07-27-2015, 10:02 PM | #1 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
| C2 Custom Axial Jeep Nukizer 715
The few of you that know me in person know I'm not a big jeep fan.....except for the old Kaiser and J10 pickups. Since the announcement of this body kit I've been patiently waiting. Then someone posted that tower had them in stock and boom. Here we are... Not like I needed another project but this was just too cool to pass up. Looks like this will be the first 1.9 build with the axial body. Some pretty sweet custom ones made along the way. It will be full class 2 legal in case I get a wild hair and try to make it to a big scale comp this year. Plus I'd like something with more scale points but still performs. From the second pic above you can see it's a 3 pc body. The grill and rear bumper are molded separately. Pretty smart since they take a lot of abuse and it gives them true 0.040" thickness vs the normal thin spots you get with the forming process. I rough fit the parts together and the fit is good, not perfect, but good. I'll have to do some massaging to get the grill perfect. It comes with 2mm screws and nuts to hold everything together. Not sure if I'll use them or shoe goo. We'll see. I need to play around with track width. I want this to really perform. But I want to be inside class 2 rules and the look of the rig has to be right. My narrowed wraith axle is at about 7.5" to 7.75" inside to inside on the wheels. And the body is around 7.25" at the doors. I'll do some more work once my tires show up. See how far I want them tucked into the fenders and narrow the axle even more. The parts list is mostly carryover from my current class 2 rig. But some new stuff will be coming. Castle mmp and bec Tekin roc412 3100 geared 9/56 running on 3s Savox 1230 servo Futaba 4pls Castle sidewinder decased to run the winch I'm going to see if I can build a bumper around the tziworld winch to replicate the 1:1 Narrowed wraith up front with axial unis and 36/14 gears Scx10 in rear with 43/13 gears (planning on an SSD new rear housing when they come out.) Scx10 trans with steel gears and likely CI 5mm outputs. TSS Robby Gordon beadlocks in black. Axial bfg krawlers with CI 4.5 lill nova (soft front, med rear) Either MIp or Maxx driveshafts. Scx10 frame rails Custom tube work by me with 3/16" stainless tube I'm still working out the color scheme but it will only deviate a little from the 1:1. Right now I'm planning on a drop bed so I can replicate the original spare location. Sent from my iPad using Tapatalk Last edited by dna4engr; 07-27-2015 at 10:07 PM. |
07-27-2015, 10:52 PM | #2 |
Quarry Creeper Join Date: Feb 2009 Location: Rocky Mountains
| Re: C2 Custom Axial Jeep Nukizer 715
Sounds like a great project. Have you measured the wheelbase of the body?
07-28-2015, 07:38 AM | #3 |
Quarry Creeper Join Date: Sep 2008 Location: NW San Antonio
Very curious about the size of the wheel well openings. Would like to know if the Swamper XLs or even 2.2s would fit without trimming the wheel wells too much.
07-28-2015, 07:48 AM | #4 | ||
| Re: C2 Custom Axial Jeep Nukizer 715 Quote:
I'm going to use 3.5" big bores so it won't have a ton of articulation. I've found I don't need a lot to be successful crawling. | ||
07-28-2015, 08:39 PM | #5 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
I've heard about the release of this body, will have to follow. Any color choice yet?
07-28-2015, 08:44 PM | #6 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
These are the first pics I've seen of the body... shame it's a 3pc, but for strength reasons I'll concede. Are the tail lights separate as well?
07-28-2015, 08:52 PM | #7 | ||||
It's actually more like 12". I plan to push the front axle forward as much as possible for approach angle. Quote:
Here is a 1.9 trepador tucked up in the fender. Quote:
Going to be gunmetal grey on the outside with some graphics and covered in flat. Quote:
Tail lights are embedded in the rear of the bed. There are lexan light buckets for the headlights. Sent from my iPad using Tapatalk | ||||
07-30-2015, 05:52 AM | #8 |
The new skins arrived yesterday. I mocked up the chassis, axles and suspension. I'm going to run it at 12.4" wheel base to push the front axle forward just a bit. Here it is at full extension And full bump. I plan to get the ride height just an 1/8"-1/4" above bump Here's the current situation on the front axle. You can see how wide it is (this is after 7/8" removed). It's about 1" wider than the rear. I decided to take about 3/8" more out so it will remain wider than the rear but fit better. Luckily it came apart easily with the screws removed. Now I need to cut and glue. Sent from my iPad using Tapatalk |
08-01-2015, 08:09 PM | #9 |
Quarry Creeper Join Date: Jun 2008 Location: San Antonio
Looks good so far! Can't wait for mine to show up |
08-05-2015, 07:00 AM | #10 |
Any updates?
08-06-2015, 08:50 AM | #11 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
Dana, your projects are pretty cool to stumble upon here.
03-07-2016, 02:48 PM | #12 |
Whoa it's been a while since I've touched on this project. To be honest it's been on the shelf the whole time. I decided to go a different route. Rather than make this my 1.9 trail comp rig, I decided to just do a scale build and use it for trail runs and g6 style events. Maybe a U4 race or two if my 1.9 u4 isn't ready yet ;) Still going to base on an scx10 chassis. Going to be 3/16 Dom tubing roll cage with a drop bed and fill spare setup like the 1:1. Mmp with tekin roc412 3100 still the plan. Staying with the bfgs and Ci foams, but going with some 1.9 Delrin wheels I picked up from duuuude with locked up demon rings and scale black hardware. Also got some ssd axles. Nothing I'm sure anyone hasn't already seen but I like them. Front is ud gears, vvd cvs, locked up FI spool, axial chubs and ssd knuckles. Along with some brass tubes from ssd Rear is ud gears, locked up FI spool and OT shafts (had to pound them in...super tight fit), ssd lockouts. Sent from my iPhone using Tapatalk |
05-14-2016, 06:35 AM | #13 |
Now that my Brodozer project is almost done, time to see if I can get this one ready to run in a week and a half ;) Picked up the curvy smw skid that is now available 3D printed. Using some stock scx10 frame rails. Setting it up with the axles and tires I almost picked up a ssd ox winch but just couldn't justify it. I had a brand new 3racing and a locked up rc upgrade motor. So I decided to just change the motor out and use this. I did however pick up an ssd bumper and Fairlead. Super nice and I just love that there are mounting holes to use the 3racing or rc4wd warn winch. Dropping that stamped steel piece that the winch comes with is a significant improvement. And looky here, the yeti interior seems to fit the Nukizer very well... This is going to be a quick and simple custom build. The core fab will be the roll cage. I plan to have it able to remove the top. Just need to decide on paint colors now....hmmm baby blue with a black canvas top.... Sent from my iPad using Tapatalk |
05-16-2016, 09:59 PM | #14 |
I was messing around with a cms for quite a while and then I just said screw it and put the 4 link and servo on the axle. It's actually pretty easy with the ssd axles. You just have to drill an extra hole. The rear factory one on the scx servo plate is in the right spot. Also built up some big bores for front and rear. So tonight it was time to start on the cage. Like I said, it's going to be simple and straight forward. I need to figure out how I'll retain the body. Screws or Velcro...we'll see. I plan to make the roof removable so that will definitely have to screw on. Sent from my iPad using Tapatalk |
05-20-2016, 09:49 PM | #15 |
I wasn't joking when I said this would be a quick one. Chassis is fabbed, body and chassis are painted. Assembly is do e. Byron here we come. I'll let the pictures do the talking. Sent from my iPad using Tapatalk |
05-21-2016, 07:23 AM | #16 |
Will it be ready for tomorrow?
05-21-2016, 09:41 AM | #17 |
Pebble Pounder Join Date: Feb 2012 Location: Buffalo
What kind of tube are you using on the cage and how are you binding it together. Sorry, I'm a noob. Nice build by the way
05-21-2016, 10:42 AM | #18 | |
Moderator Join Date: Jan 2004 Location: chicago
go check out the "Tools, and Procedures" section for brazing and tuber threads. also... if you go to the vendors section theres guys that sell stuff like that. | |
05-21-2016, 12:35 PM | #19 | |
| Re: C2 Custom Axial Jeep Nukizer 715 Yes Sir!! Don't know if she'll hold together...the way I drive ;) Quote:
It's not too hard once you start and get the right tools and material | |
05-22-2016, 10:11 AM | #20 | |
Where is the best place to buy the safety silv and solder? | |
C2 Custom Axial Jeep Nukizer 715 - Similar Threads | ||||
Jeep Nukizer (m715) | Silverado1 | 1.9 Scale Rigs | 77 | 10-06-2015 06:13 AM |
Project JEEP Nukizer 715 Concept | Senior Latya | 1.9 Scale Rigs | 22 | 03-28-2012 12:12 PM |
Jeep Nukizer 715 Concept | DunkinMcNut | Micro Scale Rigs | 15 | 07-23-2010 09:23 AM |
