04-15-2015, 10:30 PM | #1 |
Quarry Creeper Join Date: Jan 2014 Location: Logan
| Rock solid 1.9 minYeti
Here is the mini yeti work in progress. More too come.
04-15-2015, 10:37 PM | #2 |
| Re: Rock solid 1.9 minYeti
Even gonna use a straight rear axle.
04-16-2015, 09:31 PM | #3 |
Rock Crawler Join Date: Nov 2011 Location: Kamloops
That rear axle is gonna tell you no no no lol
04-17-2015, 07:16 PM | #4 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
What the heck is that thing! What did it start out as? Damn it! Now I might need one of those too.
04-17-2015, 10:59 PM | #5 |
This started life as an hpi mini trophy truck, I chopped the rear suspension and cut up a perfectly good yeti body and now it is slowly becoming the mini trophy yeti.
04-17-2015, 11:03 PM | #6 |
The mini trophy is almost the same width as an scx10. The wheel base is a little long I'm probably going to take a 1/2 inch off.
04-17-2015, 11:09 PM | #7 |
I'm still working out the kinks on the tail end but this is essentially what it will look like. I need to finish some tube work and build a new axle truss still. Also I'm thinking I may use some vaterra trailing arms in place of the hpi mtt trailing arms, that should bring my wheel base down to about 12.25".
04-18-2015, 03:07 PM | #8 |
That thing is too cool
04-23-2015, 09:40 PM | #9 |
Finally got some more work done
04-23-2015, 09:44 PM | #10 |
Shortened the wheelbase from 12.75 down to 12.25.
04-23-2015, 09:48 PM | #11 |
Added some longer travel shocks
04-23-2015, 09:51 PM | #12 |
Added some dual rate rear shocks with extra absorbers....for looks.
04-23-2015, 09:53 PM | #13 |
It still drops all the way to the ground.
04-23-2015, 09:56 PM | #14 |
Flex ain't to bad neither.
04-23-2015, 10:02 PM | #15 |
Added some nifty axial wheels with carbon fiber beadlocks, and narrow swamper iroks.
04-23-2015, 10:08 PM | #16 |
4 linked the rear and added this cute little wing from a losi mini 8ight.
04-23-2015, 10:13 PM | #17 |
Ok one more side shot
04-23-2015, 10:18 PM | #18 |
Can't decide if I like the hood.... So here is what I'm working with...?
04-23-2015, 10:22 PM | #19 |
Here is the stock body back on..
04-23-2015, 10:27 PM | #20 |
Last one for the night.
Rock solid 1.9 minYeti - Similar Threads | ||||
** Brand New MSD Rock Solid 2.2 Beadlocks ** | Unimoger | Tires and Wheels | 65 | 01-30-2008 12:18 PM |
