11-09-2016, 10:59 AM | #121 | |
RCC Addict Join Date: Aug 2005 Location: SoCal
| Re: Class "Three" Err I mean Two Tundra by VMGontheRocks Quote:
I actually ended up going with the 4.75s. | |
11-10-2016, 10:56 AM | #122 |
Newbie Join Date: Jun 2016 Location: Billings
Nice looking rig!
11-21-2016, 02:43 PM | #123 |
| Re: Class "Three" Err I mean Two Tundra by VMGontheRocks Thanks! Here's a bunch of pictures from the last two comps. Thanks Justin for the photos! Lost both bedsides and have been running it like that since. Mt. Erie Comp: Got third place, no room for errors and I made one hitting a downhill as I tumbled. Entiat Fire Look Out Comp: Managed to pull a first place! Last edited by VMGontheRocks; 11-21-2016 at 02:47 PM. |
11-21-2016, 06:19 PM | #124 |
Rock Crawler Join Date: Dec 2012 Location: Utah
Looks great and sweet pics! It is awesome you guys have so many names on the monthly comp roster. ... it is a sad seen in Utah anymore were lucky if 3 show up.
11-21-2016, 07:14 PM | #125 | |
It is pretty awesome the turn out we get at most of our comps. The NW has a very healthy scale scene. | |
12-13-2016, 01:12 PM | #126 |
| Re: Class "Three" Err I mean Two Tundra by VMGontheRocks Broke a link at the last comp, thought it was the rod end at first, but the actual threaded portion of the link broke. Looks like it will be time to bend up some new ones. Also a little freshen up with a new front bumper. Thanks David! Looks like I need to sand and paint the grill and maybe respray the cab. |
02-10-2017, 07:48 AM | #127 |
Newbie Join Date: Feb 2013 Location: windsor
Hello there. I am currently in the beginning stages of my own v1 toyzuki build. I am working in the motor mount currently. I am having problems with the topshaft. I ordered axial part ax31149 slipper drive gear shaft. I mounted my lockedup rc slipper eliminator and spur gear up and slid it into the motor mount. I have read through both of your build threads on your 2 chassis. I see how you modify your shaft but it shows that you only remove about 1/8". I have about 16mm that needs to be removed. I will also need to drill a new hole for the drive shaft pin. What am I doing wrong ?!?!? I appreciate any advice that you may have |
02-15-2017, 05:19 AM | #128 |
Quarry Creeper Join Date: May 2016 Location: Nässjö
| Re: Class "Three" Err I mean Two Tundra by VMGontheRocks Quote: Did you figure it out? I have same "problem" Skickat från min iPhone med Tapatalk |
02-15-2017, 04:32 PM | #129 |
[QUOTE="Johan_Eriksson;5667410"] Did you figure it out? I have same "problem" Skickat från min iPhone med w Well I decided that I'm going to just drill a new pin hole and cut the shaft down |
02-15-2017, 06:44 PM | #130 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
You can simply put a spacer in to take up the 16mm
02-15-2017, 11:38 PM | #131 |
| Re: Class "Three" Err I mean Two Tundra by VMGontheRocks |
02-16-2017, 06:34 AM | #132 |
02-16-2017, 07:33 AM | #133 |
02-16-2017, 08:23 AM | #134 |
| Re: Class "Three" Err I mean Two Tundra by VMGontheRocks the locked up slipper eliminator didnt come with a shaft. i ordered it directly from locked up. ill order the other axial shaft. thanks for posting the part number. i have read through this thread many times and never found that number. i also tried to search through the exploded views of the transmissions to find it. all i could find was the shaft i ordered which ended up being too long, so i really appreciate the help
02-16-2017, 01:37 PM | #135 |
As svt923 said, AX30197 is the part number you want. I didn't realize how many different top shafts there were. I had a bunch of SCX10 transmissions so I just robbed one of those for all the parts.
02-16-2017, 02:53 PM | #136 |
| Cool thanks man. I appreciate you paving the way for the rest of us!!
02-17-2017, 09:51 AM | #137 |
Newbie Join Date: Jan 2017 Location: cartersville
Badass truck man
03-06-2017, 12:17 PM | #138 |
04-17-2017, 02:55 AM | #139 |
Some pics Justin (https://www.facebook.com/justinart24/) took from the last comp: This truck needs some love before Nats lol |
04-24-2017, 01:25 PM | #140 |
Wrong
Class "Three" Err I mean Two Tundra by VMGontheRocks - Similar Threads | ||||
Class One Tundra by VMGontheRocks | VMGontheRocks | 1.9 Scale Rigs | 163 | 05-20-2018 10:22 PM |
Tundra truggy class 2 (Pink Taco) | Moosekey | 1.9 Scale Rigs | 87 | 05-09-2015 12:28 PM |
Class 2 or 3 Tundra Truggy | Just Zach | 1.9 Scale Rigs | 46 | 01-14-2012 10:22 AM |
