Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Rusty
Old 12-26-2015, 10:12 AM   #1
Default Rusty
Hello guys,
Is already from the start of the month that i'm working on very special rig.
it is an evolution of my friend Rat Rod, but with more performance and at least 1.0kg lighter
Homemade parts
Chassis
Links
Body
Interior
Transfer case
Wheels
Motor repro
Bumpers etc
Parts to buy
Yotas axles
Tyres
Electronics
So let's start with the pics
This is the body...
The body is moulded in a colored resin, it is made from a modified sand scorcher abs body
The frame rails are forged with a steel sheet.
seychelles is offline   Reply With Quote
Old 12-26-2015, 10:13 AM   #2
Default Re: Rusty
Subbed
Cheers Jacob
Bmxreeves is offline   Reply With Quote
Old 12-26-2015, 10:33 AM   #3
Default Re: Rusty
Wow, nice body mod's there!
joe122 is offline   Reply With Quote
Old 12-26-2015, 03:07 PM   #4
Default Re: Rusty
Tks Guys
Here are some parts installed from the laser cut
With the body
Old 12-26-2015, 03:09 PM   #5
Default Re: Rusty
Sweet! 2wd or 4wd?
Cheers Jacob
Old 12-26-2015, 03:14 PM   #6
Default Re: Rusty
Originally Posted by Bmxreeves View Post
Sweet! 2wd or 4wd?
Cheers Jacob
4wd
Old 12-26-2015, 07:18 PM   #7
Default Re: Rusty
Very nice start will be following this one!
ctrwannabe is offline   Reply With Quote
Old 12-26-2015, 07:21 PM   #8
Default Re: Rusty
Agreed.
Cheers Jacob
Old 12-26-2015, 08:26 PM   #9
Default Re: Rusty
Great start! I'm tuning in for this one!
Super is offline   Reply With Quote
Old 12-27-2015, 04:20 AM   #10
Default Re: Rusty
Cheers Guys!
Me and my friend Giumik , are making a good job on cad etc.
Giumik made a beautiful work and printed via shapeway..
Old 12-27-2015, 08:07 AM   #11
Default Re: Rusty
This is going to look fantastic (already does). Body work looks great and that engine is killer.
laser cutter must be pretty "handy" to have around.
Mr.Joshua is offline   Reply With Quote
Old 12-27-2015, 10:23 AM   #12
Default Re: Rusty
I build street rods and rat rod this is awesome can't wait to see more.
EZ CHOPPER is offline   Reply With Quote
Old 12-27-2015, 12:32 PM   #13
Default Re: Rusty
Goodness. Stepping up the game with laser cut pieces. Love the forward motor mount and motor is badass brother
Bananaclip is offline   Reply With Quote
Old 12-27-2015, 12:44 PM   #14
Default Re: Rusty
Looking awesome. Can't wait to see more.
THUG LIFE is offline   Reply With Quote
Old 12-27-2015, 12:46 PM   #15
Default Re: Rusty
This will be the most awesome of builds. Them chassis parts are trick.
Szczerba is offline   Reply With Quote
Old 12-27-2015, 04:35 PM   #16
Default Re: Rusty
Tks my friends... Just love to ear this beautiful words
The body is very hard to make a repro...
You have to make a master with your body with all the holes closed, after you made a mold inside and outside...
When is finished you have the 2 parts that can be injected with the plastic resin...
Finally it looks like abs same weight but more elastic...
Resin can be colored so you can basically do with every color you wants...
Old 12-27-2015, 05:16 PM   #17
Default Re: Rusty
Worked on the hpi trans also
Shorted and made the adapter to put a 5mm shaft..
The space are very tight here despite the pictures..
A small 45/50mm drive shaft
For a custommade by robysold an italian friedofmine :-)
This transfer case have a reduction so i can overdrive the front with every axles you want to install in your rig..
Near a flat belly..
Old 12-27-2015, 07:47 PM   #18
distinctive pd's Avatar
Default Re: Rusty
Very interesting! Keep it up
distinctive pd is offline   Reply With Quote
Old 12-27-2015, 08:25 PM   #19
Default Re: Rusty
Subscribed
Sent from my XT1080 using Tapatalk
mikro383 is offline   Reply With Quote
Old 12-28-2015, 10:33 AM   #20
Default Re: Rusty
Tks to all!
Some updates
Spacers for the motor
Need to trim a bit inside and outside the printed
And... Tada!
started also to a simple closin for now..
Rusty - Similar Threads
k.C's rebuild of rusty kelownaCRAWL Axial SCX-10 8 02-19-2015 12:05 AM
Another rusty truggy Constant Threat Paint and Body 5 11-19-2013 09:00 AM
Another rusty FJ40 philgoods9 Axial SCX-10 11 03-18-2010 02:45 PM
My Old Rusty (Newbie) tionunu Axial SCX-10 16 03-16-2009 01:46 PM
Rusty RCcrawlin Newbie General 6 05-03-2006 01:31 PM
