05-04-2014, 11:13 PM | #1 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
| Class 2 toyota "clone"
. I started off like my other truck with some 1/2" square tubing bent to shape. Now it says in the title that this is a clone but there will actually be some deviations to my original truck. First is the drive train a Dinky tranny\T-case set-up. The skid is designed to fit in an SCX10 chassis so i drilled the rails to match. then split them The problem with the Dinky skid is that it is designed to go inside the rails. i used a stock SCX10 skid in my bronco and hated that i had to notch out the rails to remove the skid. so this time i added plates to the inside to allow the skid to be removed easily once the who chassis is complete. the fit was good so i burned them in. I'm out of practice with the TIG, it didn't turn out as good as i hoped. when i filed it down it wasn't perfectly smooth. i'll take care of that later. The skid bolted up well next i drilled some holes for the tranny, mounted it, and bolted up a spare set of axles using stock Dingo rear links and custom fronts. the tranny is nice and lever with the frame the problem with the tranny is that there is only one mounting hole on either side. Now the bosses that slid into the frame are angled but are not a tight fit at all and it cannot hold up to the leverage of the motor More on that later Next i wanted to tackle the front linkage, wanted to be able to run either a 3 link or 4 link so since i had a Hands Brothers 3 link already on the axle i made the single upper. Then i threw some wheels and tires on and got it to an approximate ride height. then i tacked a tab in place for the panhard bar. fits pretty good Now to tackle the tranny. i made up some tabs to add another mounting location. then tacked them to the chassis being that there is no other mounting options i simply drilled and tapped some new ones. now it's plenty secure Oh and one last thing. i did a quick mock-up of the body And if you are wondering, Yes it will have a drop bed and yes it will be all aluminum like my class 2 truck! More later Last edited by THX_138; 06-08-2014 at 02:03 PM. |
05-04-2014, 11:32 PM | #2 |
Pebble Pounder Join Date: Nov 2006 Location: Tennessee
Very nice! Looks like yet another quality build. How do you go about splitting your tubing for the frame? Bandsaw? Cutoff wheel? Butter knife? Sent from my Phoneamathingy |
05-05-2014, 07:53 AM | #3 |
Rock Crawler Join Date: Jul 2005 Location: Spartanburg
| Re: Class 2 toyota "clone"
Sub'd! I always like watching your builds! Especially when they get all "mashed" up and look that much more like most of the yota's I see on the trails lol
05-05-2014, 08:31 AM | #4 |
Quarry Creeper Join Date: Feb 2006 Location: Glenrock
Nice work! I have to do some of same things to my frame. U set the bar! |
05-05-2014, 01:40 PM | #5 |
Quarry Creeper Join Date: Dec 2012 Location: ontario
Sir You Make Some Fantastic Builds !
05-09-2014, 10:36 PM | #6 | |||
| Re: Class 2 toyota "clone" Quote:
Thanks! It was time to get this thing standing on it's own. i starting by bending up some hoops out of stainless tube. Then for the rear i made some plates. since the tube is going to be stainless i'm going to try to make all the other parts stainless as well. then i tried something diferent and attempted to braze the plate in without tacking it first but it was an epic failure as you can see with the one on the left. If you are wondering why the tube was cut unevenly this is why. with the truck having a full drop bed but running a 4 link i needed a place to put the hoops that wouldn't take away from the bed floor. so i decided to lean them forward to try to keep the tires out of the shocks. And to keep the hoops under the fenders Next it was time for the front. I started by making some tabs for the shock Then the hoops were trimmed and the the tabs were mounted along with the lower mounts then they were tacked to the chassis. The last thing i did was add a rear cross bar. It's finally standing on it's own If course the mandatory flex shot then with the bed in place More to come! Last edited by THX_138; 06-08-2014 at 02:00 PM. | |||
05-09-2014, 10:43 PM | #7 |
Rock Crawler Join Date: Apr 2011 Location: beautiful rainy washington
lookin killer bud! The details are amazing |
06-06-2014, 11:38 PM | #8 |
Thanks! Well i have been working on this but i just haven't had time to post progress. So here is an update. Once i had the chassis situated, i decided to lock the front in place with a cross member. Fit is nice and should be real clean once i braze it. The i moved onto the rear. i decided to give it a better departure angle and pie cut the chassis. Then TIG'd it shut and ground it smooth. then i needed to make the bed mounts. i bent up some sheet metal first Then tacked then in place for the front mount i used some sliced square tube and added the serial number to make it official And tacked it in now it was time for some fresh panels starting with the bed floor and inner fenders then i made some supports and fastened them to the frame and glued the bed floor down Now with a clean bed floor for reference i was able to start on the cab. I formed the roof, cab back and B pillars and glued them together then positioned it on the chassis then i was able to make the sliders and add them to the chassis Next came the rear hoop it was added as well. test fit the cab skin again and all looks good then i added the tubes in front to secure the sliders finally i bent up the rear bumper and tacked it to the chassis keeping it in the same plane as the cut to the frame rails. That's it for now! |
06-07-2014, 09:46 AM | #9 |
Awesome work... still! I have to ask, any reason U put the 2 upside-down in the serial number?
06-07-2014, 11:36 AM | #10 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
Best truck winner. Great stuff sir.
06-07-2014, 11:54 AM | #11 |
Newbie Join Date: Jun 2013 Location: Lakeside
It's going to be sic when your done. Nice skills you have. Sent from my SAMSUNG-SGH-I337 using Tapatalk |
06-08-2014, 07:35 AM | #12 |
Rock Crawler Join Date: Sep 2013 Location: New Orleans
Blown away! No words come to mind. Outstanding skills.
08-09-2014, 12:00 AM | #13 |
well since he was unable to post more progress on my truck due to not being a vendor he updated me with pics of all the progress, its finally finished and i received it in the mail yesterday. Here are a few of the pics he sent me as updates and in the next post i will post pics of its progress since i got it yesterday.... |
08-09-2014, 12:13 AM | #14 |
After 7 months of anticipation it arrived yesterday and im speechless! I even got a complete spare body set.... I decided to go a stockish color for this first body and i will do some black yota stripes. I also think for the moment im gonna use these 1.55's untill i can find some 1.7 iroks, i have some new 1.9 tsl's i planned to run but at the ride height i want they may be a bit big and will mangle the fenders For now its gettin axial axles i have the DDK setup in it with all Robinson internals, HH 35t torquemaster, 90mm icons, MMp or brxl (not sure yet), and i just ordered the winch and the grill |
08-09-2014, 12:14 AM | #15 |
| Re: Class 2 toyota "clone" |
08-09-2014, 12:58 AM | #16 |
I also started messin with interior, i had this dash out of a mustang (i know its not scale to the yota but its gonna work for now) I modified it some to fit and changed out the steering wheel and added a grab bar, now gotta make seat mounts for the buckets and i will be running thses two jokers in here lol |
08-09-2014, 06:21 AM | #17 |
Looks great! Glad to see it showed up ok. Enjoy!
12-18-2014, 10:30 AM | #18 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Wow!
12-19-2014, 02:37 AM | #19 |
Quarry Creeper Join Date: Feb 2009 Location: Rockaway
12-19-2014, 07:01 AM | #20 |
Quarry Creeper Join Date: May 2012 Location: Biloxi
Class 2 toyota "clone" - Similar Threads | ||||
"Victim" or "V2" a "Country Boy Customs" class 3 | Mighty1 | 2.2 Scale Rigs | 10 | 05-06-2011 10:56 PM |
My cc-01 Jeep "PFB YJ clone" 1.55 wheels test run pics 9-28-09 | 59sled | Tamiya XC/CC01 | 20 | 10-20-2009 09:58 PM |
