Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Heavy metal
Old 08-28-2016, 09:24 PM   #1
Default Heavy metal
FINALLY GOT AROUND TO BULDING THIS 8X8 ITS TAKING ME SOME TIME TO FIGURE THIS ONE OUT. THE STEERING WAS THE KICKER BUT I GOT IT AFTER ABOUT TWO DAYS ON IT USE A TAMIYA SEMI FRAME TOOK SOME LEAF SPRINGS SHORTEN THEM MADE SOME BRACKETS OUT OFF ALUMINUM. TOOK A TAMIYA GLOB LINER BODY AND CUT IT TO FIT WHAT I NEEDED AND PLASTIC WELDED OTHER PIECE TO IT TO MAKE THE SHAP IM GOING TO LEAVE THE WELDS SHOW. HAD TO USE TWO TRANFER CASES TO MAKE THE DRIVE LINE WORK CAUSE I WANTED TO KEEP IT KIND OF SHORT COULD NOT PUT A TRANS IN BETWEEN THE CENTER AXLES DRIVE SHAFT WOULDNT WORK WITH THAT SHORT OF WHEEL BASE HARD TO DO IT ON A 8X8. THE WHEEL BASE IS 17 1/2 CENTER TO CENTER TO THE OUTER AXLES. USE VANQUISH HIGH CLEARANCE KNOCKLES ON BOTH FRONT AXLES. TOOK A PIECE OF SHEET METAL AND SHAPED IT TO GET THE FORM OF THE FENDERS.HAVE TO REMOUNT THE MOTOR CAUSE I HAD TO LIFT THE FRAME UP A LITTLE SO I COULD GET MY FENDERS RIGHT. ITS GOING TO HAVE A 2 SPEED OR 3 SPEED JUST HAVE TO SEE HOW MUCH ROOM I HAVE NOW. HAD TO MAKE A SERVO MOUNT FOR THE STEERING WAS HAVING A HELL OF A TIME WITH THAT BUT I GOT IT. STILL HAVE SOME TO SOME STUFF ON THE BODY THEN PAINT IT GETTING CLOSER WITH THIS THING. I PROBABLY FORGOT SOMETHING ANY QUESTIONS JUST ASK
EZ CHOPPER is offline   Reply With Quote
Old 08-29-2016, 12:26 AM   #2
Default Re: Heavy metal
Looks like the big log hauler in Spin Tires
kgb424 is offline   Reply With Quote
Old 08-29-2016, 07:52 AM   #3
it is. I mad it after a MAZ 537 still need to put some scale stuff on it.
Old 08-29-2016, 08:20 AM   #4
That thing is nuts. Where did you find TLT axle stays?
ElChupacabra is offline   Reply With Quote
Old 08-29-2016, 08:25 AM   #5
That's a lot of driveshafts!
travis c. is offline   Reply With Quote
Old 08-29-2016, 08:34 AM   #6
I had some old Tamiya semi parts laying
Old 08-29-2016, 09:06 AM   #7
Amazing work on everything! Don't know where to start. Plastic welding, suspension, wheels, great build.
Szczerba is offline   Reply With Quote
Old 08-29-2016, 09:33 AM   #8
reminds me of a m983
CM9000 is offline   Reply With Quote
Old 08-29-2016, 11:49 AM   #9
Yep there is 2 MAZ's in Spin Tires there is MAZ 537
And there is the MAZ 7310 and it has a split cab
Old 08-29-2016, 07:35 PM   #10
ill have to check that out it might be my next build
Old 08-29-2016, 09:40 PM   #11
ok I Googled a MAZ 537 and your is dead one
I got pictures of the real vechile and pictures from Spin Tires
And you can see the cab is split and there is a radiator in between
Old 08-29-2016, 09:43 PM   #12
How did you do all that with a straitjacket on?
Cuz you sir are a madman.
Derek Larsen is offline   Reply With Quote
Old 08-29-2016, 10:13 PM   #13
Wow!
I was playing at work the other day and was daydreaming about what I wish I could build next. It's crazy, you've built something amazingly close to what I daydreamed.
Amazing work. Very, very cool build.
mmatthews is offline   Reply With Quote
Old 08-30-2016, 05:43 AM   #14
Still want to do some detailing on it
Old 08-30-2016, 05:58 AM   #15
Had it out the other day got to watch the front end its like a plow cause the wheels so far back from the front.
Old 08-30-2016, 08:10 AM   #16
Looks awesome, I watched the video zzr posted on YouTube. How did it fair after the rollover?
JBurke187 is offline   Reply With Quote
Old 08-30-2016, 02:13 PM   #17
I let it keep rolling down the hill it went back on its wheels and it was fine I had to do some adjusting on the steering but I got it fixed
Heavy metal - Similar Threads
Heavy Metal Question RANOVRU Chit Chat 12 12-02-2012 06:47 PM
Heavy metal !!! riz Chit Chat 0 03-15-2011 06:55 PM
Heavy Metal Clod kineteks General Crawlers 2 03-18-2009 02:51 PM
