06-28-2015, 12:21 PM | #81 |
Rock Crawler Join Date: Jan 2007 Location: Northern Wyoming
| Re: Sp3cia1-K's Goat Built Ibex Build
Great build! A little inspiration to get back on my mini ibex
06-28-2015, 04:07 PM | #82 |
Quarry Creeper Join Date: Dec 2011 Location: Gold Coast, Australia
| Re: Sp3cia1-K's Goat Built Ibex Build |
07-02-2015, 06:00 PM | #83 |
I was looking over the rig the other day and saw something in the rear looked out of whack and I eventually found the issue.. ..A broken shock mount. I'm not overly bummed about the break because I've been meaning to fix the shock geometry for ages. Here's a mock up of the rear setup, with the addition of 6 or so mount locations drilled. |
07-10-2015, 10:44 PM | #84 |
I got some nice chassis related updates with things I have been meaning to do for a long time! It is just in primer stage at the moment so should be posting some pictures later tonight and some running shots tomorrow morning. While I was fixing the rear shock mounts I raised the front and rear bar work to give better approach/departure angles; I also added in a light bar mount inside the cab area and a bunch of other tweaks that I'll show once all the paint has dried |
07-13-2015, 04:30 AM | #85 |
First major thing was obviously reworking the rear shock mounts which ended up working a treat! I can also use the mounts for a sway bar, something I've never run but have had in my drawer for well over a year. Second thing I remodelled was the front end again to this time actually raise the front bumper height as it would hit things far too often. I also gives it a much more aggressive look too Third was reworking the rear section by cutting out the big spare tire mount and raising the rear in a similar way to the front. Due to where/how I did it, I didn't gain too much more uptravel compared to before but looks better The plan is to either run a spare laying flat in the rear section or a yeti fuel cell Last but not least is a light bar mount for my crawler dad v2 light bar. I opted to mount it inside the cab due to the delrin housing construction plus it was easier After all this work it was obviously time to paint again and I ended up going with a similar metallic red as last time, except an actual paint not a colour top coat which turned into a fail. I did a test spray on a piece of chassis off-cut and with no prep, cleaning, primer or anything; the paint sticks brilliantly and is near impossible to scrape/scratch off after just 3 minutes.. I can tell its going to be a million times better than that other rubbish last time! Speaking of paint... Primer: Paint: I ran out of time the other night to update the thread, well I this is where I was at with the build at midnight and had a comp over an hour away at 8.. Got to bed at about 4am and my alarm went off at 6am.. This is how it looked after a hard morning running on the rocks.. And would you look at that, it still has paint on it! Unfortunately we didn't have the numbers to run C3 but to be honest I had so much fun just learning the rear steering that I was happy to not compete. Also to clarify on the changes to the running gear, I am currently running the full width ar60 axle up front with narrow axial hexes and in the rear it is the narrowed xr width ar60 axle with some big wide hexes to compensate for the difference. And the wheels are the axial 8 holes with LockedUp rings running a set of 2.2 Baja Claws reduced to 1.9s |
07-13-2015, 05:31 AM | #86 |
Got the crawler dad light bar mounted and it is good to get it back on a rig again.. Just watch your eyes that you don't burn holes in them Last edited by Sp3cia1-K; 07-13-2015 at 05:36 AM. |
07-18-2015, 09:24 AM | #87 |
07-18-2015, 10:04 AM | #88 |
what radio you using to control the rear steer? I prefer independent control of the rear like in our real rock crawlers and used a DX3r but was basically full lock or straight only. Just picked up a MT4 and the lever works so slick for independent rear steer plus being 4 channel running the dig too.
07-18-2015, 04:12 PM | #89 |
I run a hacked flysky gt3c and use the dr ch 3 for 0/50/100% each direction and love the control I get from it.
12-03-2015, 03:52 PM | #90 |
I realized it has been quite a long time since I have updated this thread, I since converted it back to the regular setup with front steer only. The biggest addition is the BKRC 3d printed engine installed up front. The engine matched up the the original cutout made for the exo engine so was very little hassle to install. |
12-03-2015, 03:58 PM | #91 |
This is likely to be one of my last updates for the Ibex as I will be putting this up in the for sale section later today/tomorrow.. It will be sad to see it leave but have to make room for something else that is about to make its way here |
12-09-2015, 04:16 PM | #92 |
I finally got a ad up in the for sale section, also selling my yeti if anyone is interested in either rig. http://www.rccrawler.com/forum/sale/...xial-yeti.html |
12-09-2015, 07:18 PM | #93 |
Such a sweet rig. Wish I had the cash.
12-09-2015, 07:55 PM | #94 |
It will be sad to see it go.. if your serious I could separate it out to a roller/slider or something Sent from my HTC_0PKV1 using Tapatalk |
Sp3cia1-K's Goat Built Ibex Build - Similar Threads | ||||
Jethro's Ibex build (Harley's Plans Scaled for 1.9's) | Jethrobodean | 1.9 Scale Rigs | 80 | 02-11-2020 07:03 AM |
Harley's Ibex Goat Built Wraith | Harley | Axial Wraith | 57 | 09-09-2019 02:19 PM |
2.2 Ibex build | MNorby | 2.2 Scale Rigs | 17 | 10-03-2015 07:20 AM |
1.9 Ibex budget build | Brassbender805 | 1.9 Scale Rigs | 0 | 06-19-2014 10:58 PM |
Sp3cia1-K's Poison Spyder Wraith Rebuild | Sp3cia1-K | Axial Wraith | 26 | 04-14-2014 07:24 AM |
