Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: D90 from the UK
Old 07-11-2015, 03:52 PM   #1
Default D90 from the UK
Hi I'm Paul tomorrow is the start of my ultra4 style defender90.....I've allready cut down a set of 2.2 boggers to 1.9 and got the currie axles mocked up! Il update as we go but for now!
Paul 88 is offline   Reply With Quote
Old 07-11-2015, 10:27 PM   #2
Default Re: D90 from the UK
Ohhh....this should be good one!
Angus_Beef is offline   Reply With Quote
Old 07-13-2015, 02:06 PM   #3
different angle
body mocked up
still a lot to do the chassis is sort of there winch mounts to finish....link mounts for up to...lots of fiddling with the cage it's all 5mm tube no rod fully brazed and chassis mounted! Should be a tough old rig
started the wings
front
Old 07-20-2015, 01:19 PM   #4
managed to grab a hr on a bit of fab work the cage work is almost done
managed to sneak off again tonight it's becoming a regular thing the tray is complete just the rear chassis mount to finish it....Iv got winch mounts to do but I'm holding out to maybe bag a quicksand winch...the power stroke shocks arrived today from the U.S. So il be able to mock those up next
done a little on the grille also managed to tidy the odd joint and straighten a couple of tubes! I'm really enjoying building this truck
Old 07-23-2015, 05:59 AM   #5
Something totally off topic and I'm unsure were to ask.....does anyone have the dimensions of a quicksand winch? I know there very rare but I'm holding out until I get one! I can make the front mount if I have the dimensions
Old 07-23-2015, 10:19 AM   #6
I am liking the shape and proportions of the tube work. One observation though...it appears the tube work is removable everywhere except where it attached to the front bumper. Am I missing something?
DaddyJeep is offline   Reply With Quote
Old 07-23-2015, 10:39 AM   #7
You have a keen eye......the tube work was tacked there to hold it square while I worked on the rest of the cage...I've got some pics from today if fitted front mounts and a winch tray..along with the rear stays for the tray...
Old 07-28-2015, 02:28 PM   #8
Little more info....iv been offline a while a house move to the sticks means no wifi ATM iv got the front axle set in position with the shox and upper links in....I need to address the steering as ATM iv got no place for the servo.that said I may (everything crossed) got myself a quicksand for it
Old 07-31-2015, 03:27 AM   #9
Got the air intake done well happy with this.....
Old 08-01-2015, 02:24 AM   #10
Sorted the steering....fitted a light bar guard and got the suspension mocked up....soon be ready for blasts and paint....if I can decide a colour Iv also bagged a quicksand winch if it arrives
Old 08-05-2015, 12:05 PM   #11
Mmmmmm
Old 08-05-2015, 01:19 PM   #12
Looks awesome Paul ,I never seen a winch like that looks good sitting there in the front!
Javi84 is offline   Reply With Quote
Old 08-08-2015, 02:09 PM   #13
Cheers javi the winch is a quicksand 8274 replica
Old 08-10-2015, 11:19 AM   #14
Old 08-12-2015, 06:49 AM   #15
Awesome rig Paul!
Those tires are crazy...good kind of crazy!
rcjeepbuilder is offline   Reply With Quote
Old 08-12-2015, 01:57 PM   #16
awesome rig, when you say cut down a set of 2.2 boggers did you actually cut a chunk out then glue them back together.
greenz is offline   Reply With Quote
Old 08-12-2015, 03:14 PM   #17
Yes the tyres had a biggish chunk taken out of them...there around 5mm taller than stock 1.9 boggers but super phat...if you look you can see the cut line.
Old 08-23-2015, 11:49 AM   #18
Called at the UK scale nats this weekend....no rig as its not finished! But iv started the bodywork now
Old 08-25-2015, 11:41 AM   #19
Old 08-25-2015, 11:50 AM   #20
Awesome build Paul! Great work on that cage!
I love all the UK traybacks in general and especially the Gigglepin Special.
Just asking, did you also check the looks with tall & fat 1.9 tires...?
Anyhow, look very much forward to next posts
pana651 is offline   Reply With Quote
D90 from the UK - Similar Threads
Another D90 from the UK. Pete Attryde Axial SCX-10 37 01-18-2013 05:00 PM
D90 notagain 1.9 Scale Rigs 2 10-14-2010 06:54 PM
D90 kikcaffine 1.9 Scale Rigs 0 05-30-2010 05:03 PM
Where to get D90 HB? THEWHITEZOMBIE Paint and Body 4 08-05-2009 06:32 AM
d90 buster22 General Scale Talk 0 05-04-2009 01:15 PM
