Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Cherokee XJ Hardbody Class 1 Build
Old 09-14-2017, 08:46 AM   #121
Default Re: Cherokee XJ Hardbody Class 1 Build
Awesome job so far. Love the attention to detail!
IVIaarten is offline   Reply With Quote
Old 09-14-2017, 08:51 AM   #122
That hoodlatch is superb. Nice job.
grandbolin is offline   Reply With Quote
Old 09-22-2017, 12:43 PM   #123
I got the dash wired up and installed. This isn't something new or unseen.
Works pretty well.
I regret not making the gauges light up with the headlights. Especially since it's going to have a working dome light.
Dustinf is offline   Reply With Quote
Old 09-22-2017, 01:03 PM   #124
I mocked up all the interior pieces that I've finished. Just to have a look. Still a ways to go before final install.
It's nice to see it looking like something.
I'll be making a headliner and all the other interior parts for around the windows using styrene. I also need to carpet the floor.
Old 09-26-2017, 10:08 PM   #125
I've started making the other interior pieces. Roof liner and everything else that is needed.
But I've decided that I should paint the outside of the body first, That way I can glue the interior pieces as I make them.
I think this will be much easier... and it beats trying to hold four things in place at the same time while measuring.
Old 09-27-2017, 07:50 AM   #126
Very good looking c1 sir!
ThatJeeper2017 is offline   Reply With Quote
Old 09-27-2017, 11:19 AM   #127
Natedog's Avatar
Originally Posted by Dustinf View Post
I've ordered there 1:10 bonnet hinges from shapeways... I'm hoping they work.
The measurements make them seem huge.. but I'll have to wait until they come in.
Nice.
How would you guys attach shapeways "strong and flexible" plastic hinges to the jeep hard body?
I'm thinking of drilling some small holes and using some two part epoxy.
E6000 is what I'd use, great stuff!
I decided to make my own hinges... Hopefully these will work and look ok. They are pretty precise.
Very nice detailed build, love that you're trying to keep weight down but still super detailed!
Old 09-30-2017, 02:35 PM   #128
Well.. I've finally put on the first color coat.
I have a ways to go though. Sanding, clear coat... wet sand and polish.
But this is the start.
Old 10-02-2017, 06:11 PM   #129
Default Tamiya TS-13 clear coat question
Any of you guys have experience with Tamiya TS-13 clear coat?
I've read that you need to spray it right away or wait a month...
I'm looking for real world experience and or any tips you can give.
Seriously.. any advice, id hate to ruin this body.
I normally don't clear coat, but I plan on wet sanding and polishing this one.. so it's worth the extra time.
Old 10-03-2017, 01:20 PM   #130
I too read the horror stories but it it worked fine in my climate. I started with light coats and built up to a heavier finish coat. I think the only way to know for sure though would be to test it on a sample.
Highmark is offline   Reply With Quote
Old 10-07-2017, 09:41 PM   #131
I've just been painting... and sanding..
Here is just the hood, wet sanded to 12000. It's unpolished in the photo.
The entire body and windshield will be getting this treatment.
I've painted the fenders, bumpers and grill in TS-29 (semi gloss black).. but it is too shiny for my tastes. Luckily I ordered and intended to spray TS-80 (matte clear) over it. Though I may take it off and just hit the plastic parts, as the bumpers one a full scale are painted in semigloss where everything else is molded plastic.
Old 10-07-2017, 09:49 PM   #132
As for the gloss clear coat: I've decided not to use it.
I did a test and it came out fine, but for some reason the clear coat looked less scale.*
I guess if you took the thickness of the clear coat and worked it out to full scale... it would be really thick. Maybe that's why.*
So wet sanded/polished paint seems to look better. Which is convenient at the very least.
Old 10-11-2017, 12:33 PM   #133
Wet sanding a cherokee body is not for the unmotivated... or the employed... or anybody. No one should do this.
So many sharp edges to avoid.
This is going to take forever.
Old 10-18-2017, 09:30 AM   #134
Still sanding and polishing.
It's slow going... But it is getting somewhere.
I've been taking a bit of a break from this build to put together the Gmade GOM kit and see what that's all about. I'm not going too crazy with that build so it shouldn't take long.
Old 10-18-2017, 10:08 AM   #135
I've seen few people bother to wet sand and polish the paint on an RC body, but you're the first I've seen tape up the edges to keep a sharp crisp line. Even some body shops don't take that step.
I'm really interested in the Axles on that new Gmade kit
Sent from my SM-N900T using Tapatalk
spoo76 is offline   Reply With Quote
Old 10-20-2017, 08:12 AM   #136
I can see why they wouldn't wet sand.
The axles on the GOM are really nice. They feel solid and have less flex than the ar60 on my yeti.
People are complaining about the locker being too small, though I havnt heard of any breaks yet. And they sell an machined locker in case it does.
Old 10-20-2017, 08:20 AM   #137
Does it use the same diff gear/locker combo as the R1 & drawback?
Old 10-20-2017, 02:32 PM   #138
I don't own either of those. But from pictures I looked up, no. Different locker. More similar to a twin hammers or scx10.
Old 10-24-2017, 02:38 PM   #139
one of the best builds I've seen. Will it be a shelf queen or not?
ussprinceton2004 is offline   Reply With Quote
Old 11-08-2017, 09:40 AM   #140
Thanks man!
It will be a Trail rig... that I baby and try to keep shiny.
After all the work of wet sanding... I don't want to do it again.
Luckily I've decided, after much internal debate, to use my buffing wheels with New, soft wheels on them and tamiya compound.
This will speed things up so I can get back to actually building.
Tags
cherokee, class, hardbody, jeep, scale
Cherokee XJ Hardbody Class 1 Build - Similar Threads
Just saw this on FB - cherokee XJ hardbody Noll11 Paint and Body 239 03-07-2017 09:02 PM
Nappy's Class 1 Cherokee build "Frank" Nappy Axial SCX-10 7 01-22-2015 10:58 AM
cherokee hardbody? Stitch General Scale Talk 6 12-03-2008 02:07 AM
