02-25-2014, 11:28 PM | #21 |
Rock Crawler Join Date: Oct 2011 Location: minot
| Re: Mallcrawlers FJ build thread
Any angle where the drive shafts don't bind..
02-26-2014, 09:21 AM | #22 |
Rock Crawler Join Date: Feb 2010 Location: Paw Paw, MI
Here are the pics of how I mounted my body onto the sliders. The bolt coming through the slider from the inside. And how it looks when the body is stretched over the bolt. I do not use a nut or anything to hold the body. The sliders are a 1/8" wider than the body wants to be, so the compression of the body squeezing the slider holds it in place. I have one of these per side, and when viewed from any angle other than the bottom they are not noticeable. Let me know if you need more clarification on this. As for your pinion angles, try to rotate the rear up as much as possible (within reason) to keep it above the bottom links so you wont get caught on it. Ideally you would like to do the same with the front, but with the stock c-hubs you are stuck with the pinion mostly flat (and at a steep angle) unless you want to eff up your caster (and sacrifice your steering). Adjustable c-hubs will allow you to rotate the axle housing while maintaining good caster though, so they may be worth a look when you upgrade. |
02-26-2014, 09:35 AM | #23 | |
Pebble Pounder Join Date: Jan 2014 Location: richmond
| Re: Mallcrawlers FJ build thread Quote:
02-26-2014, 01:06 PM | #24 |
update from today got the rear lowers cut. right now eye to eye 4 1/4 inches. made them a tad longer just so i can go back and make them shorter if need be. wont get much done to it till the weekend. more pictures tonight Last edited by mallcrawler24; 02-27-2014 at 08:56 AM. |
02-27-2014, 08:55 AM | #25 |
another update. got the front and rear lowers created, also have the rear uppers where the uppers have the axle clocked so it wont bind. going to have to cut the drive shaft shorter. working on getting the front uppers the right length. right now my wheelbase is 10 1/2 inches. not bad for a start. i can adjust later if need be. |
02-27-2014, 11:52 AM | #26 |
been busy today got all the links made up. just need to get the alluminim sleeve and cover them. final wheelbase is 10 1/2. how do my angles look? it test drove fine couldnt tell of any binding. rear front looks like it might need to be adjusted. next thing to do is chop the frame and mount the body. need to study german tonight so no more work until tuesday. |
02-27-2014, 05:52 PM | #27 |
You are definitely going to be better off shortening the upper links on the front, that is a bit aggressive. It looks like you did that because the driveshaft slip is almost non-existent, but that's an easy fix by trimming off a few mm from shafts. Otherwise it looks good. What are your plans for the bumpers? Last edited by Ramination; 02-27-2014 at 05:54 PM. |
02-27-2014, 06:08 PM | #28 | |
no idea for bumpers yet. | |
02-27-2014, 08:32 PM | #29 |
Move your shock towers towards each other. Use the existing holes towards the middle for the outer holes on the towers That will lean your shocks towards each other I stead of away |
02-27-2014, 09:23 PM | #30 |
| Re: Mallcrawlers FJ build thread yeah i have a lift kit ill most likely use that and put the rear shocks more over top of the rear axle. the front shocks seem to be ok might move them over one hole. my birthday is in 2 weeks i asked for some proline shocks and some pitpull tires we shall see what i get.
03-05-2014, 12:58 PM | #31 |
| Updates!
so ive had all morning to get some work done on the FJ. First thing i wanted to tackle was shortening the front upper links. got that done. the next thing i wanted to do was chop the frame. i started by making small cuts and kept test fitting and test fitting. took some time but im happy how it turned out. the front the rear now the body fits pretty snug i like how it turned out. |
03-05-2014, 01:00 PM | #32 |
Lets see a body on pic.
03-05-2014, 01:11 PM | #33 |
| body mounting
so after i cut the frame my next task was figuring out how to mount the body. i liked the way how Ramination mounted his and i liked it and was set to copy it. but while working today i had another idea. I took the rear bumper from the honcho and bolted it to the bumper of the FJ. this made it so the body slid into place via the frame. here is the picture of the the bolts through the rear of the body. cant even tell with the spare tire. and i plan on painting the bumper black any way. for the front I used the front bumper mount. i cut the mounting post off the bumper and put the post back into there hole and cut them flush with the frame cap. then i put velcro on them and the front of the FJ. i have since trimmed the excess since the picture. I plan on using a stronger velcro in the future but for now it holds. so to put the body on just slide the body from the rear on to the frame. then pull the front of the body and attach it to the velcro. pretty simple design. what do yall think? |
03-05-2014, 01:16 PM | #34 |
| Re: Mallcrawlers FJ build thread |
03-05-2014, 01:19 PM | #35 |
| testing it out. |
03-05-2014, 01:23 PM | #36 |
things to come. 2s and 3s lipos and charger castle bec axial 8 hole beadlocks proline TSL's proline shocks jevne racing battery plate should have all installed by saturday. also might paint the body tonight. |
03-05-2014, 02:03 PM | #37 |
03-05-2014, 02:12 PM | #38 |
03-05-2014, 02:18 PM | #39 |
Did you get the regular sized TSLs or the XL? And please paint this thing something other than camo!!!! What is the belly clearance? Looks really tall? |
03-05-2014, 02:33 PM | #40 |
Mallcrawlers FJ build thread - Similar Threads | ||||
Tamiya CC-01 Landfreeder Build Thread (Build Complete) | TheBlueKnight | Tamiya XC/CC01 | 29 | 11-24-2014 11:21 AM |
Cormier33's CC Smash Build "TEAM OTTSIX Post Season Build Off" official entry thread | cormier33 | Axial XR10 | 132 | 10-26-2014 11:04 PM |
Dual Dingo build thread-My first build thread | juswin24 | Axial SCX-10 | 205 | 09-19-2013 12:42 PM |
Swezy207's 2.2 scaler build! (first build thread) | swezy207 | 2.2 Scale Rigs | 43 | 09-19-2011 07:01 PM |
not really a build thread more of a upgrade thread... | dragit | Axial AX-10 Scorpion | 16 | 07-02-2009 10:11 PM |
