10-15-2015, 09:17 PM | #41 |
| Re: Fr8cture's JK8
On another note... I've never been a fan of kings just from feeling a set that I got used awhile back. I decided to try them again because I had to have the look. I decided to try and get some dampening. I sanded down the pistons a little bit so I could fit a shim between the piston and e-clip to cover part of the holes. Seems much better than stock. I was gonna takes some pics but got side tracked. anyways here's a pic. Also my crazy Panhard bar... That's gonna be fun to try to get someone to make in Ti. |
10-15-2015, 09:48 PM | #42 |
RCC Addict Join Date: Nov 2008 Location: Central, WA
| Re: Fr8cture's JK8 The reason for it being moved back is so the spur gear screws dont hit the servo mount (might not be an issue with out the stock slipper clutch). If I ever get caught up enough to put my cms into production, there will be a provision to run your upper link on the drivers side, thus allowing you to turn the motor mount around and run the motor on the passenger side. Torque twist is really not noticeable anymore with the setup you've got, but why not help it even more!
10-15-2015, 09:49 PM | #43 |
| Re: Fr8cture's JK8
Oh I see. I didn't have any clearance issues with it moved forward. I'll probably move it back then. Sent from my VS986 using Tapatalk |
10-16-2015, 06:39 AM | #44 |
| Re: Fr8cture's JK8 |
10-16-2015, 10:33 AM | #45 |
RCC Addict Join Date: Aug 2005 Location: SoCal
| Re: Fr8cture's JK8
What length kings are those? Really digging the way those axles look with the red diff cover!
10-16-2015, 10:34 AM | #46 |
10-16-2015, 11:24 AM | #47 |
| Re: Fr8cture's JK8
I moved the motor mount forward again. Here is how much room there is. This is a locked slipper. Pretty sure it was made by locked up rc got it with a rig I bought a while back. |
10-16-2015, 11:42 AM | #48 |
10-17-2015, 03:59 AM | #49 |
Rock Crawler Join Date: Aug 2012 Location: Koloa boy 808 2 DA 206
| Re: Fr8cture's JK8
Lots of Sik parts wheels are purdy!!!
10-17-2015, 05:22 AM | #50 |
| Re: Fr8cture's JK8
Hey fr8cture, what are you planning to use for body posts?
10-17-2015, 06:58 AM | #51 |
Rock Stacker Join Date: Jul 2015 Location: Fredneck
| Re: Fr8cture's JK8
I just bought a Toyzuki chassis because of this thread! Thanks Fr8cture!!! I'm liking everything so far. I'll be following along.
10-17-2015, 07:07 AM | #52 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
| Re: Fr8cture's JK8
Fra8cture, Your build Is truly an eye opener for Zuki's products. I have always been a fan of his motor mount but the chassis is WOW. You have done a stand up job at putting this beast together. So much I am going to order one for my Daughters fully loaded 1.9 rig. Keep us updated and Mr Zuki, be looking for a pm shortly. |
10-17-2015, 08:08 AM | #53 |
| Re: Fr8cture's JK8
I have to agree, I had no idea about the chassis or transfer case, good job fr8cture. But I'm not really feeling the Panard bar all that much.
10-17-2015, 10:04 AM | #54 |
| Re: Fr8cture's JK8
I believe the angles of the panhard bar are absolutely necessary when using the outside frame mount and low slung chassis. Looks like the only option to get full cycle of the front end.
10-17-2015, 10:05 AM | #55 |
| Re: Fr8cture's JK8
Yes it's necessary but with the bumper I have coming probably won't be visible. Sent from my VS986 using Tapatalk |
10-17-2015, 10:14 AM | #56 |
10-17-2015, 05:54 PM | #57 |
| Re: Fr8cture's JK8
Scx10 or xr10 body mounts work perfectly. Just run screws through the shock mount holes and thread them into a body post. Use an upper and a lower hole to keep em in place.
10-17-2015, 05:57 PM | #58 |
| Re: Fr8cture's JK8
I'm not poking holes in the body. Sent from my VS986 using Tapatalk |
10-17-2015, 07:28 PM | #59 |
| Re: Fr8cture's JK8
I just read my post and didn't mean any disrespect by saying that I would be purchasing this frame combo for my daughters rig. Her rig is built very well. I was thinking more like, dad would have an optional comp rig for ECSC |
10-17-2015, 07:38 PM | #60 | |
| Re: Fr8cture's JK8 Quote:
Sent from my VS986 using Tapatalk | |
Fr8cture's JK8 - Similar Threads | ||||
Fr8cture's 2dr Jk | fr8cture | 1.9 Scale Rigs | 127 | 01-05-2016 06:01 PM |
Fr8cture's 1.9 KOH Wraith w/ Jcad frame rails | fr8cture | Axial Wraith | 141 | 10-02-2015 10:30 PM |
Kj's Jk8 | King James | 1.9 Scale Rigs | 83 | 04-05-2015 07:50 PM |
sorta jk8 | nwcrawler | Axial SCX-10 | 0 | 12-20-2014 09:58 PM |
