09-04-2014, 06:45 AM | #21 |
RCC Addict Join Date: May 2012 Location: Montreal, Qc
| Re: Starting a truggy...
Oh yeah, I know my front shocks hoop are inverted... It all correct now... |
09-04-2014, 07:26 PM | #22 |
Had to correct couples of things... First the drag link was hitting the chassis and de steering link when shock compressed... So I move the steering link under the knuckles and bent it just enought to clear the pumpkin and get my full steering... Second, my tires was touching the knuckles and rod end caus they haven't enought offset... I've tried all the 1.9 wheels I have in stock and no one has the correct offset so I bought some brand new vp omf wheels from another member here so I can put my shift hub on them and obtain the clearance needed... Finally, not happy at all with the stock scx shocks but not sure what to do about it... Was thinking about installing some 100mm shocks (gmade aeration or big bore) with a droop kit to have more flex and a decent cog... What u thing??? |
09-04-2014, 07:52 PM | #23 |
And for my combo, I was thinking about a castle sidewinder v3/HH crawlmaster pro 11t, geared 57/10 32p... Should have the torque and the speed... Any thought? |
09-04-2014, 10:07 PM | #24 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Can't go wrong with the BigBores.... Watch your temps with that gearing on your HH 11t...probably a good place to start |
09-05-2014, 06:07 AM | #25 |
Ordered a complete set of big bore... For the temp, i talked to John from HH and he told me i should be fine with a ratio around 5.5:1... So i ordered Robinson pinion 9-10-11-12t 32p... will see which s better and run cooler... |
04-06-2015, 11:15 PM | #26 |
Wow... Its been a while since i update this thread... In fact, i almost start all over cause i change my rear SMF cage and my cab for a Hilux... So basically, here s the actual list of parts... Scx10 base -Sv3/HH crawlmaster pro 11t -Castle bec -HR all metal trans 32p -Axial cvd kit -Junfac driveshaft front/rear -SMF custom truggy cage #H062 -SMF Rock slidders # -SMF cab mount -VP stage 1 blue kit (knuckles, chub, lock-out) -Warrior Armor front bumper -STRC front shock hoop -Jevne electro/batt mount -RR pinion 32p -Hilux cab, grill, Windows, back cab pinched nose mod -VP OMF beadlocks silver/grey -VP hub .600 front, .475 rear -Pitbull Growler 1.9 w/foams -Vaterra Super Swamper 1.9" spare tire/Vaterra beadlock -VP Ti links kit/revo-jato rod ends -Traxxas Big Bore shocks -Beef Tubes from Beef Up Rc -Rear links riser -Alu servo horn -HPI trophy driver -light front -KK licence plate -Rubber mirrors -Spektrum Sr300wp receiver -Customcuts emblems -Custom electro plate Last edited by noname0383; 04-06-2015 at 11:33 PM. |
04-06-2015, 11:24 PM | #27 |
what it looks like as a roller...
04-06-2015, 11:32 PM | #28 |
Some more parts... Beef Tube from Beef up rc SMF rock slidders Warrior Armor bumper Links riser battery plate ... |
04-06-2015, 11:43 PM | #29 |
I bent a bit my rear lower link for more clearance And i did the pinch mod for my Hilux cab... I also have to cut my front grill to fit... |
04-06-2015, 11:48 PM | #30 |
So, now the cab is ready for the painting... Flat black with some gloss black desing... And the last pic is waht the cab looks like once finished, with mod grill, lights, and the drivers from hpi trophy tuck... |
04-07-2015, 12:02 AM | #31 |
So, this is basically waht my ''Rattoy'' looks like right now... Still a little bit of job and tuning to do but i will wait to run it on rocks before... Oh yeah, and some emblem from Customcuts still need to be install... So plz, comment... |
05-13-2015, 04:55 PM | #32 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
Sweet rig Any up day on this bad boy? |
05-13-2015, 07:41 PM | #33 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Those wheels are DOPE |
05-13-2015, 09:52 PM | #34 |
Turned out great Noname.... Let us know how you like those red springs on those big bores...I found them to be too stiff for me. Now go get some dirt on it.... |
07-27-2015, 11:26 AM | #35 |
Thx pal... Yeah, the red springs are a bit stiff... i ordered some other softer, will begin with only the front first and will see how it goes... Oh yeah, little changes i ve made... Modified a bit the rear cage to fit 2 spares, just to be a bit different from others... Add some scale details and accessories... Last edited by noname0383; 07-27-2015 at 11:32 AM. |
07-27-2015, 11:28 AM | #36 |
Customcuts details...
07-27-2015, 11:35 AM | #37 |
I'm out on vacation right now and i brought my rattoy with me... so i'll be able to give u an update shortly... and some way cooler pics with battle scars lol...
07-28-2015, 11:03 AM | #38 |
Pebble Pounder Join Date: Jun 2015 Location: Smethport
So...do your front tires get into the body? it looks real tight up there. The truck looks great though. I especially like the paint and mudflap girl.
07-28-2015, 12:01 PM | #39 |
yeah the tire rub a bit into the cab but nothing scary for now... but i only test it a few times in easy trail or in door, so will see how it does on real rocks... As i said, i intend to run it a lot during vacation so i'll be able to have a better feedback of the rig then... |
08-14-2015, 01:42 PM | #40 |
Yeah the rig perform very very well, i love it... The setup on 3s lipo is amazing... perfectly balance between speed and torque... Everything held up pretty well too, the rear SMF cage and slidders, the Warrior Armor bumper and even the painting... Nothing broke or bent... I now have to work a bit on my steering to get a bit more angle I need to put softer rear spring but not too soft either I need to ''upright'' my front shocks one hole foward And thats about it for now... Last edited by noname0383; 08-14-2015 at 01:50 PM. |
Starting a truggy... - Similar Threads | ||||
Blackfoot Truggy (Ford F-150 Truggy) | saltinemadness | Axial SCX-10 | 11 | 10-14-2015 09:51 PM |
My Little Truggy: Fourwheelin is Magic? F350 truggy for my daughter | Joe$ | 1.9 Scale Rigs | 44 | 08-27-2013 07:29 AM |
Hilux Scaler Towing Hilux Truggy (douggy truggy) by heinie_21 | heinie_21 | Videos! | 10 | 02-18-2013 02:15 AM |
so im starting a truggy | redneck909 | General Scale Talk | 17 | 02-23-2008 08:34 AM |
