02-23-2016, 12:30 PM | #81 |
Rock Stacker Join Date: Dec 2011 Location: Fresno
| Re: Starting a truggy...
Yes please update....you did a fantastic job and I would love to see more from you bud!
02-23-2016, 06:40 PM | #82 |
RCC Addict Join Date: May 2012 Location: Montreal, Qc
| Re: Starting a truggy... |
02-23-2016, 06:51 PM | #83 |
New chassis... But mine is the V1 aluminium paint black Scale Chassis Rails - JC Auto Design I bought some of these items but not sure what i will really use!?! -cms + battery mount -scx10 rear chassis brace -scx10 cms + truss & link combo SCX10 Upgrades - JC Auto Design |
02-23-2016, 09:28 PM | #84 |
No build thread for mine...it looks just like yours with subtle differences...I always tell everyone to come see your build as it was the inspiration for mine....I'm waiting on a new chassis too...how is your cage working with the Karnage chassis? Modifications?
02-24-2016, 06:40 PM | #85 |
The cage work great, just have to ''bent'' the pieces as picture to fit the higher rear chassis... |
04-05-2016, 06:17 PM | #86 |
So finally switch for my new chassis: Karnage v1... Will see how it goes and if it perform better then before... Not much of a big upgrade but give way better clearence for the axles in full compression... New chassis: Scale Chassis Rails - JC Auto Design I had to bind a bit the 2 bars as picture above on the SMF cage, seems to hold great... Installed this too: Rear Chassis Brace - JC Auto Design I also ordered the CMS/Panhard kit but didn't install it yet... will test the rig as is for now and will see how it handle... CMS + Battery Mount - JC Auto Design CMS + Panhard Truss Combo - JC Auto Design |
04-05-2016, 06:24 PM | #87 |
How it look right now with the Karnage V1 chassis: Smooth skid: Rear: Front: Rear Brace: Rear Brace in full compression, perfect fit: Custom electro/batt plate: Still need some setup to do but everything seems good right now... will see how it perform on rocks and if i need to install the cms/panhard for a better fit... |
04-15-2016, 03:07 PM | #88 |
Rock Stacker Join Date: Mar 2016 Location: Austin
I have a power wagon model which has the slipper cover on the transmission. Do you know if this smf rc cage would block the body from mounting? The side view of the chassis in this link shows how the slipper cover protrudes at the back: Axial Racing - SCX10 |
04-15-2016, 03:57 PM | #89 |
What cab will u run? But yes, you'll probably have to take off the trans cover anyway... Envoyé de mon LG3 avec Tapatalk |
04-27-2016, 12:07 PM | #90 |
What RC4WD all around 1.9 tires should i put on this beast? I want a big OD but not as wide (large) as my Growler... Love these but maybe something different? Mickey Thompson 1.9" Baja Claw TTC Scale Tires (Pair) Last edited by noname0383; 04-27-2016 at 12:10 PM. |
05-07-2016, 07:39 PM | #91 |
Ok... Deceided to go with cms/panhard for the first time... So I went with the jcauto design kit as picture above but I have a problem... Everything fit perfect and smooth except for my servo... Don't know how to place it... In this pic, the servo horn hit my bumper mount: In this one, the servo horn hit the panhard bar at compression: Need help here... Envoyé de mon LG3 avec Tapatalk |
05-09-2016, 06:08 PM | #92 |
Anyone plz... I'm stuck here!!! |
05-11-2016, 10:37 AM | #93 |
Newbie Join Date: Dec 2015 Location: Columbus
| Re: Starting a truggy... Look into making a J bar style panhard bar. That may clear better but it is hard to tell from the picture. The main thing to remember on a panhard bar is the only thing that matters is the eye to eye distance. The shape of the bar doesn't matter as long as it doesn't bind. I hope that helps.
05-18-2016, 09:41 PM | #94 |
I ran a cms kit and wasn't a big fan of it so I went back to stock axle mounted...from the pictures, can u flip ur servo around so the horn is more towards the camera to clear the Panhard bar?
05-19-2016, 04:21 AM | #95 |
Thx but problem solve... I went with the Lockedup Rc panhard/cms and it work like a charm... Really well made and a lot of adjustments!!! Envoyé de mon LG3 avec Tapatalk |
05-19-2016, 04:23 AM | #96 |
A perfect fit with the JCauto Design Karnage chassis! Envoyé de mon LG3 avec Tapatalk |
05-19-2016, 12:29 PM | #97 |
How do u like the cms vs axle mounted?
05-19-2016, 06:26 PM | #98 |
Can't tell right now... Didn't have the time to try the new setup yet... Will do extensive test this weekend for sure... But for now, it seems I got the same flex as before but more clearance with the new chassis... Everything is smooth, Locked up Rc did a very good job on this kit compare to others I had before! Envoyé de mon LG3 avec Tapatalk |
05-23-2016, 07:17 PM | #99 |
Test ride of the Ratoy 2.0... I'm very happy with the new setup... The ''rat'' did very well on various terrain, was smooth and predictable... 2 problems occured tho: -my front lights don't work anymore , don't know why lol... easy problem here,,, -the panhard axle mount didn't held cause i used only 2 screws because of my Beef tubes... Problem will be soon resolve: Gunnar Tube - SCX10 Flat top Didn't had the time for a video but a shitload of pics |
05-23-2016, 07:21 PM | #100 |
Still enough flex... and a bit of body rubbing... |
Starting a truggy... - Similar Threads | ||||
Blackfoot Truggy (Ford F-150 Truggy) | saltinemadness | Axial SCX-10 | 11 | 10-14-2015 09:51 PM |
My Little Truggy: Fourwheelin is Magic? F350 truggy for my daughter | Joe$ | 1.9 Scale Rigs | 44 | 08-27-2013 07:29 AM |
Hilux Scaler Towing Hilux Truggy (douggy truggy) by heinie_21 | heinie_21 | Videos! | 10 | 02-18-2013 02:15 AM |
so im starting a truggy | redneck909 | General Scale Talk | 17 | 02-23-2008 08:34 AM |
