07-26-2015, 10:30 AM | #1 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Twin Bouncers
Made you look !!!!! This is/was being built for Axialfest. The idea for this rig came from MCE076 and with his blessings I proceeded to put my own twist to it. The idea was to build a super low slung rig with gobs of power (more on that later)I started with some square tubing and split it in half, next was the basic shape. A basic mock up of the axles, skid and trans. The motor is Holmes hobbies new puller pro stubby. Side by side comparison with a standard 540 brushless. Some sliders added that will doubles as a battery tray and cage mount. MIP drivelines to prevent the catastrophic failures that can happen when you run a HOSS of a motor. The front axle has a Wheely King ring and pinion, this provides a 6mm output on the pinion shaft. Should add to the durability of the ride. Last edited by hotwheels000; 07-26-2015 at 10:42 AM. |
07-26-2015, 10:33 AM | #2 |
| Re: Twin Bouncers |
07-26-2015, 10:35 AM | #3 |
| Re: Twin Bouncers
I will also be using the new brushless censored esc from Holmes Hobbies. Can you believe I am running a waterproof esc.... Cant trust that parker guy:fu-ha: Holmes Hobbies new trans output spool. Spool is the lightened version. He even includes a shim for proper gear alignment. I don't want all the rotating mass a Robinson Racing lower output provides. A rc10gt lower gear will be mated to this when installed. Here is the motor and specs. 50,000 rpm, yiiiiiicks...Can youo say 4s:rockon: |
07-28-2015, 01:42 PM | #4 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Re: Twin Bouncers
I had to.... Sent from my SM-N900V using Tapatalk |
07-29-2015, 10:37 AM | #5 |
Pebble Pounder Join Date: Jun 2015 Location: Smethport
| Re: Twin Bouncers |
08-14-2015, 03:47 PM | #6 |
| Re: Twin Bouncers
Mmmm bouncies.
08-14-2015, 09:17 PM | #7 |
| Re: Twin Bouncers
Interesting, I'm watching
08-14-2015, 11:19 PM | #8 |
| Re: Twin Bouncers |
08-14-2015, 11:45 PM | #9 |
RCC Addict Join Date: Aug 2007 Location: Seattle
| Re: Twin Bouncers
How easy are the gear swaps and what benefit does the rc10gt gear have over the current metal options?
08-15-2015, 08:29 AM | #10 |
| Re: Twin Bouncers
Bolt in swap, Holmes includes washers to shim it up nice. Rc 10 gears don't really have any advantage as far as I know, just another option. I have never had one strip on me. The big advantage other than the strength is the Holmes spool and a gear set is much lighter than a Robinson 1 piece so rotational mass is diminished and allows the motor to spool up much faster. You probably new most of that but I wanted to throw it out there for others that may not. |
08-15-2015, 10:21 AM | #11 |
Quarry Creeper Join Date: Apr 2011 Location: THE SHOP
| Re: Twin Bouncers That's as lite as you can get it? I like how it tits, I mean sits! |
08-16-2015, 08:31 AM | #12 |
| Re: Twin Bouncers
Well if the driver would quit eating all my cookies it would be a lot lighter |
08-30-2015, 12:51 PM | #13 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: Twin Bouncers
Awesome build and use of the TH cage. Any completed pics?
08-31-2015, 10:39 PM | #14 |
| Re: Twin Bouncers
Sadly no, once I build them I tend to forget or take the time to photograph them. I will dig zround a bit as I know Justinart24 has a few he posted on facebook.
08-31-2015, 10:42 PM | #15 |
| Re: Twin Bouncers
Yes, we need some more pictures. Such a mean looking rig!
Twin Bouncers - Similar Threads | ||||
Are bouncers still "in" ? | krazykrawler | General Crawlers | 23 | 05-23-2015 07:56 AM |
Ultra4 vs Rock Bouncers....insane slow mo' climbs | SkaldidDog | Chit Chat | 1 | 10-08-2013 08:52 AM |
Rock Bouncers...one question.... | REV666 | 1:1 Full Size Vehicles | 21 | 04-30-2013 07:32 AM |
rock bouncers playing | ax10newguy | Scale Videos! | 0 | 09-22-2012 11:03 AM |
