapatalk |
02-09-2014, 07:03 PM | #6 |
| Re: 55' chevy sedan
It's not efficient, but it can work. The main problem I see with using the revo rocker is that it is not exactly a 90 degree difference, so in the starting position you are actually pushing the linkage out instead of straight forward. Also, as the linkage rotates you will be losing efficiency past the 90 degree (from where it attaches to the linkage) point. I think the optimal setup in terms of transmitting the servo's power would use a long arm that the servo will attach to, and a short arm to attach to the steering linkage but then you run into the issue of not having enough throw. |
02-09-2014, 07:06 PM | #7 |
| Re: 55' chevy sedan
Is that a MERV rocker? If so, you might go ahead and try using a rocker from a full sized revo.
02-09-2014, 07:06 PM | #8 |
No traxxas stuff here, I was looking at exactly the problem you are talking about. Just hate to hang a servo on the front of this. I think it will kill the look. Sent from my SCH-I545 using Tapatalk |
02-09-2014, 07:07 PM | #9 |
That is a part off a twin harmers, I think it is a shock rocker. Sent from my SCH-I545 using Tapatalk |
02-09-2014, 07:32 PM | #10 |
Quarry Creeper Join Date: Jul 2011 Location: westchester,il
| Re: 55' chevy sedan
Love the idea!!!! Really outside the box |
02-09-2014, 07:33 PM | #11 |
| Re: 55' chevy sedan
I think you could possible use this piece on the rustler steering rack after trimming off the excess post, but you would need to find a shoulder screw with a long threaded section because the ID of the bushings in the rack is 5.3mm Another option that might be easier would be a 1/10 revo rocker with the servo pushing the long side, but I'm not sure on the screw size or the actual dimensions of these so it may not work too well. Traxxas Revo Rocker arm set, long travel (120-T) (use with #5318 or #5318X pushrod) [TRA5356] | RC Cars & Trucks - A Main Hobbies |
02-09-2014, 07:39 PM | #12 |
Maybe I just need to flip the one I have. Sent from my SCH-I545 using Tapatalk |
02-09-2014, 07:40 PM | #13 |
| Re: 55' chevy sedan
Why not go BTA with the servo mounted on a plate that extends behind the axle, and hide everything under a cowl? You are going to run into steering issues without the servo rotating with the axle.
02-09-2014, 07:41 PM | #14 |
No room with the links and frame locations Sent from my SCH-I545 using Tapatalk |
02-10-2014, 11:45 AM | #15 |
| Re: 55' chevy sedan
Found the HR wheely king bell crank Hot Racing HPI Wheely King Aluminum Steering Bellcrank WK4808 | eBay more than I wanted to spend, but should work and look good doing it. |
02-10-2014, 06:10 PM | #16 | |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: 55' chevy sedan Quote:
02-10-2014, 11:25 PM | #17 |
| Re: 55' chevy sedan |
02-16-2014, 10:08 AM | #18 |
| Re: 55' chevy sedan
Got the one I ordered in and it was exactly what I needed, so for this project I guess it was worth the $14. slide the front axle forward to clear the fenders at full lock. And then did a final trim on the body and mounted up some TH rear shocks on the front. Last edited by Docwolf; 02-16-2014 at 10:12 AM. |
02-16-2014, 08:07 PM | #19 |
| Re: 55' chevy sedan
Did the bell crank have bearings ?
02-16-2014, 08:09 PM | #20 |
It did not, didn't even come with the bushing but I happened to have one the right length. Sent from my SCH-I545 using Tapatalk |
55' chevy sedan - Similar Threads | ||||
55' Chevy Sedan Creeper. | Docwolf | Venom Creeper | 8 | 07-13-2013 07:45 AM |
Rcdude2000's 55' Chevy | Rcdude2000 | Losi Micro-Rock Crawler | 23 | 01-10-2013 06:59 PM |
55' willys pickup ( body built by pardonmyn00b) | scale4x4 | 1.5 Scale Rigs | 84 | 05-29-2012 09:11 PM |
55' chevy | looneybin | Chit Chat | 5 | 11-25-2006 03:54 PM |
