08-29-2014, 09:48 PM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: Grande Prairie Alberta
| Wraith's china made jeep 2dr jk
this if my first build thread I've ever done. So everyone please be patient with me. After I seen a few of these jeeps I knew this is what I wanted to build one. This build will really only be a body swap with a bit of parts change because I'm starting with my scx-10 jeep kit that I've been using for about a year now Parts list China 2dr jk Currie axles Gcm motor mount Gcm 1:1 t-case Scx 10 chassis Rigid light bar 1.9 Method wheels Rc4wd front bumper Vanquish cms and panhard Tekin fxr and 35t Spektrum sr410 Hitec 5646wp The rig that will be getting the new jk body And the new body More to come soon |
08-29-2014, 10:14 PM | #2 |
Got my gcm t-case put together. This is my first gcm part but defiantly will not be my last it went together super easy and looks amazing |
08-29-2014, 10:59 PM | #3 |
Can somebody with this body help me out. I want to remove the doors but I'm not sure how. Do you need to remove the black block to get the pin out? |
08-30-2014, 12:30 AM | #4 |
Rock Stacker Join Date: Feb 2011 Location: Eisenerz Erzberg
| Re: Wraith's china made jeep 2dr jk
Yes! Put this black thing away! This is the first step
08-30-2014, 11:08 AM | #5 |
I started to get the chassis tore down Then I installed my gcm motor/trans mount |
08-30-2014, 01:10 PM | #6 |
Mounted the trans to the gcm mount, installed my t-case and found a third drive shaft |
08-31-2014, 12:40 AM | #7 |
Fist body mock up without rear links I took the smaller spring off of the icon shocks till I can afford the rock krawler shocks from rc4wd |
08-31-2014, 06:29 AM | #8 | |
Quarry Creeper Join Date: Jan 2011 Location: Waterford MI
| Re: Wraith's china made jeep 2dr jk Quote:
08-31-2014, 02:03 PM | #9 |
For the panhard I had to move it forward a bit and drill a new hole to work with the gcm mount Cut down the stock shock hoops to get the body to sit lower And got the doors off and put black electrical tape on the fenders to get an idea of what it will look like Sorry for the bad iPhone pics |
08-31-2014, 07:16 PM | #10 |
Pebble Pounder Join Date: Jan 2014 Location: Archdale
Thats gonna be a cool build. We will be watchn. |
08-31-2014, 09:33 PM | #11 |
Got the rear links made And with the body |
08-31-2014, 11:20 PM | #12 |
Hmm, I like what you did with the rear shock hoops. Maybe I will do that on mine to get it a bit lower. I'll probably drill my holes higher though to keep as much of the stock stance as possible.
09-01-2014, 12:25 AM | #13 |
Started to trim the body Before During And finished On the chassis |
09-01-2014, 12:36 AM | #14 |
For the from body mounts I took the body post type pice from the axial kit box Carefully drilled it out with a 17/64 drill bit and mounted it to the frame Now the post on the bottom of the body fit in it And cross drilled it for a body pin |
09-01-2014, 01:10 AM | #15 |
Wow, I like that. Thats another issue I was having with sheet metal tabs was bolt them to the chassis with the cms and bumper mounts. Paint to get it on every time.
09-01-2014, 11:29 AM | #16 |
Got my paint today Flat Grey for the body and flat black for the fenders |
09-01-2014, 06:22 PM | #17 |
I'm thinking I want to cut the rear fenders completely off. What do you guys think |
09-01-2014, 07:52 PM | #18 |
Wraith913, Die Laughing, fr8cture and now yours. Man all of these look awesome and i guess i may have to bite the bullet and get one. Great job so far. Oh i say keep the rear fender and skin the top with diamond plate. |
09-01-2014, 08:36 PM | #19 |
Wow thanks for the compliments. fr8cture & die laughing are the ones that inspired my build. I like the rear fenders but it's so tempting to cut them off. |
09-01-2014, 08:43 PM | #20 |
I would keep em unless you do a comp cut which looks awesome too. Sent from my VS980 4G using Tapatalk |
Wraith's china made jeep 2dr jk - Similar Threads | ||||
china 2dr jeep body awesomeness !!! ? | Rodamis | 1.9 Scale Rigs | 85 | 05-03-2017 12:45 AM |
My China made JK Build | TriggerMan | 1.9 Scale Rigs | 52 | 12-08-2016 07:25 AM |
Where to find China made lipo/charger in USA? | benzy2 | Electronics | 9 | 06-30-2010 11:30 AM |
