Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: It's Jeepster Time!
Old 03-19-2015, 08:01 PM   #1
Default It's Jeepster Time!
Time for another Jeep build, this time not as detailed as the previous one, I want to comp / G6 with this one so it's time for a topless Jeepster. It's in a rough state as it sits, have to pick up more styrene, build up the hood and start the shaping process.
Inspiration ans rough sketch:
Cut templates from the sketch and cut out .080 styrene for the sides for rigidity:
Rough assembly:
joe122 is offline   Reply With Quote
Old 03-20-2015, 05:18 PM   #2
Default Re: It's Jeepster Time!
Rough assembly:
Looking great! if you need any pointers let me know.
Silverado1 is offline   Reply With Quote
Old 03-20-2015, 07:51 PM   #3
You two guys cut from the same slab? I'm awed by both of your styrene skills! Looking forward to the finished product joe!
Mike Flea is offline   Reply With Quote
Old 03-20-2015, 07:54 PM   #4
I would have to die and be re-born, and hopefully with half of your skills, your builds are incredible, and yes I am always looking for pointers!
Old 03-20-2015, 07:56 PM   #5
Thanks Mike, very kind words.
Here is the aftermath of a night of sanding. Sore fingers again!
Old 03-20-2015, 08:03 PM   #6
Hi Joe if you're interested I have a primer that is excellent on styrene when your to paint I can take a picture of the can and where I get it.
Sean
Old 03-20-2015, 08:05 PM   #7
Sean
That would be great Sean.....Thanks!
Old 03-20-2015, 08:12 PM   #8
Joe
Time, patience and practice that's what it take.I'll try to help out as much as i can.
Sean
Old 03-20-2015, 08:55 PM   #9
I am an old guy, have tons of patience Sean, besides just following your builds is an eye opening experience, seriously.
Scott
Old 03-21-2015, 03:11 PM   #10
Hi Scott
Here's the primer that I was talking about, I buy it at a auto body supplier, it's not cheap but it works well,it actually bonds with the styrene, just don't apply a heavy coat at first it will crackle on you. Once you allow the first coat to dry for a couple of hours I apply glazing putty were it needs it, let dry and sand then I apply a heavy coat let dry for a couple of days. If you decide to try it let me know how it went.
Sean
Old 03-21-2015, 03:36 PM   #11
Sean, thanks. Found it online at O'reilly auto parts. Your right, $21! SEM is a high quality line. Going to head there now and see if it's on the shelf.
Old 03-21-2015, 04:11 PM   #12
Scott
If you have sore fingers from sanding you may want to get a power file from Black & Decker http://www. black and decker.com 1\2 precision belt sander model#PF260 this what I use for my rough sanding and great for metal also.
Sean
Old 03-21-2015, 09:39 PM   #13
So far fingers are surviving, good tip though...Thx!
Almost ready for primer.....
Old 03-22-2015, 07:18 AM   #14
Scott are you adding body lines to your build? if your interested I have a few tips.
Old 03-22-2015, 10:44 AM   #15
I usually do, but Jeepster's are pretty devoid of any side character lines other than the molding that normally surrounds the wheel wells. I utilized flares this time. I did use a piece of .020 on the hood so as to keep the slight bump in the hood. These are pretty slab sided vehicles. But I always am open to suggestions, especially from a pure craftsman such as yourself, Thanks Sean.
Here I've test fit the cage, will be finishing the interior, fuel cell seats etc. And more sanding!
Old 03-22-2015, 11:42 AM   #16
Looks great! Isn't sanding a lot of fun! Did you get the primer? When ever I finish my priming and body work I wet sand with 320 grit to get it ready for final paint, have you decided on a color?
Old 03-22-2015, 03:09 PM   #17
Gave it the first coat of primer.
Old 03-22-2015, 05:02 PM   #18
Is that the Sem primer?
Old 03-22-2015, 06:25 PM   #19
NO, very bumbed, it was shown to be available online at both O'reilly and Auto Value parts stores, went to both stores and not in stock, might have been able to order it, but I've heard positive things a bout Duplicolors primer surfacer, so that's what I tried this time.
Old 03-25-2015, 07:50 PM   #20
Out of the paint booth! See'in green!
It's Jeepster Time! - Similar Threads
Jeepster build Falon 1.5 Scale Rigs 37 09-20-2015 06:26 AM
1.9 eBay Jeepster french_connection 1.9 Scale Rigs 208 01-23-2015 05:55 PM
Jeepster Build Jeepster13 1.5 Scale Rigs 7 11-09-2011 06:16 PM
