10-30-2015, 04:51 AM | #41 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| Re: Suzuki tube buggy Thinking about making my own chassis rails like you. What size box tube did you use, what gauge steel? Also, how did you split the box? Bandsaw? I dont have a bandsaw but I thought I saw someone do it with a cutoff wheel in a drill press.
10-31-2015, 02:36 AM | #42 | |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
| Re: Suzuki tube buggy Quote:
Bandsaw I've tried other methods. I found the dremel wheel in the drill press took forever and didn't seem to work as well as I might have hoped. The hardest part is splitting the two halves the rest is easy. | |
10-31-2015, 05:11 AM | #43 |
Sweet build Mnster.
10-31-2015, 07:09 AM | #44 |
Quarry Creeper Join Date: Feb 2008 Location: US
Amazing fab skills. Hats off to you sir. I am taking notes over here. I've never been brave enough to try a custom chassis. Keep the updates coming.
10-31-2015, 09:21 AM | #45 |
Pebble Pounder Join Date: Apr 2013 Location: Penn Yan
| Re: Suzuki tube buggy Very cool build!
10-31-2015, 10:08 PM | #46 |
Well had a little mishap today. While brazing the cage mounts the styrene tub was just little to close to the torch and it melted. So back to square one on the interior tub. I guess i wasn't very happy with it any how it seemed to basic and fragile. I'm deciding to try a new route, vacuum forming. I was planning to vacuum form the drivers floor pan to allow clearance. So I made some fender molds. Spent the rest of the day making a vacuum table from about $10 worth of lumber. The idea is pretty simple, attach my shop vac at the back of the box. The little holes will suck the molten styrene sheet over the molds. The frame holds the sheet while I heat it with a heat gun. After the plastic sheet becomes molten I slide it over the box and suck it in place with the shop vac. No idea if this is going to work but worth a try later this week. I'd like to make two molds for complete interior tub sides. That way I can make replacements easily if needed and can make it fit the inside of the body like a glove rather then just flat sheet. Last edited by Mnster; 10-31-2015 at 10:16 PM. |
11-01-2015, 11:23 AM | #47 |
Completed the molds. Loaded up a sheet. 1st pull 2nd pull 3rd pull This left me with several to choose from. They are hardly perfect but should look just fine inside a body. Choosing the best two I can already tell I like the shape fit and finish way better than the boxy styrene work I did prior. |
11-01-2015, 05:55 PM | #48 |
Pebble Pounder Join Date: Jun 2015 Location: Smethport
The vacuum formed fenders came out real nice.
11-03-2015, 10:31 PM | #49 |
It rolls! Even flexes half decent. Put some work into mounting a shifting servo for the 2 speed trans. |
11-04-2015, 02:55 AM | #50 |
RCC Addict Join Date: Jul 2006 Location: Pasadena
Holy wow, that thing is nice. All of the proportions are perfect.
11-04-2015, 06:19 PM | #51 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
Short wheelbase is awesome, lots of cool fab work in a little package!
11-04-2015, 07:50 PM | #52 |
Rock Stacker Join Date: Jul 2010 Location: Airville
Vacuum form worked out great. Really cool build.
11-06-2015, 08:17 AM | #53 |
Moderator Join Date: Jan 2004 Location: chicago
sweeeeet! drop bed is excellent. |
11-06-2015, 10:48 AM | #54 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Awesome work |
11-06-2015, 10:08 PM | #55 |
I did some work on the rear bumper today 3/16 stainless tube can't wait to head back to work to sandblast all the flux off the parts and make them shine. The tail light decals will go in the holes to fill it out like the real thing. I'm considering making tube fenders all the way around the truck to give the fenders a little more depth and fill. Would be a pretty big task but likely worth the effort in the end. Worked some more on the shifting linkage. I ordered a RC10GT throttle linkage to get the needed springs and do dads to make it work smoothly. Should have it done in a few days. Finished the steering linkage and installed the servo. Last edited by Mnster; 11-06-2015 at 10:11 PM. |
11-07-2015, 10:07 PM | #56 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
Neat design, digging the updates and having the time to take us through each step is cool too. Didn't know about lexan body at first but incorporating styrene is to add realism is a great idea taking away the thin plastic body look!
11-12-2015, 06:14 PM | #57 |
Floor pan mold Still have to cut it so the Trans fits. Tons more work to go. |
11-12-2015, 06:15 PM | #58 |
Don't know where to start. such a great build!
11-12-2015, 06:42 PM | #59 |
Rock Stacker Join Date: Apr 2009 Location: Round Lake
That's BaD A_ _! I have to try that vacuum molding thingy soon.... Great job man!
11-12-2015, 08:49 PM | #60 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
Nice!
Suzuki tube buggy - Similar Threads | ||||
Tube Frame Suzuki | gadge | 2.2 Scale Rigs | 0 | 06-06-2013 12:14 PM |
usnick suzuki, surgical stainless tube | gardenwelder | 1.9 Scale Rigs | 7 | 10-20-2011 02:45 PM |
Project Suzuki Samuri tube crawler.replica of a real crawler | RCWizard | General Crawlers | 7 | 12-24-2004 06:53 PM |
