Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: DaddyJeep's class 2 IFS Crawler
Old 08-22-2015, 09:59 PM   #1
Default DaddyJeep's class 2 IFS Crawler
Since I have my son's crawler working it's time to get started on my own. Mine will be loosely based off my 1:1 Jeep. Of course mine is going to be complicated with slash IFS and I will be building my own arms to match a wraith width rear axle. This build needs to be done in about a month for the Keystone Crawlers TTC.
Here is my 1:1.
[IMG][/IMG]
This is far as I got today. At least it is a start.
[IMG][/IMG]
[IMG][/IMG]
DaddyJeep is offline   Reply With Quote
Old 08-23-2015, 08:49 AM   #2
Default Re: DaddyJeep's class 2 IFS Crawler
Looks like you have it all planned out this should be good!
rcjeepbuilder is offline   Reply With Quote
Old 08-23-2015, 03:05 PM   #3
Started putting together the chassis today. Everything will ultimately tie into the 16ga skid plate.
[IMG][/IMG]
[IMG][/IMG]
Old 08-26-2015, 09:45 PM   #4
[IMG][/IMG]
A little more chassis progress tonight. I need to find me a donor truck soon so I can start laying out electronics and suspension.
Old 08-27-2015, 03:43 AM   #5
Going to be a killer build, love those IFS projects. Nice tube work so far! Will follow....more please.
joe122 is offline   Reply With Quote
Old 08-27-2015, 08:33 PM   #6
More chassis work tonight. I am real happy with the cowl. The cowl is 22 gauge steel welded to the brake line. I also added some more tube in the rear and added a light panel.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 08-27-2015, 08:56 PM   #7
Looks great bud , I can't wait to see it finished!
Javi84 is offline   Reply With Quote
Old 09-02-2015, 09:42 PM   #8
I picked up a Wraith as a parts donor.
[IMG][/IMG]
The width of the Wraith axles are perfect. They match up to the IFS Slash front pretty well. I made a mock up grill so I could start the tube work up front. I think I have a plan on how to marry up the upper chassis to the lower. I am going to make them so I can take the top chassis off. That way if i decide I don't like the IFS I just have to build a new lower chassis.
[IMG][/IMG]
[IMG][/IMG]
The wheel base is going to end up right at 12"
[IMG][/IMG]
Old 09-04-2015, 10:22 PM   #9
I made a die to form the steel hood.
[IMG][/IMG]
The first attempt cut the steel on one side so I had to file some more to get enough clearance.
[IMG][/IMG]
Second try worked much better.
[IMG][/IMG]
Then I needed to figure out a hood hinge. I spent a bunch of time trying to figure out an internal hinge and then I realized, the only way to do it is the right way. So I made me some somewhat scale hinges out of .020" stainless. Tomorrow I will get some piano wire and bolt them in place.
[IMG][/IMG]
Old 09-05-2015, 06:44 AM   #10
Got some sick fab skills Sir! NICE - liking that hood.
Old 09-05-2015, 11:04 PM   #11
Thanks Joe,
I got my body panels made tonight. I welded tabs to the chassis and drilled and tapped them to secure the panels.
[IMG][/IMG]
[IMG][/IMG]
I guess I could have got a few more pics. I made my frame rails and welded them to the skid plate. Hopefully that keeps me class 2 legal. It's still going to be a stretch to fit into class 2, but we will see. I also started thinking on how to make my suspension arms work. I am goingto use the Wraith knuckles for my spindles. The Slash drive shafts fit in them even. Hopefully it will be a roller tomorrow. If not, definitetly by Monday.
Old 09-06-2015, 09:09 PM   #12
I didn't get nearly as much done today as I hoped. I at least got the lower control arm mounts built and welded to the frame.
[IMG][/IMG]
[IMG][/IMG]
Old 09-06-2015, 09:43 PM   #13
Man, some serious fab work here, can't wait to more progress on your build.
Old 09-08-2015, 06:20 PM   #14
Thanks Joe,
I didn't get it into a roller like I had hoped, but at least I got one conrrol arm put together. I still need to plate the top and bottom and weld on the shock mount.
[IMG][/IMG]
[IMG][/IMG]
And the attachment points at the frame.
[IMG][/IMG]
Old 09-10-2015, 10:50 AM   #15
I got lots done last night. I welded a plate on one side of one control arm. woohoo, I feel accomplished.
[IMG][/IMG]
Old 09-10-2015, 08:50 PM   #16
I finished up a control arm tonight and mounted it to the Wraith knuckle using a Jato rod end. I don't think it's going to work. I need to redesign the lower links and make them more accurately. I am going to build a jig to make them more precise next time and I'm going to change the geometry a little.
I never expected this build to be easy and was probably a little over optimistic to think I could complete it in a month. I was reallt hoping to run it in TTC next weekend. Maybe I should throw the Wraith back together so I can at least compete.
Old 10-04-2015, 07:59 PM   #17
I pulled the plug on the IFS for the moment. I built a solid axle lower chassis so I can get wheeling. I will get back to the IFS later. I'll post up some pics later.
Old 10-05-2015, 10:26 AM   #18
New lower chassis with bumpers welded together.
[IMG][/IMG]
Body mounts. They will look much better after a little grinding and blasting.
[IMG][/IMG]
I wonder if my son will let me steal his big block Chevy. It looks right at home in my chassis.
[IMG][/IMG]
I built a 4 link for the rear and 3 link for the front. I built the links a little shorter this time, but they should still perform just as well. The geometry is very similar to my 1:1 and it flexes great.
Old 10-05-2015, 10:31 AM   #19
You can see the links better in this shot.
[IMG][/IMG]
Old 10-05-2015, 05:15 PM   #20
100% scratchbuilt...loving the fab skills..
cooper_xl is offline   Reply With Quote
DaddyJeep's class 2 IFS Crawler - Similar Threads
Mad Skinz IFS Demon U4RC Trophy Class Rock Racer scottanthony 2.2 Scale Rigs 12 07-12-2015 11:25 AM
IFS-Class 4 Section ? the DMG Comments, Suggestions, and Help 44 05-06-2014 03:43 PM
"SOCAL" IFS full fab Trophy Class Mighty1 1.9 Scale Rigs 33 11-27-2013 10:38 PM
Class 1 IFS Hummer edge540 1.5 Scale Rigs 47 11-27-2012 10:27 PM
