u4 1.9 szcerba made chassis figure i start a new thread on the new ultra 4 rig im starting parts list pro4 4000 mmp savox hr aluminuim tranny robinson gears mips over under harden gears locked up lockers wraith skid axial links rear titanium links vanquish methods hydro dip vanquish curries big bore shocks toyota hard body proline tsl xl crawler inovation foams rig is orignal a 2.2 ifs wrexo.. http://i289.photobucket.com/albums/l...image-1152.jpg http://i289.photobucket.com/albums/l...image-1446.jpg updated pic http://i289.photobucket.com/albums/l...image-2274.jpg |
Re: u4 1.9 old szcerba made chassis i realized after building this up and changing things i love to have steering so time to redo it and turn it into a 1.9 rig and compete in the 1.9 u4 races this year in the nw seattle washing comps here is the build thread from this past year |
Re: u4 1.9 old szcerba made chassis |
Re: u4 1.9 old szcerba made chassis http://i289.photobucket.com/albums/l...image-2472.jpg http://i289.photobucket.com/albums/l.../image-314.jpg http://i289.photobucket.com/albums/l.../image-688.jpg http://i289.photobucket.com/albums/l.../image-825.jpg http://i289.photobucket.com/albums/l.../image-825.jpg tore the wrexo apart picked up some axle that had the 5m vp shafts and harden gears and vp hubs and knuckles since i already had a rear currie i purchased a front currie housing rear scx tubs mounts and everything else to complete the set from the good guys here in the rcc market place... time to put the thing together had a few issue with the lockers working but got that fixed,,,, ill update more pics soon |
Re: u4 1.9 old szcerba made chassis Good to see you at it , axles are beast. |
Re: u4 1.9 old szcerba made chassis Quote:
http://i289.photobucket.com/albums/l...image-1938.jpg http://i289.photobucket.com/albums/l.../image-836.jpg http://i289.photobucket.com/albums/l.../image-587.jpg had to bring it to work to shave down the c hubs so the 5m shafts would fit and not bind waiting on the mounts for the rear |
Re: u4 1.9 old szcerba made chassis http://i289.photobucket.com/albums/l.../image-377.jpg http://i289.photobucket.com/albums/l.../image-815.jpg http://i289.photobucket.com/albums/l.../image-290.jpg making sure the links will work pinion angles good mock up the power plant looking good so far still have to cut off the ifs mount so it will clear the servo |
Re: u4 1.9 old szcerba made chassis http://i289.photobucket.com/albums/l.../image-765.jpg http://i289.photobucket.com/albums/l...image-1637.jpg http://i289.photobucket.com/albums/l...image-1446.jpg http://i289.photobucket.com/albums/l.../image-286.jpg almost done not sure what body to go with alumn panels or yota hard body also might go with the big bore alumn shocks ill probly take out the axiial linkgs and make new links with alumn rods and traxxus rod ends |
Re: u4 1.9 old szcerba made chassis http://i289.photobucket.com/albums/l...image-2282.jpg paint the body dark camo brown to match the lighter camo mossy oak hydro dib method wheels |
Re: u4 1.9 szcerba made chassis And then..... |
Re: u4 1.9 old szcerba made chassis lol got it all together did some run testing jumps hills broke stuff like links servo shocks lol |
Re: u4 1.9 old szcerba made chassis and here is the testing day with the shorter currie axle http://i289.photobucket.com/albums/l.../image-952.jpg http://i289.photobucket.com/albums/l...image-1398.jpg http://i289.photobucket.com/albums/l...image-1191.jpg |
Re: u4 1.9 old szcerba made chassis http://youtu.be/1Wxa3-Ax7Sw here is a testing video i broke the rear links so i picked up som solid stainless steel traxus links with revo ends also broke the servo ears so i fixed that then will be adding a steering link vp next went was the rear shock pulled out the bottom end so it s time for limiting strap race is this week end we will see how it does in the 1.9 class |
Re: u4 1.9 old szcerba made chassis i have 3 different wheel and tire options so far the tsl work good but so far my mayhem and growlers combo works better my hubs are wider and wheels are alittle heavier helping with stability |
