Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Project Farm Truck - Axial SCX10 with Tamiya F350 body
Old 07-12-2014, 12:21 AM   #1
Default Project Farm Truck - Axial SCX10 with Tamiya F350 body
After previously building a Tamiya F350, I decided I wanted the performance of the SCX10 with the scale appeal of the Tamiya High Lift. Begin Project Farm Truck.
Started with a basic SCX10, Delrin cross members, Chassis mounted servo and panhard, and forward mounted battery.
Aluminum C channel was used to make Velcro mounting brackets utilizing the shock towers. The original side mounting holes and roof antenna are filled.
Underside view of the bed and cab, bolted together using the original holes and further supported using some extra plastic links. The links are attached using bolts/nuts on the front (before filling the holes on the outside) and Shoe Goo to hold the rear. The cab and bed seemed very weak prior to adding the links.
I built a headache rack using styrene supported internally with 1/4 aluminum tubing for increased strength.
Test fit using 8/32 all thread with a nut under the bed, fits snugly and holds well due to the angle. The all thread and nut are held in place under the bed with shoe goo.
Start of the styrene toolbox, which will have an opening lid.
More updates later.
TrailSnail is offline   Reply With Quote
Old 07-12-2014, 02:30 AM   #2
Default Re: Project Farm Truck - Axial SCX10 with Tamiya F350 body
nice, so you're going for a scale truck that still performs good? sounds sweet, i know my brothers scaler (trail finder 2) gets the worst flex lol, so it will be interesting to see how this turns out. i can see you're off to a good start, looks great so far.
Hammer! is offline   Reply With Quote
Old 07-12-2014, 09:41 AM   #3
Looks great so far!
HDMM is offline   Reply With Quote
Old 07-12-2014, 11:39 AM   #4
Thanks. I'm looking for better performance than the Tamiya High Lift, but this will still be pretty top heavy.
Some work on the interior, starting with an old school bench seat. Used .060 styrene heated and bent, then added some cushions and covered with stretch fabric.
Seat after finishing and added the driver zip tied to the seat.
Old 07-12-2014, 02:09 PM   #5
Got some primer on the toolbox and headache rack and mocked up to check for proper fit and function:
Old 07-12-2014, 04:23 PM   #6
Building a basic dashboard with enough detail to look realistic through closed windows. Here is the progress while trimming to fit and determining how to mount the dash.
Old 07-12-2014, 04:27 PM   #7
Bumpers painted and ready to mount:
Old 07-13-2014, 06:51 AM   #8
looks neat, i like the seat, maybe i'll put one in my hilux, keep it up
jez
jezzami101 is offline   Reply With Quote
Old 07-13-2014, 10:04 PM   #9
jez
Thanks, the seat is pretty easy to make and works for an old school look.
Old 07-13-2014, 10:31 PM   #10
Finished the supports and lower portion of the interior and installed LEDs. The switch to change the settings on the lights is accessed from inside the toolbox (blinking hazard lights etc.).
Old 07-13-2014, 10:34 PM   #11
Painted the body with a cream center stripe and brown for the remainder of the truck. The headache rack and toolbox are painted to match the center stripe.
Old 07-13-2014, 10:38 PM   #12
A few shots of the interior with glass installed:
LED lights (4 5mm white and 4 3mm amber in front (amber doesn't show up in the picture), 2 5mm and 2 3mm red lights in the rear):
Project Farm Truck - Axial SCX10 with Tamiya F350 body - Similar Threads
1978 GMC Longbed, SCX10 based, Farm Truck fanke19 1.5 Scale Rigs 66 09-14-2015 03:42 AM
Axial SCX10 Honcho Tamiya Highlift Ford F350 RC4WD Trail Finder Hilux CR01 Unimog Sca boolean21 Scale Videos! 0 04-01-2014 10:58 AM
help with old tamiya body for scx10 project smedo Axial SCX-10 1 08-19-2009 04:03 PM
