11-21-2015, 09:37 AM | #61 |
Rock Crawler Join Date: Aug 2009 Location: San Antonio
| Re: Shape_Shifter Builds a Komodo |
11-22-2015, 12:21 PM | #62 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
11-22-2015, 01:39 PM | #63 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
11-22-2015, 04:17 PM | #64 |
11-22-2015, 04:46 PM | #65 |
Quarry Creeper Join Date: Oct 2014 Location: Baltimore
I hope you got a Tonka decal to put on the tailgate.
11-22-2015, 05:47 PM | #66 |
11-23-2015, 02:55 PM | #67 |
Rock Crawler Join Date: Dec 2013 Location: Norway
Can't figure out why not you just put the shell on the Ascender. The Ascender got a awesome cms setup from the get go. Then you could slap a sawback shell on the gs01 or something. |
11-23-2015, 03:19 PM | #68 | |
| Re: Shape_Shifter Builds a Komodo Quote:
Second, the Komodo body is not sold sperately yet. Third, I already own a Sawback. | |
11-23-2015, 03:37 PM | #69 |
You already got the Komodo body, it's just to put it on a Ascender if you want Ascender axles. Then you have the opportunity to run the gcm Ascender forward motor mount also. And second the komodo body is for sale, it was shipped to me last week. |
11-23-2015, 03:57 PM | #70 |
| Re: Shape_Shifter Builds a Komodo Meh. I like to build. A body swap is too easy. |
11-23-2015, 06:38 PM | #71 |
Don't you need the Panhard cross link mount to cut down on the bump steer?
11-23-2015, 06:54 PM | #72 |
Have you figured out how different the final ratio is? Also, did you do the R1 overdrive mod before you swapped axles, just curious. |
11-23-2015, 08:38 PM | #73 | ||
I like to be different than everyone else but I need to look at what is involved with making these axles steer properly before I decide how different I want to be...... | ||
11-25-2015, 01:37 PM | #74 |
12-01-2015, 07:31 PM | #75 |
Here you can see many obstacles that would get hung up on the bigger GS01 axles. |
03-30-2016, 06:18 AM | #76 | |
Quarry Creeper Join Date: Feb 2016 Location: canada
| Re: Shape_Shifter Builds a Komodo Quote: https://www.youtube.com/channel/UC0g...bL3c-TM3ELxkWg hope this helps | |
03-30-2016, 09:28 AM | #77 |
09-17-2016, 03:10 PM | #78 |
Newbie Join Date: Apr 2016 Location: Belgium
I'm not surprised at how many people are complaining about the way the 4link suspension acts on the komodo and sawback. I AM surprised though at how little attempts are seemingly made to overcome that. I started trying different layouts and re-arranging the links and mounting points after a 2-minute test drive in the living-room. The kit comes with plent extra parts you can use as spacers and extra screws you can use for different lengths etc. What I think is the biggest issue is how the upper and lower links are not parallel at any time throughout the suspension travel. If you look at the car from the side and draw lines through the links you see those lines crossing: in the rear, not so far behind the car, and in the front , not that hat far forward from the car. How I believe it should be and what I've done is lower the 4 link upper mount points at the chassis side, bot th for the front and rear. Further more I inceased the angle between the upper links looking from the top : by moving the chassis side mounts to the outside of the frame. Unfortunately I've only had 1 chance to drive the car on real terrain, but it definitely felt much better than the initial 2 minute run in its original configuration. (I made a bad drop and bent the rear axles, and destroyed the gears on my servo) |
09-17-2016, 06:15 PM | #79 | |
Ive built a few 1:1 rock crawlers and have a pretty good understanding of off-road vehicle suspension. I think people are over-complicating the suspension of the Komodo. It is an excellent sport truck out of the box. It is not intended for competition without modifications. | |
Shape_Shifter Builds a Komodo - Similar Threads | ||||
Shape_Shifter Builds a Sawback | Shape_Shifter | G-Made Sawback | 58 | 06-09-2014 05:43 PM |
looking for prerunner builds. post builds here | wcdfmt510 | General Scale Talk | 19 | 06-27-2013 09:48 PM |
komodo 2.2 | bamaboy1992 | General Crawlers | 6 | 09-20-2011 10:03 PM |
Komodo | tutit | 1.9 Scale Rigs | 4 | 12-06-2009 06:04 PM |
