Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: RC4WD Planetery Transmission Pinion HELP
Old 02-25-2014, 11:22 AM   #1
Default RC4WD Planetery Transmission Pinion HELP
Sorry mods if this is in the wrong section. I just recently purchased a rig with this planetary transmission and it did not include a pinion. I have searched through the forums and all I have found is that it is a 48p 15t metric pinion. Although I know what 48p is and a 15t is, I have never heard of a metric pinion....
So my question is, does anyone know of a pinion that is compatible with this transmission? And can anyone further elaborate on what a metric pinion is and how it differs from a standard pinion.
Any help will be much appreciated
fallensk8man89 is offline   Reply With Quote
Old 02-25-2014, 04:23 PM   #2
Default Re: RC4WD Planetery Transmission Pinion HELP
The teeth are cut a little different.and they're a hair off in size.The metric.If put on a normal spur will tear it up.And the same if a normal one is put on a metric spur.
T I N Y is offline   Reply With Quote
Old 02-25-2014, 06:33 PM   #3
Is it a disruptor trans? If so rc4wd sells the pinion needed.
littletoyboy is offline   Reply With Quote
Old 02-26-2014, 11:44 AM   #4
Thanks for the quick response guys....
Yes it is a disruptor transmission from rc4wd. and they do sell an hd gear for it, but it is out of stock. also I think it said they were going to be discontinued.
I am not just trying to get a pinion to get it going, I am also trying to find an alternative pinion that people can buy down the road if they need one for this transmission.
So... does anyone know of a pinion other than those from rc4wd that will work with this transmission?
Old 02-26-2014, 07:58 PM   #5
I think tamiya is known for using metric pitch pinions in vehicles, cc01 for example. I also read that they are a .6 pitch, if it's the same as a .6 MOD these are used as pinions on berg axles and Robinson racing makes a 15 tooth pinion. Sorry it's not a definite answer. You could try emailing Robinson racing directly.
spookyseven is offline   Reply With Quote
Old 02-26-2014, 10:48 PM   #6
thanks spooky I appreciate the info. I have found one of those and ordered one so I will post when I receive it and test it.
Old 03-03-2014, 12:01 PM   #7
just an update. the robinson racing 15T mod .6 Metric Pinion will fir this transmission and is much more durable than the just that comes with it factory
Old 03-03-2014, 07:26 PM   #8
Yotapane's Avatar
Location: norcal.. The real NorCal , like 400 miles north of NorCal
I've had issues tracking down the same gear for my glenade, rc4wd has a contact button and I emailed them that the gear was lost and they instantly emailed me back with the link to the upgraded gear..
Yotapane is offline   Reply With Quote
Old 02-20-2016, 09:10 PM   #9
Yota I need that link. i have this trans in my rig an cannot find a pinion anywhere
bent is offline   Reply With Quote
RC4WD Planetery Transmission Pinion HELP - Similar Threads
Disruptor Transmission Pinion Gear??? heinie_21 General Crawlers 0 09-03-2012 11:55 PM
rc 4wd planetery reduction g/ box steveh General Scale Talk 0 12-17-2011 09:54 PM
