03-28-2016, 06:45 PM | #41 |
| Re: Old Blue (Memory Lane Build) |
03-28-2016, 07:34 PM | #42 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
How much more travel do you get with trailing arms? __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra |
03-28-2016, 08:27 PM | #43 |
RCC Addict Join Date: Feb 2008 Location: your back yard
I'm watching to see what your going to do with that. Sent from my SM-G900V using Tapatalk |
03-28-2016, 09:01 PM | #44 | |
| Re: Old Blue (Memory Lane Build) Quote:
Approximately 50% more than shocks on axle. These are 90MM Traxxas big bores. Hope I don't disappoint. | |
03-28-2016, 09:03 PM | #45 |
Cool. I'm probably going to have a lot with 103mm Gmade shocks. __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra |
03-28-2016, 09:16 PM | #46 |
03-28-2016, 10:29 PM | #47 |
. Its a 3 5/16th length mounted about half way up __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra |
03-29-2016, 07:59 AM | #48 | |
My wife's scx10 is running the same big bores as mine on the stock axle, about 2" stroke length on each corner. Where this build has about 3" on each corner, but the perceived spring rate on mine is 50%softer, and dampening is 50% less effective. Meaning you need stiffer springs and thicker oil to get the same feel out of the trailing arm setup. Trailing arms are levers and have the same effect as a longer lever when moving something. Last edited by lonleycreeper; 03-29-2016 at 08:03 AM. | |
03-29-2016, 08:28 AM | #49 |
Yup. Totally makes sense. How do you look the estra travel when your going fast? __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra |
03-29-2016, 09:11 AM | #50 |
I find that proper shock tuning is critical no matter how much travel you have, especially the faster the truck is. Weight balance is another critical adjustment to tuning a rig for going fast. Longer travel gives you a little extra leeway but is not a substitute for good tuning.
03-29-2016, 09:21 AM | #51 | |
Totally agreed. I think im actually going to need to a soften everything I little, cause mine is stiff cause I don't have much up travel. We will see though. __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra | |
03-30-2016, 06:05 PM | #52 |
03-30-2016, 06:18 PM | #53 |
Next to the wifes hilux. Last edited by lonleycreeper; 09-27-2017 at 10:52 AM. |
03-31-2016, 06:40 AM | #54 |
Truck looks really good, I'm liking the stance. Need to see that bed in person, hard to see in pics but it's coming along. Any plans for wheel wells? How about the shocks, leaving open or doing a box around them? I should just shut up and watch.. :/
03-31-2016, 01:53 PM | #55 | |
Yes to wheel wells, but going tubs after I get the sway bar in. The shocks are getting a tube cage and spare tire mount, kinda prerunner,ish. | |
03-31-2016, 02:42 PM | #56 |
What sway bar are you getting? I have a Vanquish antirock and its way to stiff __________________________ 1.9 Ibex tuber - The Merica ibex. |
03-31-2016, 06:01 PM | #57 | |
3/32" steel rod and wraith links. The stock bars were to short to go through the frame rails, so custom here we go. | |
03-31-2016, 09:20 PM | #58 |
Reigned in the crazy flex. This should handle better. Last edited by lonleycreeper; 09-27-2017 at 10:53 AM. |
04-01-2016, 08:43 PM | #59 |
04-01-2016, 08:46 PM | #60 |
Oh that looks awesome. If you going with a winch extend out not on top. Room to run one under the hood? Just my .02 Sent from my SM-G900V using Tapatalk |
Old Blue (Memory Lane Build) - Similar Threads | ||||
A trip down memory lane | Full Throttle Rob | Maine | 8 | 01-06-2016 10:20 AM |
Locked Up's "Memory Lane" builds... | Locked Up | Non Crawler RC's | 72 | 12-27-2014 02:54 PM |
Screaming blue build | spitfireat808 | Hawaii | 4 | 10-10-2013 08:21 PM |
Blue Bronco Build | habenero | Axial SCX-10 | 26 | 06-15-2013 01:20 PM |
Memory Foams Weights Kreepy's and Memory Makers | chivas72 | Tires and Wheels | 18 | 02-22-2008 08:01 AM |
