![]() | #1 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
Hello all! I am just in the process of starting my FJ Cruiser build using RC4WD Gelande II kit. The rear leaf springs will mount to the axle easy enough using 2mm & 3mm metal spacers since the rear axle has nice round notches for round spacers to fit. Front axle is a little different than most other guys I have seen do the leafs on! I think I got a newer axle and it seems solid cast! They didn't include the nice little notches so now what to do? Should I cut my spacer flat to fit? I am not sure if I want to dremel any parts of the axle housing. Here are pics of the axle area. See how the holes where the bolts for the leaf springs go are? I actually didn't even pay attention until I was tightening down the leaf with round metal spacer and was like what the?? ![]() ![]() |
![]() | #2 |
Oppan Gangnam Style ![]() Join Date: Jun 2005 Location: Shingle Springs
If you doing a spring under setup, looks like you will need to break out the dremel.
![]() | #3 |
Yes I am doing a spring under. I will dremel my spacers I guess? I am a dummy and thought the spacers would be the same on the front as the rear. 2mm & 3mm on rear. I cut a 3mm with a nice flat spot and then realized it is too small. I have to use 4mm & 5mm on front to have leafs mount as flush to axle as possible and also give a decent angle for the driveshaft. Oh the learning curve for a newbie! Now I wait for 5mm spacers. In Canada we have to wait for all good RC parts. Even more so in my super tiny town with no LHS! I am using RC4WD sapcers because I couldn't get a decent shipping deal from other vendors. :( Last edited by ZippoMan; 03-30-2016 at 01:15 PM. |
![]() | #4 |
I got the fronts mounted after hacking the spacers with a dremel. Not pretty but will work. I will post pics later. It really isn't pretty but works and I need to touch up the black axles with paint now. ![]() |
![]() | #5 |
![]() | #6 |
Official Scale Nazi Join Date: Sep 2004 Location: Monticello, IL
Looks good to me. I filed flat spots on the axle tube to give a place for the leafs to sit flat. Your way will work too especially if you're not using u-bolts.
![]() | #7 |
I wanna be Dave ![]() Join Date: Apr 2014 Location: North Carolina
Looks like you're coming along well. For what it's worth, I did a step-by-step how-to thread with leafs over axle a little while back. Your solution on leafs under axle works well, as would U bolts. Here's the link to mine if it helps: How-to convert from links to leafs on a Gelande chassis |
![]() | #8 |
Thanks guys and I will be reading more threads and taking in all the info. I am grateful to have this community and a couple others for knowledge. I am totally new to building anything beyond a basic kit with bolt on parts. I am scared of customizing because I don't have all the right tools, skills & money to go hardcore.
![]() | #9 |
Newbie ![]() Join Date: Jan 2016 Location: california
I used a piece of nylon rod I had around that happen to be drilled out to just the right size. I notched one end with the dremel to fit . Then cut to length. 5, or 6 mm, cant remember.I temporarily glued them in place with CA, the filed down to match the top of the axle. I will see if I have any pics.
![]() | #10 |
Yeah I don't have the luxury of nylon rods. I was crazy and bought the metal spacers. They are working out decent enough for me. Pics would be cool to see! I love pics always! It helps wrap my brain around the situation better. |
![]() | #11 | |
| ![]() Quote:
![]() | #12 | |
| ![]() Quote:
Lol. One of my regular running mates gives me grief about Revolvers pretty regularly for that same reason. You can easily substitute Bruiser shackles for the Revolvers and otherwise follow the same steps if you want. As for the fear of modifying, most of us have been there at some point. My first several scale builds were all bolt-on in part for that reason, and I remember the deep breath I had to take when I first took a saw to the interior of my D110. Modification and fabrication can sound like scary words at first, but they're really not. If you've used a Dremel or drill on any part, you've modified something. If you've used any sort of raw material to make or modify any part, you've done fabrication. Once you get over the psychological hurdle, you'll find that you open a lot of doors in your builds and get an even greater sense of satisfaction from them. And the good news is that there are virtually no parts in this hobby that can't be replaced cheaply if you mess up during a build. ![]() | |
![]() | #13 | |
| ![]() Quote:
![]() | #14 |
Rock Crawler ![]() Join Date: Oct 2009 Location: Upstate NY
Aren't Yota II's reversible? Leave the housing with mounts down and reverse the hubs and internals. I don't have Yota II's, but it seems like it should work, maybe I'm wrong.
![]() | #15 |
I got the leafs mounted. I guess if I have any further issues I might flip stuff but I want to keep it the way it is. Fingers crossed for future success. It is a super slow project for me due to skills, parts and funds. ![]() |
![]() | #16 |
I was thinking couldn't the bruiser U Bolts be used to do leaf under? Would be more realistic if it would work.
![]() | #17 |
![]() | #18 |
Newbie Join Date: Sep 2019 Location: Canada
How did you end up finalizing the installation? I’m still working on mine and have the driveshaft right up against the transmission. Also having an issue with the placement of the steering stabilizer in the axle over configuration.
Gelande 2 Cruiser from Alaska! | AKbash57 | 1.9 Scale Rigs | 39 | 01-22-2016 08:27 AM |
My Gelande 2 CRUISER | Toylux | 1.9 Scale Rigs | 0 | 09-17-2015 11:26 AM |
Rc4wd gelande 2 land cruiser | neon9 | 1.9 Scale Rigs | 8 | 06-16-2015 09:40 PM |
